New BMS model
Inwo
Re: New BMS model
Post by Inwo » Jun 12, 2017 7:42 pm
Thank you,
Getting quit a bit of interest. As soon as I get pricing, I'll post.
Inwo
Re: New BMS model
Post by Inwo » Jun 17, 2017 4:20 pm
Always next week! :(
I someone doesn't want to wait, I will sell my demo.
Works perfectly.
$200 + $6.50 CONUS
Sold, ....
(123.98 KiB) Downloaded 22 times
macribs
1 GW
1 GW
Re: New BMS model
Post by macribs » Jun 18, 2017 10:26 am
Keep the spirit up, we will continue to drop by. I am sure it will be ready in due time.
Inwo
Re: New BMS model
Post by Inwo » Jun 22, 2017 10:38 pm
Was able to make a preliminary order of samples.
Prices are up being it is a two piece unit. Main unit plus display. Both in aluminum enclosures.
Singles are $300
5 pcs $275 each
liamcaff
Re: New BMS model
Post by liamcaff » Jun 23, 2017 3:47 am
Will this suit a setup consisting of 20s Lipo, a Cycle Analyst and a controller from powervelocity.com?
Cost for EU buyers?
Inwo
Re: New BMS model
Post by Inwo » Jun 23, 2017 10:12 am
I believe pricing direct is the same.
If it's faster, I can ship on your label.
You might check, as the main market is China and eu.
Should work fine for you.
Inwo
Re: New BMS model
Post by Inwo » Jun 30, 2017 6:25 pm
Promise to ship from factory on Monday.
$300
Special Features
1. The BMS24T uses advanced ADC measurement technology, high accuracy, high voltage and high current
detection circuit. The maximum voltage measurements tolerance is within 5mV at up to 24S LiPo battery
(102V)
2. Support regenerative braking, during braking operation can charge the batter pack and the discharge power
(Wh) will decrease to response to the braking power.
3. Charge/discharge current up to 600A. Bigger current can be customized.
4. 1.2A per cell balance current is very useful for large capacity battery pack, the feature can resume all cell
voltage balance status at the shortest time. Over temperature protection make sure the system safety
during balance.
5. BMS24T calculate and display the charge and discharge power (Wh), generally the battery rated power is
rated voltage multiply rated battery capacity.
6. TFT LCD screen provides rich information including current, voltage, power, capacity, battery status, SOC
and temperature and so on.
7. BMS24T features a maximal safety protection, within the range parameters can be setup, BMS24T will alarm
and cutoff charge or discharge according to users’ setup, out of range of parameters, and trigged absolute
maximum ratings BMS24T will force to cutoff charge or discharge to prevent the battery from fire.
8. Minimize the power consumption by draw current from all cells or external power supply.
9. Dual power design, the unit can be powered by all cells or external power supply.
10. Detect cell count at any time, and compare with the count detected when switch on first time. If it is not
uniformity, the device will alarm and cutoff charge or discharge according to users’ setup, the feature can
prevent any cell connection from loosing.
11. Sound alarm and LED alarm will be triggered when any warning events happened, and then wait several
seconds cut off or Don't cut off charge or discharge. The delay time can be programmed.
12. Charge relay and discharge relay are controlled independently.
13. Two temperature sensors monitor battery temperature on different position.
14. Supports upgrading the firmware program by USB port.
15. BMS24T provide users the maximal flexibility, key parameters can be programmed.
16. BMS24T display battery SOC or called battery gauge similar with car dashboard. Cell count, battery pack
voltage and battery gauge (%) is displayed simultaneously.
17. In case that the battery pack need not be charged and discharged, Press STOP button enter into sleep mode
to save energy consumption, at this mode, Charge and Discharge is forbidden, and LCD back light is off.
Press any key to resume normal work mode.
18. LCD back light ON time can be programmed to save energy, when it is OFF, press any key to resume “ON”.
Protection functions
1. Cell count error protection
2. Over charge protection
3. Under voltage protection
4. Over current protection when charge or discharge
5. Over temperature protection
6. Over differential cell voltage protection
7. Over differential battery temperature protection
8. Under SOC protection
GmagNeato
Re: New BMS model
Post by GmagNeato » Jun 30, 2017 9:30 pm
What is the displays tolerance to elements (rain, dust, impact, etc)? Does it have any mounting solutions (prethreaded holes for a mounting bracket, etc)? And can it be purchased separately if a replacement is needed?
1st build: (commuter conversion) Novara HT / DIY 15s7p Panasonic NCRB's (harvested from used laptop packs) / 40a generic Chinese controller / 1500w 5T Leaf motor (STOCK)
2nd build: EEB frame / 20s4p of 7200mah Turnigy Hard Case Packs, 74v nominal, 28.8ah, 2131wh / Adaptto Max-E (9G4 firmware currently) + BMS + 70a Charge Coil onboard / QS 205 V3 Extra 5T
Inwo
Re: New BMS model
Post by Inwo » Jun 30, 2017 10:19 pm
Not rated for moisture or dust, as they use xh and rj connections.
They seem rugged for vibration.
No mounting options.
More suited for stationary and enclosed ev application.
I can ask about buying replacement modules.
The bms itself is very repairable. I have been doing repairs on original models, from incorrect connections.
Factory seems very helpful in obtaining repair parts.
Also open to suggestion for upgrades.
John Bozi
Re: New BMS model
Post by John Bozi » Jul 01, 2017 6:58 pm
It looks designed around 3 x 8s packs which are incredibly rare for the diy crowd. There are tons of ebike users who use hobby king lipo and the most common highest series pack with lots of choices is 6s.
Inwo
Re: New BMS model
Post by Inwo » Jul 01, 2017 8:51 pm
Works fine for up to 4 6packs with xh re-pinning.
If it was popular we could supply adapter board.
Inwo
Re: New BMS model
Post by Inwo » Jul 13, 2017 5:08 pm
Shipment arrived here, for 3day delivery to USA address.
Untested as of now. Brand new model.
300a shunt included.
Singles:
$312.40 delivered medium flat rate box.
GmagNeato
Re: New BMS model
Post by GmagNeato » Jul 13, 2017 5:29 pm
What type of warranty are you offering?
cal3thousand
Re: New BMS model
Post by cal3thousand » Jul 13, 2017 6:06 pm
I would love some video showing the operation. It would certainly help my wallet open up
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Inwo
Re: New BMS model
Post by Inwo » Jul 13, 2017 7:00 pm
I have some customers who may help me out with the video.
Standard manufacturers warranty.
I can also help as problems arise. To save shipping out of country for USA customers.
Can't promise better than factory warranty, but Jason has promised to support me in simplifying any service that might be needed.
The last round I was able to help some customers. Even those who purchased direct from factory.
Rube
Re: New BMS model
Post by Rube » Jul 14, 2017 5:21 am
Inwo, you are doing some really cools stuff by promoting these products. Great work :D
I'll consider the BMS and charger when the next build rolls around.
Inwo
Re: New BMS model
Post by Inwo » Jul 14, 2017 3:21 pm
It's been fun.
I helped Jason from Chargery with some early bugs and repairs. Didn't give him grief when the first bms got so hot, all the chips fell off the board.
Now it seems I'm the guy for the N.A. market.
He is building me some neat products.
Inwo
Re: New BMS model
Post by Inwo » Jul 14, 2017 3:24 pm
John Bozi wrote:It looks designed around 3 x 8s packs which are incredibly rare for the diy crowd. There are tons of ebike users who use hobby king lipo and the most common highest series pack with lots of choices is 6s.
Almost forgot, as I didn't order any. The bms-16 is a parallel product with the same specs.
I don't know if the price difference warrant selling them.
Inwo
Re: New BMS model
Post by Inwo » Jul 15, 2017 6:01 pm
Custom mount in my Gem! :D
Inwo
Re: New BMS model
Post by Inwo » Jul 16, 2017 6:22 pm
Have another original model bms-24. Seems quite a few want the discrete lcd display, so I'm offering trades.
I'll post as I get them.
Trade bms only, so accessories are new.
Have one here now. $200
Also a Chinese 91v 15a charger that I got for 22s. Don't know if it can be turned up to 100v or not.
Using the beta Chargery now so don't need it. $125
(123.98 KiB) Downloaded 1 time
China charger.jpg (80.24 KiB) Viewed 305 times
I guess this is in the wrong place, as these two are used......................
lukas999
Re: New BMS model
Post by lukas999 » Nov 13, 2017 1:59 pm
Hey guys
anyone have firmware update file for 2 24 s bms from chargery.com ?
can't find a link on their web site
please send me link via PM
Thanks You for Your help
Lucas
liamcaff
Re: New BMS model
Post by liamcaff » Feb 10, 2018 8:45 am
Any more updates/videos on this product?
