Headway 20AH batteries with holders/connectors U.S only. SOLD
Headrc   1 W
1 W
Post by Headrc » Aug 16 2018 11:30am
THESE ARE NOW SOLD. THANKS YOU ENDLESS SPHERE
I have (24) new Headway 20AH 43184 batteries with the plastic holders and screws that I would like to sell. These are genuine never used cells. The only thing I did was to pull a couple of them and do a charge/discharge/ capacity test on them to make sure they performed as they should. The price is $600 plus shipping for all 24. I am only shipping to U.S. Attached are a couple of pictures with graphs of the tests I did. One of the pictures is the stock picture from the manufacturer as I did not want to pull out the holders and disassemble the packaging, but rest assured you will get the holders, connecting plates and screws to build a battery pack. These would be a good choice for something like a 24 volt 60AH portable battery pack. Or you could use them as an add on pack. I am selling because I have plenty of the Boston Power Swing 5300 batteries that can answer the same need that these answer so I just do not need these.
The setting for the capacity test was 10A constant current down to 2.7V, the settings for the charge test was 5A up to 3.6V.
Headway 20AH stock photo.jpeg (39.62 KiB) Viewed 224 times
Headway 20ah specs.jpeg (147.24 KiB) Viewed 224 times
Headway 20AH A small.jpg (77.51 KiB) Viewed 224 times
Headway 20ah B small.jpg (78.33 KiB) Viewed 224 times
Headway 20AH D small.jpg (83.87 KiB) Viewed 224 times
Headway 20AH E small.jpg (85.46 KiB) Viewed 224 times
Headway 20 AH discharge capacity test .JPG (45.82 KiB) Viewed 224 times
Headway 20AH charge test to 3.6V.JPG (44.7 KiB) Viewed 224 times
Headrc   1 W
1 W
Re: Headway 20AH batteries with holders/connectors U.S only.
Post by Headrc » Aug 23 2018 10:55am
I could be interested in breaking this package up if someone wants a smaller quantity for building portable 12 volt packs.
