thepronghorn wrote: ↑Jul 26 2020 8:35pm
What is the recommended nozzle size for printing your modules?
I really like the design. As intended, with all of the structure provided by 3d printed parts, it takes a lot of filament and printing time. One idea I have to reduce the amount of printing time is to just use 3d printed cell spacers/endcaps (example pictured below) to hold the cells and copper strips. The endcaps would be clamped together with end plates and threaded spacers. This goes back more towards the original snath design.
It could still use your very nice nickel coated predimpled copper strips and the clever top termination design with the inset nut (which I haven't modeled yet).
What do you think of this design? I can also move this discussion out of your sales thread if you'd like.
Hi. I would appreciate if you could move to a separate thread. I will share my input when i can.
If you would search my threads, there was one for developement of the no solder/weld system. Initially i was thinking making something what you are proposing. But there are couple of things.
Replacement of a bad cell would be more complicated as you would need to disassemble more.
You cant set how much you want to compress the foam unless you machine spacers and that adds cost and weight.
Modules would be larger in volume.
Its a bit fiddly to fit top unless your cells ar perfectly strait, i had to lasercut fishpaper so they would allign better and i could fit top lid.
I am not discouraging you, just sharing experiences i had on my jorney and ehy i chose this over that. I would like to see if something comes out of your thinking.
BTW, 3d printing takes long time, but its not manual, 1kg of plastic will make you 14 6P modules probably more with V2. By the time your ordered hardware will arrive, you can print average size battery.
My modules being rectangular boxes are still possible to arrange in 3 or more ways so you can still choose which fits better, say 20s could be arrange in: 2 rows of 10 or 4 rows of 5 or 5 rows of 4 or 20 rows of 1.
Then ther is simplicity. I had many firs time battery builder that told me it was very easy to make a battery.
I print with 0.4 nozzle, people tried courser and 0.6 was marginally ok, higher and it would miss important details
