N.E.S.E. the no solder module
agniusm   100 MW
Re: N.E.S.E. the no solder module
Post by agniusm » May 06 2021 2:52am
Ham wrote:
May 06 2021 2:10am
Hi All,
quick question regarding dimensions if I may:
The 5p 21700 module is listed as 119.4 tall. Is that the full length including terminals or just the length of the housing?
Thanks
Its for housing only. I have different screws to go with it so it made more sense to list them separately. Check here: https://18650.lt/index.php/resources/
Ham   1 kW
Post by Ham » May 06 2021 3:15am
Thank you for such a fast response
http://www.HamsFitness.com Strength, Conditioning & Diet
http://www.zeusrides.com my builds current and past
Dak77   100 W
Post by Dak77 » May 15 2021 1:04am
Has anyone had experience with the 21700 NESE modules fitted with Samsung 50E ? I don't have a dial caliper to measure mine, but I suspect they're just slightly too long to fit without damaging the module and cover. I suppose it's possible that my cells are fakes, but the wrapper and positive end look identical to every picture I've seen of them.
PRW   10 kW
Post by PRW » Aug 02 2021 11:09pm
just thinking...
are there any restrictions (other than difficulty of access and the need to ensure safety from shorting onto the frame, etc) to building a pack in stages within the confines of the frame? One of the big constraints of the Phasor is the limited access size and shape. I realise zip tying the pack together and wiring up the bms may be difficult.
john61ct   100 GW
Post by john61ct » Aug 03 2021 11:11pm
Batteries are consumables
need regular inspection testing maintenance.
Ideally you can easily remove and replace as needed.
PRW   10 kW
Post by PRW » Aug 04 2021 5:40am
john61ct wrote:
Aug 03 2021 11:11pm
true
john61ct   100 GW
Post by john61ct » Aug 04 2021 1:30pm
If you built a pack that fit with protective padding / shell, sliding sideways into that triangular cutout, then dropping down to get fixed in place, looks like there would then be room to fit and attach electronics in the protected space above the pack
TorontoBuilder   100 W
Post by TorontoBuilder » Sep 03 2021 3:51pm
spuzzete wrote:
Feb 12 2021 8:31pm
agniusm wrote:
Feb 11 2021 2:23am
Thank you for the photos.
0.3mm probably shaved off a lot of printing time :)
If it works, its all good
p.s. i love the machine, like its built on wood board, reused PC PSU and still gets job done. I love the philosophy of reuse, repurpose, rebuild
No worries :D .
Yes, at 0.3mm it saves time. It took about 2.5hrs for the base and 1.5hrs for the lid. I used my own settings mainly because they're optimized for PETG (almost no stringing). My printer is very "primitive" compared to the newer ones but hey, it works well enough for my needs, I don't need to buy a new one yet 8)
Damn I was hoping that I could print off the parts faster than that because the Toronto Public Library limits the use of their 3d printers to 2hr time slots only.
What is the cheapest 3d printer I wonder...
agniusm   100 MW
Post by agniusm » Sep 04 2021 9:18am
TorontoBuilder wrote:
Sep 03 2021 3:51pm
Ender 3 v2 is probably your best bet. They are so cheap and you probably could pick one up locally
Post by TorontoBuilder » Sep 04 2021 1:15pm
agniusm wrote:
Sep 04 2021 9:18am
Sep 03 2021 3:51pm
Thank you very much sir. I checked out the Creality products pricing yesterday. Not only do I think I can afford an Ender 3 Max, I may have space in the house for one... if I sell something else to make room.
I know I have a number of parts I'd far prefer to 3D print rather than manually machine in the shop, and I really want to use your 26650 modules since I am nervous to have my wife use anything other than LFP cells.
agniusm   100 MW
Post by agniusm » Sep 05 2021 12:47am
Sep 04 2021 1:15pm
agniusm wrote:
Sep 04 2021 9:18am
Sep 03 2021 3:51pm
If you are not intending to print large parts, stick with a smaller printer. Leveling large bed is a big task and it warps more plus it heats up slower. Bigger is not always better
999zip999   100 GW
Post by 999zip999 » Sep 05 2021 11:30am
This printer is only $200 free shipping most the time I see it for $300 .
CREALITY Ender 3 Ender 3 Max Ende 3V2 3D Printer 220X220X250mm 1.75mm PLA US
$199.99/eaFree Shipping
Est. Delivery Fri, Sep 10 - Tue, Sep 14
Is this real ?
agniusm   100 MW
Post by agniusm » Sep 05 2021 2:32pm
999zip999 wrote:
Sep 05 2021 11:30am
Is this real ?
Sounds real to me. I picked one up from ads, basically new for 140€.
agniusm   100 MW
Post by agniusm » Sep 18 2021 2:51am
New filament is out. This is good news. The material is called Nonoilen from Fillamentum. This material is biodegradable, degrades 3x faster than usual PLA, prints same as PLA and is capable of temperatures up to 120C plus is food and dishwasher safe. I have ordered a roll to test it out on NESE modules. Using this, NESE modules would be 100% recyclable.
tylerwatts   100 W
Post by tylerwatts » Sep 19 2021 9:45am
agniusm wrote:New filament is out. This is good news. The material is called Nonoilen from Fillamentum. This material is biodegradable, degrades 3x faster than usual PLA, prints same as PLA and is capable of temperatures up to 120C plus is food and dishwasher safe. I have ordered a roll to test it out on NESE modules. Using this, NESE modules would be 100% recyclable.
Sounds interesting, what is the degradation rate of it? How long would your modules last before losing strength and needing to be replaced?
I ask because the beauty of your system is they can be recycled and reconfigured easily. So why would you want to dispose of them in any hurry? Plus you should be able to recycle PLA right?
cheers
Tyler
agniusm   100 MW
Post by agniusm » Sep 19 2021 11:25am
tylerwatts wrote:
Sep 19 2021 9:45am
cheers
Tyler
I think its same as wood. It could last forever but put it into composter and it will be gone in a year or 2.
Fillamentum states that it decomposes in a year in soil, 90 days in home composter.
It will last if its enclosed but at the same time decompose if its thrown away. It does not produce microparticles when decomposing.
agniusm   100 MW
Post by agniusm » Oct 01 2021 7:15am
Prototyping 12V 7A VRLA replacement with lifepo4. Fully integrated with no wires. Looks promising. 2000 cycles vs 200. 20A continues. For UPS battery replacements.
john61ct   100 GW
Post by john61ct » Oct 01 2021 12:18pm
link to that board?
agniusm   100 MW
Post by agniusm » Oct 01 2021 12:33pm
john61ct wrote:
Oct 01 2021 12:18pm
link to that board?
Dont have one, just search L04S25-201
agniusm   100 MW
Post by agniusm » Nov 07 2021 12:13pm
Series busbars are coming and will be available shortly, 1 to 2 weeks
john61ct   100 GW
Post by john61ct » Nov 07 2021 1:14pm
Do you mean within the single module?
Or just series connecting modules together?
agniusm   100 MW
Post by agniusm » Nov 08 2021 10:42am
john61ct wrote:
Nov 07 2021 1:14pm
I see you post a lot, over 7 posts a day and share your expertise a lot.
Would you care to link me to some of your whatever builds you documented on ES?
tomjasz   10 GW
Post by tomjasz » Nov 08 2021 9:01pm
agniusm wrote:
Nov 08 2021 10:42am
Hmmm suddenly very quiet...
agniusm   100 MW
Post by agniusm » Nov 09 2021 8:23am
Finished my demo 12v LiFePO4 battery. This is for UPS battery replacement.
Smaller and with couple thousand cycles.
Posting just to show how one can utilise pcb's with my modules to integrate bms systems.
spinningmagnets   100 GW
Post by spinningmagnets » Nov 09 2021 9:50am
This is brilliant.
I have also seen children's plastic riding vehicles that typically use two SLA batteries (of this size) in series for 24V, which is easily swapped for 7S Li-Ion.
I believe there is also a market for 5S Li-Ion as a run-time extender for 18V cordless tools.
