[AUSTRALIA] Sur-Ron Light Bee / Fire Fly - Mid drive ebike
beefcake_ground pigeon   1 mW
Re: [AUSTRALIA] Sur-Ron Light Bee / Fire Fly - Mid drive ebike
Post by beefcake_ground pigeon » Apr 17 2018 5:30am
stuff I found ? 230ml 5wt fork oil????
Post by beefcake_ground pigeon » Apr 17 2018 5:31am
Post by beefcake_ground pigeon » Apr 17 2018 5:43am
close haven't found much better yet different model would love a cad file img
MontyRep   100 µW
100 µW
Post by MontyRep » Apr 21 2018 3:36am
What’s the better suspension - Fastace or RST ?? Your thoughts ?
Aebrennan   100 W
Post by Aebrennan » Apr 21 2018 5:24am
I finally received a reply from Fastace direct.
There is no rebuild manual in english available for this particular fork, so i have requested a manual for the closest product they have. I hope to receive this in the next few days.
Fastace is currently working at the Sur-ron factory trying to resolve fork issues, though im not sure if its the air or spring they are working on.
Sur-ron is now working with DNM and fitting the USD-8S as a fork option along with the RST KILLAH and the spring version of the Fastace ALX13RC.
I personally am not a fan of any DNM products, and will not order any unless customers request them.
My preference is Fastace (with a heavier spring) but I would prefer the RST over DNM , and i have requested if Black is an option. (LMX use a black version of the KILLAH)
The next order is in the process so anyone interested in special spec builds please advise asap. Pre-order cut off will be April 30, shipment ETA late May.
Post by beefcake_ground pigeon » Apr 21 2018 6:15am
so it is the alx13rc model no. not akx01rc model forks they were talking about on other page , be good having that cleared , my bad they both look very similar be good for more info been looking round the net
fast ace forks so far handling well punishment tests passed no blowen seals yet!! multiple dh tracks rips!!!🙃
Aebrennan   100 W
Post by Aebrennan » Apr 23 2018 4:53am
I finally received some info from Fastace.
The forks should be labelled on the lower left leg ALX13RC
The left fork holds 150ml, the right fork holds 300ml. Fork spring rate is 38lbs/in.
I am waiting to hear back regarding oil weight and possibility of purchasing heavier springs.
I personally would run 5wt fork oil, there is a good chance they only use vegetable oil from the factory like DNM.
I intend to send a set of forks to Shock treatment for evaluation, and see if we should continue with the Fastace fork as a standard part.
Post by beefcake_ground pigeon » Apr 25 2018 1:39am
be interesting to see what they supply even in Chinese okay engineer pdf drawings cad etc,, would be awesome to see, 2 different fork oil volumes I assume 2 different circuits,?? both our bikes the right fork leg feels like spring loaded but left leg feels like a massive shock oil damping??
anyone else noticed this with fast ace front wheel off?
I thought they should be identical leg setup for axle to side leg frame dual loading and hub twist loadings etc..?
Unless pre design one leg hub systems seen a few on mountain bikes but special built to run one leg but still have twist issues, and strength ,
not bading these they do feel solid and rail really nice , handle the big hits wash out ramps etc and look and feel strong enough like breaking won't be the issue, strength looks good
but have noticed lower caps loosen off I assume flex across axial shaft load ?dab of white coolant paste loctite on one thread helps slow this down and not as permenant as thread locker loctite, still putting in back of car!!
need a bag of twist wire she'll be right where's my drill?🙃
info when comes will help many I'm sure.
bet ur a bit busy with these bikes now , congrats, hope u don't mind, had a few people stop and ask so I gave them ur web info too😀😀
racingame   100 W
Post by racingame » Apr 26 2018 10:04pm
I don't know if I can ask it here, but anyone knows what rear suspension is the heavier optional one (450lbs)? I know the one mounted by default is a Fastace BDA53RC, but I was curious to look into the other one as well.
Aebrennan   100 W
Post by Aebrennan » Apr 27 2018 5:50pm
The optional rear is a 450lb spring for the same Fastace shock.
We can offer you the spring as a spare part, or do an exchange on the complete shock absorber from new.
Aebrennan   100 W
Post by Aebrennan » Apr 27 2018 10:21pm
Latest stock update
We currently only have 1 New Light Bee left in stock!
It is a Grey frame and has Fastace forks.
This bike can be purchased for $4250 as 48V or $4750 as 60V.
The bike has been unpacked and assembled but never ridden.
It has been shown for display purposes only and currently has a Supermoto wheelset fitted. Can be sold with the off-road wheelset fitted.
Preferred collection from Sydney, but we can arrange a bike transport company to get it wherever you may want it.
We expect to be re-stocked with bikes late May.
We also have ex-demo bikes for sale. These have low kms and have been used as test ride bikes. PM for details.
MontyRep   100 µW
100 µW
Post by MontyRep » Apr 28 2018 7:15pm
Hi guys anyone in Brisbane have a bike I could have a look at ? Would like to see one in the flesh before ordering one. Thanks.
Aebrennan   100 W
Post by Aebrennan » Apr 29 2018 3:00pm
MontyRep wrote:
Apr 28 2018 7:15pm
Come down to Sydney, you can see the bikes in the flesh, test ride and then take the bike home?
Otherwise try send Nic (beefcake ground pigeon) a PM he is in Brisbane
Post by beefcake_ground pigeon » Apr 29 2018 5:39pm
montyrep u name the place I'll throw it in the car and come see u, 5k deposit for a test ride🙃 I watched hyenas vid 😭😭😂😂😭😭🙃🙃😀❤️❤️🙈
I am near the city on the Southside free most days
Rodney64   1 MW
Post by Rodney64 » Apr 30 2018 4:34am
My Sur Ron has just arrived in Perth if anyone wants to have a ride.
MontyRep   100 µW
100 µW
Post by MontyRep » May 01 2018 4:24am
beefcake_ground pigeon wrote:
Apr 29 2018 5:39pm
Hi beefcake
Thanks for the reply. I’m south side as well.
Can meet you at your usual ride area if that helps. Are you going for a ride over the weekend ? You mentioned my gravattt which is close to home. Thanks
Post by beefcake_ground pigeon » May 07 2018 9:13pm
not sure if u got my pm montyrep think sent twice, if u want to organise a meet email me at elnic1415@gmail.com burner email so won't be up for more than a few months, but if u or any others in brisbane want a look send email with ph number will call u and organise time and place,
Aebrennan   100 W
Post by Aebrennan » May 13 2018 3:58pm
Thanks for all the support from you happy owners.
It’s great to hear the positive feedback from our customers and willingness to show and share information regarding such a new and exciting product.
The next shipment of bikes will be built this week and shipping out on the 20th May.
We still have bikes available so if interested please PM through this site or email through the contact page on aebikes.com.au to secure a bike from this coming shipment.
We will also have a limited number of the factory produced sine wave controller, promising a 20% power increase, get in touch for pre-orders.
Please note from July 1st we will need to register for GST so prices will increase.
Rube   100 W
Post by Rube » May 14 2018 5:56am
Hi Abrennan, any chance of registration compliance? If that is on your horizon send me a pm. I may be able to assist.
nethern   1 mW
Post by nethern » Jun 03 2018 4:48am
Can this bike be used as trial bike? How s the power delivery? Does it come with sinwave controller?
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Jun 03 2018 5:28am
nethern wrote:
Jun 03 2018 4:48am
yes yes and yes..
Sur-ron is developing upgrade kits and components such as FOC sinwave controllers , electric power systems for upgrade and diy projects and modular body style kits (in conjunction with Eve bikes france) and components to transform light bee into different bike forms and functions such as trials, mx enduro, street, bobber, cafe racer, etc..
https://evnerds.com/electric-vehicles/e ... in-europe/
https://evnerds.com/electric-vehicles/e ... companies/
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
Aebrennan   100 W
Post by Aebrennan » Jun 03 2018 2:20pm
The bikes can be fitted with the optional 58T rear sprocket which gives much more torque and less top speed similar to a trials bike power delivery.
We have a shipment on its way which includes the new sine wave controllers which I’m guessing is the magic ingredient in the new “ X “ version.
We were advised of a 20% power increase throughout the rpm range, with quieter and smoother delivery.
We should expect a higher top speed with the standard 48T sprocket but the torque of the 58T sprocket.
We will update as soon as possible.
nethern   1 mW
Post by nethern » Jun 03 2018 11:10pm
How will it different from the oset24?
Say if I want to buy a e-trial , future Sur Ron or oset ?
Any idea?
Reason: Replace img from www.trialsbike.com.au reported by member as deceptive site.
