Swingarm Drive for Qulbix 76R & 140R
LightningRods   10 MW
Post by LightningRods » Jun 30 2017 6:12pm
My swingarm drive for the Qulbix 76R and 140R is now available. It's designed to fit the 165mm dropout width Qulbix swingarm on both models.
This drive requires a left side drive #219 kart sprocket. I'm also producing billet aluminum hubs that allow fitment of the sprocket plus disc brake rotor. The hubs have sealed bearings and a solid 12mm 4140 axle. Thick 36 hole spoke flanges. The current design has the left side threaded for a 1.375" x 24 tpi freewheel. The standard left side sprocket is a 96 tooth. Combined with a 12t motor sprocket this creates an 8:1 reduction to the rear wheel.
The last part required for the drive system is an offset brake caliper mount. It replaces the standard Qulbix mount that attaches inside of the swingarm. Milled from aluminum billet.
PRICE LIST
Swingarm Drive including L-R Big Block motor, mounting brackets and hardware, 219 driver sprocket, alloy sprocket guard, front chain tensioner. $495
Billet aluminum 165mm rear hub with sealed bearings and 12mm 4140 axle. $275
96 tooth stainless steel #219 sprocket, 6 bolt disc pattern. $50
Billet aluminum disc brake caliper mount. $50
The Big Block will run all day at 3000 watts. Blasts of 6000-7000 watts provide light motorcycle performance. Weight of the complete drive is approximately 12 lbs.
Please PM me if interested.
Thanks,
Mike
aka Lightning Rods
"I don’t mind that they stole my idea, I mind that they don’t have any of their own.”
-Nikola Tesla
Lightning Rods Web Site http://www.lightningrodev.com
Lightning Rods Facebook Page https://www.facebook.com/pages/Lightnin ... 4531978401
John Bozi   1 MW
Re: Swingarm Drive for Qulbix 76R & 140R
Post by John Bozi » Jun 30 2017 6:45pm
Sensational Mike.
That is a decent price for those after more sprung higher powered options mated to a proven frame.
I look forward to the reviews guys!
BCTECH   100 W
Post by BCTECH » Jun 30 2017 9:27pm
Will this kit fit both 76r and 140r?
Mammalian04   100 kW
Post by Mammalian04 » Jun 30 2017 11:17pm
BCTECH wrote:Will this kit fit both 76r and 140r?
Yep, my swingarms on my Q76 and 140 are interchangable.
Luk   100 mW
Post by Luk » Jul 01 2017 2:24am
Hello Mike
PM send
Luk-ebike.fr
redline2097   100 W
Post by redline2097 » Jul 02 2017 4:46am
Can it be fitted anyhow to 165 frame?
spektrolyte   10 W
Post by spektrolyte » Jul 02 2017 6:38am
Dammit! My 76 arrived on Friday with a 155mm swingarm...
Luk   100 mW
Post by Luk » Jul 02 2017 4:08pm
You can remove the 155mm swingarm by 5mm on each size .
165mm swingarm is the original size ;
Caliper is not parallel on 155mm swingarm .
Caliper is right on 165mm swingarm .
155mm swingarm is a 165mm tighten .
Luk-ebike.fr
devo1223   100 W
Post by devo1223 » Jul 18 2017 12:09pm
On the pedal side, can a 5 speed freewheel fit or only a single speed?
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
Luk   100 mW
Post by Luk » Jul 18 2017 2:54pm
A standard 10 speed freewheel fit, i think .
Luk-ebike.fr
Amiran   10 W
Post by Amiran » Aug 06 2017 5:36am
Hi mate,
Would you be interested to sell the swingawrm, how much shipped to UK?
skyungjae   10 kW
Post by skyungjae » May 08 2018 12:22pm
I'm so tempted to upgrade my Risun Clonebix. :twisted:
¯\_(ツ)_/¯
2005 Jamis Dakar build thread: http://endless-sphere.com/forums/viewto ... 27#p972546
2005 Kona Stink-E build thread: http://endless-sphere.com/forums/viewto ... 64#p690597
