DaVinci Drive with 3220 motor PRICE DROP $1,000
- recumpence 100 GW
- Location: On Earth right now. That can change at any time, though..........
Hey Guys,
This is a DaVinci Drive. Here are the specs;
3 turn Astro Flight 3220 motor (brand new)
White Industries super high torque freewheel (new)
Belt and pulleys (brand new)
7/8 oversize shaft
Billet aluminum DaVinci Drive housing (refurbished)
This drive is the highest output single motor system I make. It has all the bells and whistles.
The housing was previously used. I cleaned it up (removed scratches) and built it back up with 100% brand new parts. Normally I have a 2 month wait to build a drive system. This one was built this morning and is ready to ship.
I normally get $1,800 for this setup.
This unit is for sale for $1,000.
I can supply a new Castle Creations Edge 160 controller programmed for EV use and a throttle interface box of desired for additional cost.
Matt
7/8 oversize shaft
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
- recumpence 100 GW
Re: DaVinci Drive with 3220 motor
recumpence wrote: ↑Oct 11 2018 12:45pmHey Guys,
7/8 oversize shaft
This unit is for sale for $1,100.
Matt
- Attachments
- 20181011_123459-01.jpeg (220.11 KiB) Viewed 2259 times
- 20181011_123506-01.jpeg (215.17 KiB) Viewed 2259 times
- 20181011_123521-01.jpeg (189.98 KiB) Viewed 2259 times
- 20181011_123528-01.jpeg (176.69 KiB) Viewed 2259 times
Re: DaVinci Drive with 3220 motor $1,200
Man i have been dreaming of a setup like Matty's but i don't think the DaVinci will fit.
viewtopic.php?f=6&t=39928
What do you think Matt?
Any possible way to squeeze it in there somehow?
- recumpence 100 GW
No. If I were to add this drive to that bike, I would install it in front of the bottom bracket and drive the bottom bracket with it.
Thanks for the suggestion Matt.
I will try to envision a way to mount it and figure what other parts it would involve(mounting bracket mainly) and if it is not way too complicated (i don't possess Matty's mental resillience and skill) and if still available, i'll take it (Castle ESC, throttle box & all).
- recumpence 100 GW
Re: DaVinci Drive with 3220 motor PRICE DROP $1,000
Just dropped it another $100 down to $1,000. This is the lowest I am willing to go.
If it doesn't sell, I will build another bike with it.
Matt
Matt
Hi,
I would like to buy your davinci drive system with an astro 3220.
Do you have it in stock?
How much it will cost me? The system in this post works for me, I do not expect you still have it, but I can hope.
- recumpence 100 GW
I have one similar. Send me a private message and I will speak to you directly.
hi its silll for sale ?
Hi Matt,
Is this unit still available? Also would need mounting brackets for a 35 mm diameter down tube and an adapter fir mounting a big sprocket on the rear wheel with a disc brake setup.
Gunther
Gunther
If you are still looking for one of these, I have one that I no longer need. Mine is only an Astro 3215 motor though.
