Kepler Bottom Bracket Friction Drive For Sale (Finally)
alxpeace   1 µW
Re: Kepler Bottom Bracket Friction Drive For Sale (Finally)
Post by alxpeace » Oct 02 2019 3:04pm
@Kepler, Pm'ed for Kit Order, TY :bigthumb:
Kepler   1 GW
1 GW
Post by Kepler » Oct 13 2019 10:23pm
Hi all.
Just letting you know drive brackets are now back in stock. Please contact me via PM if you are interested in purchasing.
$100 USD plus postage ($20 USD anywhere in the world)
Manual supplied with purchase detailing other required parts and installation.
You will need to purchase separately and suitable outrunner motor, Vesc controller, and battery. There is a guide at the start of this thread to help you understand how the complete drive is put together.
I also have limited quantities of Arduino interfaces and custom button throttles.
An example of the extreme stealth that can be achieved.
Speed controller and interface hidden inside the frame and a single 6S 6000mah Lipo battery hidden in the water bottle.
150 Watts for an hour which is plenty on this type bike.
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
Dumsterdave   100 W
Post by Dumsterdave » Oct 14 2019 4:04pm
Kepler wrote:
Oct 13 2019 10:23pm
Hi all.
so what would be a rough estimate costwise for a complete setup using the exact specs on this bike?
Kepler   1 GW
1 GW
Post by Kepler » Oct 14 2019 5:38pm
The bike is 2018 Trek Domane SL7 Project One. Cost around $6000 USD. Approx $400 USD for the complete electric drive system (not including labour of course :) ).
I decided to use this bike because you have access to the inside the frame through a small removable cover under the water bottle
I am using a modified bracket for the carbon frame. The drive bracket uses the same lower section and pivot mechanism but a custom clamping upper bracket. Its not something I offer as there are so many different carbon frames and the clamp I used was hand built and very specific to this bike. Just showing what can be achieved with this system.
If you want to do something similar with a road bike, find a frame using a bottom bracket with screw in bearing cups. (these are becoming popular again) Also road bike manufacturers are starting to offer in frame storage solutions which will be perfect for this drive. Check out the 2020 Trek Domane bikes.
Current Rides
cheapcookie   100 W
Post by cheapcookie » Oct 16 2019 5:19pm
hey kepler, coulndt the motor be permanently in contact with the tyre. lets say if you ran out of juice or wanted to pedal without boost you could decouple it. that would allow for tesla style piloting?
Kepler   1 GW
1 GW
Post by Kepler » Oct 16 2019 7:13pm
You could lock it up if you wanted to by removing the shim washer in the pivot mech. You could then lock it on the tire when you wanted and unlock it off the tire should you run out of batteries.
I do run a permanent contact setup with my mountain bike which has some advantages.(Thread on that bike here viewtopic.php?f=28&t=96581). Firstly it will work in wet weather providing you keep the Watt limit quite low (around 200W) and secondly you can set up the drive for regen if you want to. Regen works really well with a Vesc controller and makes a lot of sense on a mountain bike as you are typically spending quite a bit of time going down hill.
On a road bike, it makes more sense to have the drive decouple when not required so you get the most out the natural pedaling efficiency of a light weight road bike.
Certainly the option is there to use both methods.
I am glad you mentioned this as it is feature I haven't documented with this drive.
Current Rides
thierrylah   1 µW
Post by thierrylah » Oct 26 2019 5:48pm
Hi Kepler,
I would love to buy a bracket as soon as it is available.
Thierry
juicy77   10 µW
10 µW
Post by juicy77 » Nov 12 2019 8:35am
Kepler wrote:
Oct 16 2019 7:13pm
Hi ive pmed with regards to the updated bracket design and implementing regen on my old kit. Thanks!
guyrandom1   1 µW
Post by guyrandom1 » Nov 14 2019 5:56am
I've ordered the drive kit and am piecing together the rest of the parts.
What's the latest recommendation on the controller? I was looking at the Vesp-x but have been unable to find. It looks like it is now rebranded as Enertion FocBox, but I am only finding the Unity variant that is listed at $300.
Thanks in advance for any help.
Pranav.ptl   1 mW
Post by Pranav.ptl » Nov 15 2019 9:57am
Kepler wrote:
Oct 13 2019 10:23pm
Hi all.
Hi could you please pm me details as well.. been on the fence forever and am finally ready to get it. Cheers
Kepler   1 GW
1 GW
Post by Kepler » Nov 16 2019 2:09am
PM sent.
Current Rides
frenchie   10 mW
Post by frenchie » Jan 02 2020 12:32pm
Wow that's looks clever! And the Domane is pretty cool too :D
Please PM me info on your kit and what other stuff I need....
Thanks!
tcss000   1 µW
Post by tcss000 » Jan 19 2020 3:53am
Researching on the best way to build my friction drive, and Kepler is awsome! Seriously considering Kepler brackets.
But a question if u dont mind pls? (is it ok to post questions here?)
Im quite familiar with ebike / escooter controllers. Been using them for few good years. But why do you guys recommend this drone controller (VESC) ? Any particular advantages over regular chinese ebike controllers? I see that this recommended Flipsky vesc4 cost considerable more then a 36v ebike controller ....
Thanks!
Ecyclist   1 kW
Post by Ecyclist » Jan 19 2020 11:22pm
tcss000 wrote:
Jan 19 2020 3:53am
Thanks!
1) VESC it's not a drone controller, how did you get that? VESC was originally designed for skateboards.
2) VESC is small and can be programmed to do much more than just control motor.
3) VESC 4.12 can handle up to 60k erpm and VESC 6 150k erpm.
If you want to know more check the esk8 forum.
www.electric-skateboard.builders
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
JiggityJoe   10 mW
Post by JiggityJoe » May 26 2020 8:03pm
Hey Kepler,
I'm interested in purchasing a bracket for my gravel bike, and was also wondering if you're providing anymore kits with programmed VESC, Arduino, and throttle etc.
Thanks,
Joe
ahagge   10 µW
10 µW
Post by ahagge » Jul 13 2020 6:57pm
@Kepler,
Any suggestions on what to do when the motor just doesn't seem to have enough "oomph" to kick up to the tire when its resting spot is off of the tire? I've tried adjusting the gravity spring to get the motor as close as I can to the tire, but it just doesn't seem to want to kick up into a driving position when I apply power. I'm using a 63mm outrunner that's pretty heavy (almost 700g). I went big because I'd read that the larger diameter motors tend to run cooler, and I'm a clydesdale. :oops:
Do you think a motor with a 50mm can size might kick up better? Or perhaps a shorter 63mm unit like [urlhttps://hobbyking.com/en_us/turnigy-aerodrive-sk3-6354-260kv-brushless-outrunner-motor.html]the one you recommend in your documentation[/url]?a BTW that one calls for an 8s-10s battery - does it work OK on a 6s pack?
Kepler   1 GW
1 GW
Post by Kepler » Jul 13 2020 10:13pm
There are 3 possible reasons for this.
1 > Your speed controller is ramping throttle too slowly.
2 > You are not applying enough power. (Needs to be above 100W)
3 > The most likely reason is that you have not got the correct geometry setup on the drive. Please refer to the picture below.
In the engaged position, draw a line through the bracket pivot point, the centre of the motor, and wheel axle. The centre of the motor should sit just below this line. If you send me a side on picture of your bike with the drive fitted, I will be able to confirm if the geometry is correct.
Current Rides
Halfwaythere   1 µW
Post by Halfwaythere » Jul 20 2020 6:43pm
Hi John,
I would love one of your its on my folding bike is there any way this can be made a reality love your work.
I am new to the scene so may be a bit late hope you still have this available :)
Thanks in advance.
Milan
Kepler   1 GW
1 GW
Post by Kepler » Jul 20 2020 7:22pm
I have standard drive brackets available however the design may not suit a folding bike due to the typical distances between the bottom bracket and the face of the tire. The drive is adjustable from 60mm to 110mm. The drawing in the previous post shows the drive set to 80mm.
However the bracket lends itself to be be adapted to a custom bracket that suits your bike as the main mounting plate is in two halves.
Below is a concept on how to mount the drive on a bike using the kickstand space between the bottom bracket and the tire. To be clear I don't make a kickstand mount, just showing an example of how the mount can easily be customized.
Current Rides
Halfwaythere   1 µW
Post by Halfwaythere » Jul 21 2020 3:37am
Hi John,
Thanks for the reply I am not very technical and looking for a whole system to purchase, so you only sell brackets at the moment is that correct?
Happy to pay whatever it is am in Melbourne and the closest thing I have found to this is Hidden Power but I like yours better :p
Anyway let me know if it may be at all possible to get something made up I am in Blackburn which is not far from you I believe :)
Milan
yoyoman   1 kW
Post by yoyoman » Jul 22 2020 6:49pm
I also have a folding bike. Thank you for that mockup of a kickstand mount. Do you think a steel corner bracket would be stiff enough to mount the drive bracket?
everbilt-corner-braces-20487-64_1000 (1).jpg (11.99 KiB) Viewed 966 times
Kepler   1 GW
1 GW
Post by Kepler » Aug 09 2020 2:50am
Sorry, I missed your post. Yes I am sure that bracket would be plenty stiff enough. Looks like a good off the shelf solution.
Current Rides
hb800   1 µW
Post by hb800 » Oct 01 2020 8:42pm
Hi Kepler,
I've just heard about your stunning friction drive mounts and would like to purchase one if possible.
Based on your latest suggestions, its planed to be mounted on the kickstand mounting platform with a kickstand counter plate like this: https://www.hebie.de/en/parking/stand-a ... ter-plate/ a probably custom-­built threaded block and an adjustable mounting bracket with 2 long holes, like shown in your latest picture. If one of the hole spacings (22 / 25 / 30 mm) should match, the Ganter Norm GN 828 Bearing block https://www.ganternorm.com/en/products/ ... ews-GN-827 could also be a convenient solution.
Referring to the adjustable brackets: are these also included or would it be possible to purchase them seperately?
Thanks!
nomo81   1 mW
Post by nomo81 » Oct 02 2020 2:01am
Got one for sale if interessted
viewtopic.php?f=9&t=107749
Thanks
alexvolta   1 µW
Post by alexvolta » Oct 20 2020 3:29pm
Hi Kepler!
I just recently discovered your very well designed friction drive, and I am trying to get my hands on one.
Are there any left from the last batch? If not, is a new batch coming?
Thanks!
