li-ion 18650 Adjustable size BATTERY HOLDER - Honeycomb Layout
jonescg   1.21 GW
1.21 GW
Re: li-ion 18650 Adjustable size BATTERY HOLDER - Honeycomb Layout
Post by jonescg » May 14 2018 1:24am
cheeko wrote:
May 14 2018 12:21am
Hi i wouldn't mind this for 22S6P can you let me know if i can get them.
I bought 1000 of them and sent 200 across to Ryan in Brisbane (I think he needs all of them though). If you need 100 or so I can send you some of mine.
cheeko   100 W
Post by cheeko » May 15 2018 12:07am
Its ok wanted a few more, ill have to try another way to build it.
Thanks for your help though.
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
CFM   100 µW
100 µW
Post by CFM » Jun 14 2018 3:23pm
PM sent but no response... Are these still available?
brumbrum   100 kW
Post by brumbrum » Jun 17 2018 3:29pm
Minimum order = 500 pieces. Is this 500 single/solitary holders? In other words, would minimum order be 167 triple holders?
KarT_PS   1 mW
Post by KarT_PS » Jun 20 2018 6:03am
Yes, MOQ concerns one type of holder. Smaller quantities you can order at Polish partner who sends to UE countries:
https://nexun.pl/shop/elementy-elektryc ... du-3p.html
In other cases - please do not hesitate to contact PM.
KarT_PS   1 mW
Post by KarT_PS » Aug 29 2018 6:15am
Hi Everyone,
let me refresh the thread by introduction of new products:
What new?:
*Battery Holder x6
*Wire holder
*Ending part
Do not hesitate to get in touch via PM.
Solexelec   1 W
1 W
Post by Solexelec » Sep 10 2018 3:10pm
Hi
I was interrested to build to half pack 7S24P to make "big" battery 14S24P with smaller space.
do you have a little room left to ventilate the cells?
thanks for informations
KarT_PS   1 mW
Post by KarT_PS » Sep 11 2018 4:23am
Hi,
at narrowest point there is 1mm of space, so room to ventilate the cells is present.
Also you can look at the drawing - you'll find more information about dimensions.
Best regards
Ewa.
spinningmagnets   100 GW
Post by spinningmagnets » Sep 11 2018 7:20am
I really like these a lot. hexagonal end-caps have been discussed before, and I am very happy someone is now actually producing these. I had previously thought that I would have wanted to build a pack out of all sections that held two cells (with the last row using single-cell pieces), but I think its possible to build just about any series and paralleled combination with 3-cell and 2-cell pieces (I'm assuming the multi-cell pieces are slightly cheaper when purchased in bulk).
I don't want to start an argument over pack-building methods and configurations, but I have stated many times in the past that I prefer the honeycomb layout over "rank and file". For those who like honeycomb, a few are still building by hot-gluing cells together. The cells should not touch each other, even with the stock PVC heat shrink on them. Not only for electrical isolation, but also for heat dissipation. Even if your pack barely gets warm in the center, the heat needs to get out if you want the pack to last.
If the cells on the outer edges of the pack stay relatively cool, but the handful of cells at the center of the pack are always warm, lets just imagine that the outer cells would retain over 80% of their rated capacity for six years, but the inner cells go below 80% after three years. Would you rebuild the pack by replacing only the inner cells with new ones? Of course not. The entire pack will only last as long as the handful of cells that are abused the hardest.
Tesla uses honeycomb and does not have shrink wrap on their cylindrical cells for heat dissipation. I think the fiber insulation-washer added to every positive end is a vital component, but after that, this is the pack-building system I would use.
liamcaff   1 kW
Post by liamcaff » Sep 28 2018 9:12am
PM sent for order :)
angrykoala   1 µW
Post by angrykoala » Dec 26 2018 7:33am
Karlt_ps this looks awesome.
Do you also sell matching Nickel Strips for soldering?
Or can you point me where I can get them?
We will be building multiple
16s 13p batteries in a rectangular box that takes 2 layers of cells
So need 4 stacks of 7x15 bricks = 420
for each battery...
KarT_PS   1 mW
Post by KarT_PS » Dec 27 2018 4:50am
Hi angrykoala,
Nickel Strips for soldering will be available in January.
We will post an offer for it.
Thank you for your interest.
Piotr.
KarT_PS   1 mW
Post by KarT_PS » Jan 09 2019 11:06am
Hi Everyone,
let me refresh the thread by introduction of new products which you can find in first post.
viewtopic.php?f=31&t=92223
Find more about:
- cell holders
- nickel tapes
- connectors
We are also looking for distributor with online store - interested? Write on prv.
Best regards
Ewa.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jan 09 2019 9:48pm
Those nickel tapes look amazing! How, may I ask, were they made? Stamped out? I have tried water jet cutting but it was quite rough.
KarT_PS   1 mW
Post by KarT_PS » Jan 10 2019 9:15am
Exactly - they were stamped out. Thanks for recognition :)
sparkiesweden   10 mW
Post by sparkiesweden » Mar 04 2019 3:55pm
Any plans for 21700 version?
KarT_PS   1 mW
Post by KarT_PS » Mar 05 2019 2:27am
Hi,
yes we have it in our plans, 21700 version should be ready at the end of this year.
Regards,
Ewa.
Vmw1982   100 mW
Post by Vmw1982 » Mar 09 2019 3:44pm
footbaldd wrote:
Feb 21 2018 8:40pm
The cell holders showed up and look excellent. You do need to pay attention to make sure that all of the dovetail joints are properly connected, and the shipping was quite expensive. Once the package left Poland, which took around a week, it was here within a day and a half (Houston, TX). They are exactly what I was looking for. Thanks again.
Did you test those cells. I got the same LG HG2 Witu the yellow pwarning print on them and they only tested at 2200 mAh. Wondering if you had the same issue. I had to stop buying from one vendor for this reason. And would love to start buying them again.
kobe   1 µW
Post by kobe » Apr 25 2019 10:14am
Hi,
I would like to order 100pcs of X1 holders and 50pcs of X3 holders, if possible. You can reach me on the e-mail hencl@mgm-compro.com
Thnaks a lot in advance!
Kind regards,
Jakub
Aebrennan   100 W
Post by Aebrennan » May 08 2019 9:38pm
Where can I buy the nickel strip and have sent to Australia?
KarT_PS   1 mW
Post by KarT_PS » May 16 2019 5:56am
Hi everyone,
all the answers were sent on prv.
In nearest future we are planning to open on-line shop, so it will be easier to order our holders.
Regards,
Ewa.
Valman   100 mW
Post by Valman » Jun 09 2019 4:05pm
PM me please about payment details for shipping to UK for:
28x side covers 0.06 = EUR01.68
24x 6-cell-holder 0.15 = EUR03.60
28x 3-cell-holder 0.08 = EUR02.24
14x 2-cell-holder 0.07 = EUR00.98
16x 2-cell-terminated 0.07 = EUR01.12
24x 1-cell-holder 0.05 = EUR01.20
20x wire holder bms 0.08 = EUR01.60
2x meters T8P tape 18.20 = EUR36.40
24x 2P connectors 0.05 - EUR01.20
Total EUR50.02
thanks
Valman   100 mW
Post by Valman » Jun 11 2019 5:49am
Can you also please confirm that the nickel here is high purity? - i.e. 99%+ purity? (from what I read here, there are a lot of sellers selling nickel with low purity that isn't good, and doesn't pass a salt corrosion test - thanks)
KarT_PS   1 mW
Post by KarT_PS » Jun 12 2019 7:46am
Hi Valman,
all answers and details I will send you on prv.
Regards,
Ewa.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jul 10 2019 4:54am
Hi Ewa, just sent a PM.
Cheers!
Chris
