li-ion 18650 Adjustable size BATTERY HOLDER - Honeycomb Layout
KarT_PS   1 mW
Post by KarT_PS » Jan 05 2018 4:34am
!!! NEW OFFER !!!
Cell holders that can be combined in a variety of shapes to align to available space. Fits li-ion 18650 batteries.
The cells are placed on a multiple triangle shape (kind of honeycomb) - allows to utilize available space more efficiently.
Distance between cell 19.4 mm.
Material: ABS, Injection Molded, Produced in EU (Poland), Patent Pending.
Minimum order value: 50 EUR.
We can issue an invoice.
We are looking for distributor of our products with online store.
If you are interested – please write on prv.
NEW !!! - Thumb Throttle - NEW !!!
Thumb Throttle - 12,20 EUR / piece (excluding VAT and shipping)
Technical:
- compact design,
- does not interfere with derailleurs,
- right and left side,
- construction based on the hallotron principle (0.8-4.2V),
- soft elastomeric, non-slip insert in the place of contact with the thumb,
- works with any power controller,
- intended for brushless and brush motors,
- hermetic Higo connector,
- length of the cable: about 40cm,
- compatible with BBSHD.
Cell holder - pricing per piece (excluding VAT and shipping).
Cell holder x1 - 0,05 EUR / piece
Cell holder x2 - 0,07 EUR / piece
Cell holder x2 terminated - 0,07 EUR / piece
Cell holder x3 - 0,08 EUR / piece
Cell holder x6 - 0,15 EUR / piece
Wire holder BMS, diameter 1,5 - 0,08 EUR / piece
Wire holder, diameter 3 - 0,08 EUR / piece
Clip - 0,08 EUR/ piece
Side cover - 0,06 EUR / piece
Tapes for soldering/welding – pure nickel 0,2mm.
Price per meter (excluding VAT and shipping)
T2P - 4,55 EUR / meter
T3P - 6,85 EUR / meter
T4P - 9,10 EUR / meter
T5P - 11,40 EUR / meter
T6P - 13,70 EUR / meter
T7P - 15,90 EUR / meter
T8P - 18,20 EUR / meter
Connectors
Price per piece (excluding VAT and shipping)
2P - 0,05 EUR / piece
3P - 0,08 EUR / piece
4P - 0,10 EUR / piece
5P - 0,13 EUR / piece
6P - 0,16 EUR / piece
7P - 0,20 EUR / piece
8P - 0,21 EUR / piece
How to estimate how many and what type of holders you need for your application??
There are two ways to get the answer:
**One is to estimate the number by following formulas:
NumberOf3xHolders = (2*NumberOfCells)/3
NumberOf2xHolders = 0.1*Numberof3xHolders
NumberOf1xHolders = 0.1*Numberof3xHolders
This should cover safely most layouts.
**The other one is to print out this 1:1 pattern on A4:
HoneyComb Holders Pattern 1to1 A4.PDF
and follow the example:
You might need few copies sticked together to cover bigger footprints.
KarT_PS   1 mW
Re: li-ion 18650 Adjustable size BATTERY HOLDER - Honeycomb Layout
Post by KarT_PS » Jan 12 2018 1:42am
For your reference, the dimension matrix of the 10x10 battery pack:
footbaldd   100 mW
Post by footbaldd » Jan 16 2018 8:35am
PM sent.
hypertoric_amplituhedron   100 W
Post by hypertoric_amplituhedron » Jan 21 2018 4:21pm
Dude, these look great. Exactly what I'm looking for. I'll be considering these for a few upcoming builds.
There are two types of people in this world.
1. Those who can extrapolate from missing information.
KarT_PS   1 mW
Post by KarT_PS » Jan 25 2018 6:31am
Now Battery Holder 2x available!!
footbaldd   100 mW
Post by footbaldd » Feb 21 2018 8:40pm
The cell holders showed up and look excellent. You do need to pay attention to make sure that all of the dovetail joints are properly connected, and the shipping was quite expensive. Once the package left Poland, which took around a week, it was here within a day and a half (Houston, TX). They are exactly what I was looking for. Thanks again.
KarT_PS   1 mW
Post by KarT_PS » Feb 27 2018 2:28am
Few days ago we have finalized machining of injection tool and did trial for x2 holder. This one, compared to the one from my latest post, has dovetails around all sidewalls and can be used in the middle of the honeycomb assembly.
The previous type had no dovetails on a sidewall and shall be used to terminate the honeycomb assembly.
We are doing further research and I will keep you informed on new solutions!
jonescg   1.21 GW
1.21 GW
Post by jonescg » Feb 27 2018 3:02am
Looks great. I might be interested in a bag of these!
Rube   100 W
Post by Rube » Feb 27 2018 6:07am
Yeah another Australian interested in an order. Chris, let me know how many you want in case it's worth sharing an order.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Feb 27 2018 6:15am
Rube wrote:
Feb 27 2018 6:07am
Sure - I'm looking at building a drop-in replacement for the iMiEV battery, except with 18650 cells and liquid cooling. 24 kWh would be easy, 27 kWh might even be possible with a bit of shoe-horning.
whereswally606   100 kW
Post by whereswally606 » Feb 27 2018 6:35am
These look ace. Just posting so I can easily find the thread again when I need to build a new battery
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
SlowCo   1 MW
Post by SlowCo » Feb 27 2018 6:52am
whereswally606 wrote:
Feb 27 2018 6:35am
+1
KarT_PS   1 mW
Post by KarT_PS » Feb 28 2018 2:29am
Feel free to get in touch via PM.
StealthBobber   10 µW
10 µW
Post by StealthBobber » Feb 28 2018 4:14pm
SlowCo wrote:
Feb 27 2018 6:52am
Feb 27 2018 6:35am
+1
+2
footbaldd   100 mW
Post by footbaldd » Mar 04 2018 9:28pm
Here's what my two half packs look like with all the holders assembled. It can be a bit of work getting the holders all the way seated, but they are a great design. I used the three cell pieces for everything but the last row on the larger of the two packs in which I used the two cell sections. Thanks again.
Rube   100 W
Post by Rube » Mar 05 2018 6:47am
PM sent, no response. All OK?
KarT_PS   1 mW
Post by KarT_PS » Mar 07 2018 3:22am
(675.05 KiB) Downloaded 444 times
Dontcare   1 µW
Post by Dontcare » Mar 19 2018 4:31pm
How does one order these? The OP mentioned "PM" which likely means "send me a message on another channel", which isn't terribly useful. I guess I'll be buying that Makerbot after all ...
jonescg   1.21 GW
1.21 GW
Post by jonescg » Mar 19 2018 8:10pm
"Private Message". Any forum member can send anyone a private message.
Aebrennan   100 W
Post by Aebrennan » Apr 06 2018 5:54am
Had anyone been able to buy these?
I have sent PM no response?
jonescg   1.21 GW
1.21 GW
Post by jonescg » Apr 07 2018 5:16am
Yep. I just received my order of 1000 triple hexagons. Pretty convenient way to put a pack together.
vlad2323   1 µW
Post by vlad2323 » May 08 2018 12:19pm
Thank you! received his order in Belarus - they are smart Holders !!! I recommend to everyone!! With their help, you can do any design. Thank you very much again !!!!
cwah   10 GW
Post by cwah » May 09 2018 2:20am
If I want to do a 15s14p = 210 cells battery. I need 2*210/3 = 140 holders (3x)
140*.12€ = 16.8€ total cost?
ridethelightning   1 MW
Post by ridethelightning » May 13 2018 4:12am
awesome product..
cheeko   100 W
Post by cheeko » May 14 2018 12:21am
Hi i wouldn't mind this for 22S6P can you let me know if i can get them.
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
