N.E.S.E. the no solder module
elhnad   100 µW
100 µW
Re: N.E.S.E. the no solder module
Post by elhnad » Dec 03 2019 12:31am
if i want a 10s8p bike pack is it as simple as getting,
10 of these 8p module kits?
https://18650.lt/index.php/product/n-e- ... e=standard
my gut tells me im missing some stuff.
there's nobody in the US distributing these for you is there?
agniusm   10 MW
Post by agniusm » Dec 03 2019 1:07am
elhnad wrote:
Dec 03 2019 12:31am
Yes, that's what you need. You could get 9 of the series bus bars to connect it all up. I also have ring terminals, power connectors, bolt caps.
There is no distribution in US but my shipping prices are just a few dollars higher than local US prices.
tomjasz   10 GW
10 GW
Post by tomjasz » Dec 03 2019 5:41am
Fair shipping, typically 20% or more off bike-discount.de and their ilk shipping costs.
To many businesses bury added profit in shipping. Yup it all has a price but it’s the disingenuous “lowest price” offers I find frustrating. No problem here!
mxs   10 W
Re: N.E.S.E. the no solder module 20% OFF WINTER SALE
Post by mxs » Dec 13 2019 2:14pm
I don't see a series connect Amp rating on the website. Somewhere I read that it's 50A per P module ... but it didn't say how many P configuration??
agniusm   10 MW
Post by agniusm » Dec 14 2019 6:47am
mxs wrote:
Dec 13 2019 2:14pm
You can draw max rating of the cell from NESE. If the cell is 20A max you can draw 160A from 8P or 60A from 3P module.
You can double that by paralleling 2 modules, e.g. 2 8P modules for 320A.
Most cell datasheets would tell you continues current of the cell but you have to validate that against temperature rise so it does not exeed safe limits and stays bellow 60C
mxs   10 W
Post by mxs » Dec 17 2019 9:48am
I get the cell current limitation .... But isn't the series connection/joint have its own limits from design/material stand point? The way you are describing is that the only limit is the cell rating itself??
agniusm   10 MW
Post by agniusm » Dec 17 2019 1:02pm
mxs wrote:
Dec 17 2019 9:48am
You can always double or tripple up series connections. The path is short and conductor is 1mm copper. It will be better than any quadrupled spotwelded nickel connections
john61ct   100 GW
Post by john61ct » Dec 17 2019 1:11pm
1mm is 18AWG
the ampacity rating of different gauges is easy to look up
agniusm   10 MW
Post by agniusm » Dec 17 2019 1:14pm
Its a bus bar so different to a wire. By the calculator i have it can handle 78A to 60C. V drop 0.034V. As mentioned you can double up or use thicker DIY bus bar
mxs   10 W
Post by mxs » Dec 17 2019 4:16pm
Got it, thanks.
Stormsorter   1 µW
Post by Stormsorter » Dec 24 2019 6:39pm
Thanks for making the STL files public especially since my winter grocery getter trike was stolen the day before my batteries were delivered. I had planned on building my first electric slowly with a mtb frame I already had or maybe find something easier along the way but I am now forced to rush the build and buy an overpriced cargo bike to replace my trike for now.
Now on to my question. I am building a 16s6p pack for a cyclone 3000watt with its stock 40amp controller and I have some 8x0.3mm nickel plated copper strip. Should I double up the strips so its 0.6mm thick or would the 0.3mm be fine? Also how thick should I make the series connectors? I have some 0.5mm bare copper I can make them from.
agniusm   10 MW
Post by agniusm » Dec 28 2019 9:04am
Stormsorter wrote:
Dec 24 2019 6:39pm
Modules are made to be used with custom tabs i make. The tabs are 1.2mm thick as they have pressed bumps in them. You probably could so something with flat tabs and button head cells, but you will still need foam for compression. I have separate tabs for sale and they are not that expensive if purchased alone, without bolts and series bus bars. Certainly will be cheaper and easier than trying something DIY. €82.26 total with shipping and if you quick, you can knock off another 20% off of it till first of January
agniusm   10 MW
Post by agniusm » Dec 31 2019 7:38am
Hey. Happy New Year everyone! I would like to thank everyone for support, criticism and your hard earned money spent on my products. Its been a good ride this year and i am looking forward to the coming. I wish You lots of creativity, success in your hobby, happiness, good health and wealth for your close ones and friends. HAPPY NEW YEARS. Agnius
P.S. Promotion code 'WINTERSALE2020' will still be valid to 00:00 2020.01.01. You can still make it when you sober up :smiley:
Hickbeard   100 W
Post by Hickbeard » Feb 06 2020 8:12am
@agniusm
Finally building my battery. Cheers bud.
Would you out the poron backed tabs on the positive or negative?
Sent from my CLT-L09 using Tapatalk
agniusm   10 MW
Post by agniusm » Feb 06 2020 9:00am
Great. Does not matter but i usually put neg on the poron side.
When did you got the kit and what batyery are you building? I cant refference your purchase to your nicknae :D.
Latest modules have +/- near terminals
Hickbeard   100 W
Post by Hickbeard » Feb 06 2020 9:59am
14s5p.
I printed the modules and just bought the tab set and insulator discs.
I under ordered so had to order 1 more tab set.
To the uk
Hickbeard   100 W
Post by Hickbeard » Feb 07 2020 8:03am
These cell holders are brilliant.
I would definitely reccomend considering these as a viable option.
As there is no spot welding involved you can switch out the number of cells you want anytime.
I would actually reccomend considering printing/buying 8p regardless of size. That way you can change your config anywhere from 1p to 8p. 1s to 100s if you want. Wish I'd done that now.
I might print 14 more 5p ones so I can run 14s10p. Don't know.
But yeah anyone considering these. Customer service is helpful, friendly and quick. The products are top notch.
Cheers bud. Image
john61ct   100 GW
Post by john61ct » Feb 07 2020 10:21am
I would be interested in a design **not** connecting the cells at all to each other within a module,
4/5 or 6-cell modules, so each can be kept under the TSA 100Wh limit for air travel with lithium (ref Grin LiGo packs)
No power leads, just bringing out a pair of #16 AWG wires per each cell, isolated from each other.
Where waterproofing is possible, accommodating incorporating a flat round spot with enough free space inside behind it, to insert a receptacle for 8/10/12 plugs, e.g. TE/Deutsch DT or DTM series.
Then different xPyS layouts can be accommodated in separate junction boxes, also allowing each module set of cells to be checked / charged / tested independently
or swapping out a 12V portable pack e.g. to run a dinghy, then merging back into the 48V propulsion or House / mothership bank upon return.
Or switching from 12V to 24V when winching is required, etc.
agniusm   10 MW
Post by agniusm » Feb 07 2020 11:27am
Most 18650 cells connected in parallel on largest 8P modules falls under 100wh limit ;)
john61ct   100 GW
Post by john61ct » Feb 07 2020 11:36am
Yes but that's just one issue
Hard-wiring the parallel connections is less flexible than what I'm proposing.
can't rewire to a different layout just by swapping Jboxen
have to atomize the pack to check the cells individually, etc
agniusm   10 MW
Post by agniusm » Feb 08 2020 8:50am
john61ct wrote:
Feb 07 2020 11:36am
I dont know what that means. Its not about flexibility but rather simplicity. I had many 1st timers building batteries without any issues, faster than pros welding packs.
Usually when you build a battery, you build it for purpose, you dont need to rewire it. You can change layout to 2 more different ones and its easy enough to do.
Just by checking your pack voltages will give you an idea if there is a problem. Cell count is not that large and it would go out of balance noticeably.
john61ct   100 GW
Post by john61ct » Feb 08 2020 9:22am
agniusm wrote:Its not about flexibility but rather simplicity.
I am not criticizing your existing design for that simplicity use case.
I am proposing an alternative approach based on what you have already got, for a different use case oriented around flexibility.
I want a say 6kWh main bank, and to be able to rotate smaller say 500Wh packs or 2kWh packs in and out, same cells comprising many different packs at whatever voltage is needed for a given purpose,
and without needing different chargers for every voltage needed.
Automated balancing charging and capacity testing at the per-cell level as a periodic maintenance routine without opening packs up to remove the cells.
If this idea is not of interest to you that's fine never mind.
agniusm   10 MW
Post by agniusm » Feb 08 2020 9:49am
john61ct wrote:
Feb 08 2020 9:22am
Sorry, but are trying to just frock arround? Show me a single pack with per cell based monitoring? 5kWh is 400+ cells and you are proposing to somehow wire this all for what reason? No one is a maniac like this. No one needs per cell monitoring. You need to monitor each parallel group. BMS does that and balance charges cells.
Surely i am not interested in making something useless like this.
john61ct   100 GW
Post by john61ct » Feb 08 2020 1:38pm
OK thanks for stating so clearly.
I was not talking about monitoring per-cell while in use as with a BMS. But never mind. . .
agniusm   10 MW
Post by agniusm » Feb 25 2020 4:02am
Off-topic. Building this 7S3P battery for my 2 year old son, pedal car conversion. Using car wiper motor and some other cheap electronics of ebay. Most important thing is lights and horn :smiley:
This is why 3D printer is a must for maker of any kind :slight_smile:
