Frame for sale SEKIBIKES Frame 2017
cryzymotor   10 W
Post by cryzymotor » Jan 16 2017 3:57am
Hello Everyone,
SEKIBIKES strong frame version 2017 are ready for sale. The frame is strong and safety enough for high power and high speed ridding.
As it is simillar with motorcycle frame.
Material: Steel (frame=3.1mm thickness, swing arm=7.9mm thickness)
Color: Black or White
Size: 24'', swing arm is availible for 2.35 - 3.0 tyre
Weight: 21kg
Price: 350.0 USD without shipping cost
send out from China, shipping cost need to check for different area(80-140USD)
We also provide the matched BB & chainwheel & crankset, price=45.0USD/set
(For Spring Sale: BB & chainwheel & crankset are free for frame orders before 1st May 2017)
Below frames are for customer before painting and painted.
The complete bike is the frame version 2016 with the controller outside,and frame 2017 with controller inside.
frame
SEKIBIKES frame2017
SELIBIKES Frame2017.jpg (232.95 KiB) Viewed 1056 times
SEKIBIKES frame
frame painted
red colour
white colour
seat post & rear shock support
side cover
swing arm & crankset
cryzymotor   10 W
Re: Frame for sale SEKIBIKES Frame 2017
Post by cryzymotor » Jan 16 2017 4:07am
upload again.
cryzymotor   10 W
Post by cryzymotor » Jan 16 2017 4:44am
complete bike style like below:
atomek1000   100 W
Post by atomek1000 » Jan 16 2017 6:46pm
What max power do you guarantee it can withstand?
cryzymotor   10 W
Post by cryzymotor » Jan 16 2017 9:33pm
Hi Atomek1000,
We do not test what the power the frame can support max, it is difficult to get the exact value.
The motor of the complete bike in the picture is 4kw motor, we ride the bike harf a year, there is not any
structure transformation and dimensional change.
Let show you some details of the frame material.
The box part and seat support are both 3.1mm thickness steel
Swing arm and shock support are both 8.0mm thickness steel
Swing arm and box connected by 10mm roller
Head tube is 5mm thickness steel
All seam welded by argon arc welding
All frame kits total weight is 21kg
The frame strength dare to compare with any simillar frames!
cryzymotor   10 W
Post by cryzymotor » Jan 17 2017 8:12am
All dimensions in below picture.
cryzymotor   10 W
Post by cryzymotor » Jan 17 2017 8:23am
battery space 300*180*120mm.
cryzymotor   10 W
Post by cryzymotor » Jan 18 2017 5:00am
more dimentions.
charge and hole for wires.jpg (159.06 KiB) Viewed 1053 times
swing arm.jpg (150.94 KiB) Viewed 1053 times
swing arm2.jpg (157.53 KiB) Viewed 1053 times
Merlin   1 MW
Post by Merlin » Jan 18 2017 12:04pm
- i wonder that a 68mm BB is enough for a 133mm wide frame. i see your complete bike picture but if i compare to a 140mm qulbix frame there isnt that much space for a normal 68mm BB.
the Pedals would hit the frame. how long are your crank arms?
- 21Kg is the weight of the frame including swingarm, sideplates and so on?
cryzymotor   10 W
Post by cryzymotor » Jan 18 2017 11:54pm
Hi Merlin,
We make 68mm BB and 44mm head tube in order to apply all standard mountain bike kits.
you can add two rings to get 73mm BB easy.
and everyone can buy accessories from bike market.
plz check below picture, there is enough space between frame and crank.
we like to answer all your questions.
cryzymotor   10 W
Post by cryzymotor » Jan 19 2017 12:18am
yes, 21kg including all parts in below picture.
AEM   10 mW
Post by AEM » Jan 19 2017 10:47pm
Where would I buy the Bike Frames?
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jan 19 2017 11:08pm
AEM wrote:Where would I buy the Bike Frames?
isn't it listed in the thread? That is why I wish the MODS would make that standard.
Dan
cryzymotor   10 W
Post by cryzymotor » Jan 20 2017 3:51am
thanks for your questions.
we are the factory in Tianjin China, the frame will be sent out to customers from the factory directly.
the lead time is 15 days from you placing order.
cheers
Hyena   100 GW
Post by Hyena » Jan 20 2017 4:33am
Well the swing arm is a bit different to all the other clones doing the rounds, but making the frame out of 4mm thick steel ?! That must be some mighty fine chinese cheese steel alloy!
21kg, good lord...
www.HyenaElectricBikes.com
liveforphysics   100 GW
Post by liveforphysics » Jan 20 2017 5:39am
Hyena wrote:Well the swing arm is a bit different to all the other clones doing the rounds, but making the frame out of 4mm thick steel ?! That must be some mighty fine chinese cheese steel alloy!
21kg, good lord...
It should at least be extremely durable and perhaps rigid.
4mm may be thicker than most steel frame motorcycle tubing.
cryzymotor   10 W
Post by cryzymotor » Jan 20 2017 7:36am
21kg, good lord...
Hi Hyena(maybe Jay),
thanks for your time!
we do not think about the weight too much once design, the first important is strong enough, and the frame is not for jumpping. For jumpping, off road motorcycle is more better! what do you think?
the complete bike with our frame will be less than 50kg usually.
most of this kind of frame weight around 13kg, those swing arms are made of square tube, ours 21kg, the extra 8kg comes from the swing arm and all other upholder which is all 8mm thick steel.
we think weight is not important for this kind ebikes, so carbon and aluminum is no useful!
Merlin   1 MW
Post by Merlin » Jan 21 2017 3:24pm
Sry to say,
But weight is in any way the (probably) most important part.
... Acceleration
... Efficiency
... Less weight, less power needed, less heat on controller /motor
In your case it's the worst you can do with a swingarm with pure 8mm metal.
The Unsprung mass of a 12kg hub is all ready too much for EVERY bike suspension part.
If you add another 8kg (that's incredible) to your rear suspension....
Man that will bounce even on street over every potholes...
This "skeleton" design is great... And also that you don't need a chain tensioner.
It looks like you have all tools to do it better.
10-12kg is the normal frame weight. Your battery box can be made from 2mm steel easy.
350$ is a killer price (don't know how pricey your shipping is)
But rethink that Europe or America buyers had to pay additional ~20% tax/fees
Now you are in a range of all other diy frames.
If you want to jump in this market, make it light (er) or cheaper or improvements that others don't have....
But with 21kg for just the frame I would wonder if you find a customer.
cryzymotor   10 W
Post by cryzymotor » Jan 23 2017 11:48am
Hi Merlin,
many thanks for your postreply, very great analysis!
i know 3mm thick frame box and 8mm swing arm is heavy than 2mm box and square tube swing arm.
but we still keep our design for safety enough! our first prototype is 2mm steel, we really think it is not strong enough for rider over 80kg weight!
for the price, we also show some discount for big order(>10 pcs per order).
shipping cost need to check for different area(around 100usd).
and thanks again for your suggestion, yes, difference with others is important, we are making the improvement!
regards
macribs   1.21 GW
1.21 GW
Post by macribs » Jan 26 2017 5:10pm
cryzymotor wrote: we do not think about the weight too much once design, the first important is strong enough, and the frame is not for jumpping. For jumpping, off road motorcycle is more better! what do you think?
I most say I like the idea of a rugged hard core frame, build like a tank. Should be really durable even with rough usage. This frame surely stands out from the crowd.
Posting from cellphone so hard to see exactly how the swing arm is made, but for me it looks like swing arm is just made from flat steel, then perforated to save some weight? What did we learn from Boyd Coddington in American Hot Rod? Box it in! Always box it in! 8)
  • 1: Wouldn't a swing arm boxed in design be both lighter, strong and stiffer then single piece flat steel?
  • 2: Could you tell me more of the swing arm design, as I don't really get it using the small cellphone screen. Where is the anchor point of swing arm to the frame, around the bottom bracket? Seems like an interesting choice for nice clean chain line without any chain growth.
cryzymotor   10 W
Post by cryzymotor » Feb 09 2017 2:30am
1.all square tube need to be welded with a motor axle holder, and most tube 2mm thick, we think that is the weak spot.
2.upload more photos, i dont know if it is showing the design clearly, if no, PM me your mail, i will show you more.
cryzymotor   10 W
Post by cryzymotor » Feb 20 2017 12:41am
update more info of our frame.
neptronix   100 GW
Post by neptronix » Feb 20 2017 8:23am
21kg... :lol:
SlowCo   100 kW
Post by SlowCo » Feb 20 2017 1:26pm
The pivot point of the swingarm looks very narrow and flimsy with only a M8 (?) bolt. Also it could be that the stresses off serious off road riding cause flex and strange handling due to the bearingless (?) swingarm-frame connection. But that is just judging from the photo's.
the12be   100 W
Post by the12be » Feb 20 2017 2:10pm
@ cryzymotor that is only 40mm dropout my downhill bike has 50mm dropout or are you saying this is a 48 vott frame ?
my electric enduro frame had 50mm dropout but I needed 80mm dropout to fit a 72vott motor and rotors on .
