Hi, do you have similar holders for 21700 cells?KarT_PS wrote: ↑Jan 05 2018 4:34am!!! NEW OFFER !!!
Cell holders that can be combined in a variety of shapes to align to available space. Fits li-ion 18650 batteries.
The cells are placed on a multiple triangle shape (kind of honeycomb) - allows to utilize available space more efficiently.
Distance between cell 19.4 mm.
Material: ABS, Injection Molded, Produced in EU (Poland), Patent Pending.
Minimum order value: 50 EUR.
We can issue an invoice.
We are looking for distributor of our products with online store.
If you are interested – please write on prv.
NEW !!! - Thumb Throttle - NEW !!!
Thumb Throttle - 12,20 EUR / piece (excluding VAT and shipping)
Technical:
- compact design,
- does not interfere with derailleurs,
- right and left side,
- construction based on the hallotron principle (0.8-4.2V),
- soft elastomeric, non-slip insert in the place of contact with the thumb,
- works with any power controller,
- intended for brushless and brush motors,
- hermetic Higo connector,
- length of the cable: about 40cm,
- compatible with BBSHD.
Cell holder - pricing per piece (excluding VAT and shipping).
Cell holder x1 - 0,05 EUR / piece
Cell holder x2 - 0,07 EUR / piece
Cell holder x2 terminated - 0,07 EUR / piece
Cell holder x3 - 0,08 EUR / piece
Cell holder x6 - 0,15 EUR / piece
Wire holder BMS, diameter 1,5 - 0,08 EUR / piece
Wire holder, diameter 3 - 0,08 EUR / piece
Clip - 0,08 EUR/ piece
Side cover - 0,06 EUR / piece
Tapes for soldering/welding – pure nickel 0,2mm.
Price per meter (excluding VAT and shipping)
T2P - 4,55 EUR / meter
T3P - 6,85 EUR / meter
T4P - 9,10 EUR / meter
T5P - 11,40 EUR / meter
T6P - 13,70 EUR / meter
T7P - 15,90 EUR / meter
T8P - 18,20 EUR / meter
Connectors
Price per piece (excluding VAT and shipping)
2P - 0,05 EUR / piece
3P - 0,08 EUR / piece
4P - 0,10 EUR / piece
5P - 0,13 EUR / piece
6P - 0,16 EUR / piece
7P - 0,20 EUR / piece
8P - 0,21 EUR / piece
How to estimate how many and what type of holders you need for your application??
There are two ways to get the answer:
**One is to estimate the number by following formulas:
NumberOf3xHolders = (2*NumberOfCells)/3
NumberOf2xHolders = 0.1*Numberof3xHolders
NumberOf1xHolders = 0.1*Numberof3xHolders
This should cover safely most layouts.
**The other one is to print out this 1:1 pattern on A4:
HoneyComb Holders Pattern 1to1 A4.PDF
and follow the example:
You might need few copies sticked together to cover bigger footprints.
li-ion 18650 Adjustable size BATTERY HOLDER - Honeycomb Layout
Re: li-ion 18650 Adjustable size BATTERY HOLDER - Honeycomb Layout
Could you confirm the answer you received about the nickel - not sure why it would need to stay in PM.
Would also like to know.Hi, do you have similar holders for 21700 cells?
Just purchased some to try out, they fit together brilliantly, come with little tools to help you assemble and disassemble the pack so you don't cut your fingers to shreds, will let you know how pack building goes.
Hope all is well! I sent a PM a while ago ( maybe a month?) and was curious if anyone has heard from Kart_ps lately? Boughten from several times before and I know response takes a few normally. Hope everyone is doin ok during this pandemic!
I had a reply from him on the 17th Jul saying the 21700 holders weren't going to arrive any time soon.
Hi I have sent you a couple of PM's but haven't heard anything. Still selling these?
Hi All,
This day I can be able to contact with KarT ltd. easy way.
Please send a mail or contact with phone ...
Good luck!
Joe B.
Good luck!
Joe B.
Did these guys ever get an online store set up?
Frank
Thanks for the feedback. I'm waiting for 21700.
Frank
Hello KarT_PS, nice shop! Lots of useful things and great prices!
I just made an order, but please add the paypal payment. It's so much faster and easier than the bank transfer, and I will pay for all the surcharges. Thanks!
PP allows for buyer protection, reversing transactions.
Wire transfers don't.
So it's not the fees, prices must increase to cover all the scammers out there, including buyers
Just received my thumb throttle and trigger throttle from you @KarT_PS, connected to my BBSHD with eggrider, but they don't work.
My cheap chinese thumb throttle is working correctly, why yours don't? Do I have to set something up in the firmware to make them work?
They are not wired for Bafang.
Ask me how I know...
You need to change the wiring. Did you get the ecobike or rapid version?
Titanium Fatbike - Bafang Ultra and Phaserunner viewtopic.php?t=96212
Emtb - Bafang Ultra G510 3500W viewtopic.php?t=109135
Dengfu E06 Fatbike Bafang Ultra viewtopic.php?f=28&t=108990&p=1614975#p1614975
Join the Bafang Ultra group on FB https://www.facebook.com/groups/2323768714344360
Thanks for the info. I had a similar issue with the wiring that colors are not standard.
I ordered both, Thumb and Trigger trottle with the note "Rapid, KT, Bolt".
With Higo female extension cable i had to swap black and blue so it has to be wired like this:
+5V = red
GND = blue
signal = black
This is with Higo cable. Note that it might be different when using Julet or other brand connectors which are compatible.
I don't get it why they "invented" different standards. Where power comes out (controller or display side), the connector usually is female to have protection against short, and throttle or brake come with male connector. Also it is quite stupid that Higo can be used with Julet for instance, but the colors are swapped.
Hi,
Where can I buy the throttle, I need 2 units to California USA.
