New BMS model
Inwo   10 kW
Re: New BMS model
Post by Inwo » Mar 03 2017 7:55pm
Just noticed the reference to db-25 cable.
The bms itself is located near batteries. The cables that I mentioned are for extending the lcd and switches, only, to a remote location.
Inwo   10 kW
Re: New BMS model
Post by Inwo » Mar 03 2017 11:53pm
$250 priority mail delivery from USA.
Usa distributor.
Dealer pricing.
Bison_69   100 W
Re: New BMS model
Post by Bison_69 » Mar 04 2017 7:48pm
Here is an interesting BMS developpment kit for guys that like programming...
It is From Intersil Evaluation Kit... #ISL78610 (up to 168 channels in a daisy chain setup) (available at Digikey)
http://www.intersil.com/en/products/end ... 78610.html
http://www.intersil.com/content/dam/int ... l78610.pdf
http://www.intersil.com/content/dam/Int ... 1z-top.jpg
This board could be interface with a nanoPI NEO AIR micro PC and via its bluetooth/wi-fi communication give you all wireless data on a smartphone (with an app)
http://www.friendlyarm.com/index.php?ro ... uct_id=151
CityTrackPro 2015 eBike http://http://kobois.com
QS MOTOR 205 H50 V3 hub-motor
KELLY 7230S 90V 120A (300A peak) Controller w/Bluetooth
Large screen CycleAnalyst
Batteries 18650 VTC4 LiFePO4 21S10P
SMART BMS 16-32S / 200A w/Bluetooth and LCD Display
SolidWorks Designer - electric Trike and new eBike frame for a Montreal friend well known on the forum.
Free Personal 3D Drawings download http://grabcad.com/sg/projects
"Your tiny little human brains. How do you get around in those things?"
Bison_69   100 W
Re: New BMS model
Post by Bison_69 » Mar 05 2017 3:09pm
Another interesting BMS type... provided by TYVA...
Hand key solution... (6 to 25 cells) wireless data to smartphone...
http://www.tyva-energie.com/en/moduloo- ... a-bms.html
http://www.tyva-energie.com/images/pdf/ ... 5S_7.0.pdf
Inwo   10 kW
Re: New BMS model
Post by Inwo » Mar 05 2017 3:34pm
Do you have any information on it? As per usual,doesn't tell you much.
Will it go down to 2.75v per cell? Pricing? Bt or canbus only display.
johnnyz   1 kW
Re: New BMS model
Post by johnnyz » Mar 05 2017 4:14pm
Inwo wrote:Do you have any information on it? As per usual,doesn't tell you much.
All parameters are controllable. You can get the alarm to switch on at 3 volts for example and cut off at 2.75 which is what I will be doing.
Factory pricing is $214
Inwo   10 kW
Re: New BMS model
Post by Inwo » Mar 05 2017 10:53pm
Many are programmable. Few can be set to 2.75 volts hvc.
XLR8   100 W
Re: New BMS model
Post by XLR8 » Mar 22 2017 9:48pm
Can't see anywhere that this BMS does cell balancing, only monitoring.
amberwolf   100 GW
Re: New BMS model
Post by amberwolf » Mar 23 2017 1:08am
XLR8 wrote:Can't see anywhere that this BMS does cell balancing, only monitoring.
Maybe in the first post?
Inwo wrote: Price is high, but they are the best designed (or only) 24s monitor/balancer I've seen.
1.2 amps balance current.
XLR8   100 W
Re: New BMS model
Post by XLR8 » Mar 23 2017 3:29am
Sorry, I was referring to a post just 2 posts back. I should have quoted it in my reply.
zerous   100 µW
100 µW
Re: New BMS model
Post by zerous » Mar 23 2017 1:27pm
Bison_69 wrote:Another interesting BMS type... provided by TYVA...
Any idea about price? Can not find information about resellers
johnnyz   1 kW
Re: New BMS model
Post by johnnyz » Apr 03 2017 7:12am
Just a glance a this product tells me it is inferior to the BMS24 from Chargery as it can only balance at .2 amp while the Chargery BMS balanced my 24s 20 ah pack very quickly (in a couple of hours), because it pulses at 1.2 amp!.
John
zerous   100 µW
100 µW
Re: New BMS model
Post by zerous » Apr 03 2017 9:04am
John
My battery pack is 25S, there is not many BMS out there build for 25 cells.
johnnyz   1 kW
Re: New BMS model
Post by johnnyz » Apr 07 2017 1:10pm
Why 25s??...
Ok judging by the lack of response to this question it appears it confirms how difficult it is to get good BMS units at good prices in REASONABLE time...
I found Sunpowerbattery...and here is a link to their products...http://www.batterysupports.com/lifepo4- ... 32_36.html
Has anyone had experience with these BMS units?
John
Inwo   10 kW
Re: New BMS model
Post by Inwo » Apr 13 2017 10:40pm
Only had 20 pcs.
All sold.
One failure, which was easily repaired. Common parts and great support.
Plus one from a customer who connected it wrong. I was able to repair it for him quickly at no charge. That will not always be possible.
Should have the new and improved model for beta testing in a couple weeks.
sacko   10 kW
Re: New BMS model
Post by sacko » Apr 15 2017 2:45am
Possibility of a 38s BMS?
I have a Leaf Cell Vectrix conversion and looking for something like this.
Inwo   10 kW
Re: New BMS model
Post by Inwo » Apr 15 2017 9:09am
Not in the works. This company is geared to the rc market.
I have explored the possibility of using two. It can be done, but is it worth while.
Imo only problem is keeping them isolated. Should not be hard to do.
What type of charge/discharge control is needed? Relays or logic?
bionicon   100 W
Re: New BMS model
Post by bionicon » Apr 21 2017 10:34am
Hello i have a 16S bms pro from chargery, maybe stupid question ,I want to use this for a 14S lippo battery-pack. But the balance leads out of the lippo's has one positive an the others are negative(gen-ace).
On the bms is there just the oposite input, one negative and the others are positive ,so this confuses me :shock: Can i just switch and connect?
bionicon   100 W
Re: New BMS model
Post by bionicon » Apr 21 2017 11:45am
Ignore that i ever asked this question :roll:
stupid me :oops:
Inwo   10 kW
Re: New BMS model
Post by Inwo » Jun 10 2017 8:31pm
Received word tonight that new BMS-24 design will be available next week.
No information on pricing.
New model has discrete lcd display for remote mounting using simple rj-45. (my idea :D )
Also Bluetooth app.
Selling bms with support has not been easy.
I ended up supporting those that were not from me. Happy to do it.
Second thoughts on doing another round. Lost money the first time. $50 is not enough margin even for a non-profit.
Any interest or encouragement is appreciated.
It's a great product. Very repairable.
No bms can withstand wiring errors. Only one unexplained failure. Not sold by me fortunatly!
I've been pretty happy with the low cost smart bms. Hoping to try at least one more run of 20 BMS-24 units.
The best thing about these is the personal service and the designer catering to suggestions.
Inwo   10 kW
Re: New BMS model
Post by Inwo » Jun 10 2017 8:32pm
ps,
I have to check, but the mating 24s ac charger may be available at the same time.
ejonesss   10 kW
Re: New BMS model
Post by ejonesss » Jun 11 2017 5:32pm
when and where can we get one it looks very good product?
stuff for Even Newer 4 to 24-cell Battery Management System (BMS)
32 lifepo4 cells 16s2p 40138 green cells √
16s2p 40138 based pack built assembled (building electrical equiv to $2000 eonyx system.*
Inwo   10 kW
Re: New BMS model
Post by Inwo » Jun 11 2017 6:02pm
Chargery promised samples for testing next week.
Inwo   10 kW
Re: New BMS model
Post by Inwo » Jun 11 2017 8:30pm
New charger info:
chargery new charger.gif (16.5 KiB) Viewed 1060 times
sunny70   1 µW
Re: New BMS model
Post by sunny70 » Jun 12 2017 4:11am
Inwo wrote:...
Consider yourself encouraged, Inwo! Looks like a great product from an extremely helpful distributor. I'd order from you in a hearbeat.
Wishing you all the best with this.
