EU - MAC 12T motors in 24" rims
Allex   1 GW
1 GW
Post by Allex » Oct 28 2017 5:34am
Hi guys I have 4 identical motors that was installed on NYX bikes.
These motors only run for about 30km so consider them as brand new.
They have been standing unused for over a year in a shed so you may see some rust on nipples on the inside of the rim.
This is the latest version of MAC with redesigned casing.
Laced in 24" Sun rims with really thick spokes!
They have 12T winding so a slow wind suited for a pack with higher voltage or for slow speeds.
Price new 330USD
https://em3ev.com/shop/mac-kit-36v-fram ... -900w-max/
Asking: 200USD a pop
Shipping within EU - 55USD
Shipping to US and others - 100USD
brumbrum   100 kW
Re: EU - MAC 12T motors in 24" rims
Post by brumbrum » Oct 28 2017 3:38pm
Are these 135mm axle dropout? And do you know how wide the rim is?(inner diameter if possible)
Cheers
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Allex   1 GW
1 GW
Post by Allex » Oct 28 2017 5:03pm
They are 135mm
Inner diamter on rim is 23.4mm
sparkiesweden   10 mW
Post by sparkiesweden » Oct 29 2017 1:58pm
36 or 48V?
Allex   1 GW
1 GW
Post by Allex » Oct 29 2017 2:58pm
There is no such thing as 36/48V
You can use them on 24V or even 100V
Higher voltage gives you higher speed.
sparkiesweden   10 mW
Post by sparkiesweden » Oct 29 2017 3:31pm
True that. Nevermind ... ;-)
Might be in for one or two. Skickar PM
Allex   1 GW
1 GW
Post by Allex » Nov 07 2017 11:53am
3 motors left.
madin88   1 GW
1 GW
Post by madin88 » Nov 07 2017 2:11pm
Allex you should mention that russia guys have pushed this type of Motor to 8kW with forced air cooling 8)
I own an eZee motor which is basically a MAC with less stator width and i'm always surprised about the performance.
The 12T really should be paired with a 100V controller and >20s than it will perform great at very low currents.
Allex   1 GW
1 GW
Post by Allex » Nov 07 2017 4:18pm
Allex   1 GW
1 GW
Post by Allex » Jan 31 2018 5:16am
3 motors left.
Allex   1 GW
1 GW
Post by Allex » Mar 27 2018 3:39am
2 motors left =)
Allex   1 GW
1 GW
Post by Allex » May 21 2018 8:16am
Still 2 brand new left.
spektrolyte   10 W
Post by spektrolyte » Jun 14 2018 6:24pm
Interested, how did they perform in the Nyx? I'm looking for a rear wheel for my Q76 that doesn't weigh 15kg+, I have an 84v battery and a Sabvoton 72150 (until my Adaptto gets fixed). I assume that they will fit in a Raptor with 155mm dropouts. Singlespeed or cassette version?
Allex   1 GW
1 GW
Post by Allex » Jun 15 2018 2:36am
They worked fine, but never liked pushing over 1500W in them...but this is because it is a small motor.
This is a regular screw on freewheel version.
Not sure how wide the NYX swing is, but worst case you need to use some spacers if the q76 is wider.
spektrolyte   10 W
Post by spektrolyte » Jun 15 2018 11:21am
I have never ridden a geared motor, how does performance compare to MXUS 3k, and which controller did you use with it?
Seems my Sabvoton and maybe Adaptto isn't going to work.
Allex   1 GW
1 GW
Post by Allex » Jun 29 2018 8:33am
They were installed with Adaptto, they work but I dont think in optimal way.
You cant really compare them with mxus, as they are much lighter and of course performance is not the same as these motors are 500W nominal and about 2000W peak. While mxus is 3000nominal.
BoomerChomsi   1 kW
Post by BoomerChomsi » Jul 16 2018 8:09am
How many kg's are these motors?
Also are their any gears available for replacement when worn out?
thanks!
Believe and Do
Allex   1 GW
1 GW
Post by Allex » Sep 13 2018 5:43am
One motor left now!
You can get all parts from Paul:
https://em3ev.com/shop/?prod_cat_=mac-motor-parts
Allex   1 GW
1 GW
Post by Allex » Mar 25 2019 4:47am
Bump
Allex   1 GW
1 GW
Post by Allex » Dec 12 2019 7:21pm
150USD
Antenor   100 W
Post by Antenor » Dec 15 2019 1:50pm
What speed i can get with 48v battery?
Allex   1 GW
1 GW
Post by Allex » Dec 16 2019 5:59am
I would say around 38km/h but not sure.
