PV NextGen FOC 130v 200/600A 25kw - $599, Watch Display
Powervelocity.com   10 kW
Re: Preorder. PV NextGen FOC 130v 200/600A 25kw - $499
Post by Powervelocity.com » Apr 14 2020 10:36pm
Pretty sure it will work. The switching frequency can go up to 60Khz. New controllers are configured to run at 25-30kHz by default.
We shipped only to a limited number of testers so far and making changes based on the feedback. The controller design is undergoing the major overhaul at the moment, lot's of safety and reliability features are being added. The price will likely go up as the result. We hope to restart production in May.
tylerwatts wrote:
Apr 13 2020 6:10pm
Hi powervelocity.
Do you have any experience running big RC motors with your controllers? Such as Turnigy CA120 outrunner with low inductance values? What pwm frequency can/do your controllers run at?
Please share any working examples or owner threads of such combinations.
Thank you
Cheers
Tyler
Edited typo spelling autocorrect...
vwgo   100 µW
100 µW
Post by vwgo » Apr 24 2020 12:39am
Hello,
I’m new to the EV movement and I’m getting my feet wet with an ekart build. Wondering if your new controller will work for my application?? I’m using a ME 1507 motor (sin/cosin) and a Curtis style throttle PB-6 3-wire. I’m building a 96v battery for it. Will your new controller run this motor and throttle??
Thanks
999zip999   100 GW
Post by 999zip999 » Apr 24 2020 9:32am
Battery what battery are you going to use
vwgo   100 µW
100 µW
Post by vwgo » Apr 24 2020 11:02am
I’m going to make a battery using these.
Post by Powervelocity.com » Apr 24 2020 5:07pm
I haven't tested this particular motor but I see no reason why it would not work. I did test anther IPM motor and it runs fine with halls and sensorless. SIN/COS encoder is supported.
For those battery pouches, make sure you get a good fire extinguisher before you put them together and connect it to the vehicle.
vwgo   100 µW
100 µW
Post by vwgo » Apr 24 2020 7:41pm
So, I want to get on the pre order list but your asking for “Product Customization”. Not sure what to ask for or if I even need any?? Being new at this I’m not up on all the lingo yet...Sorry. This controller from the specs looks pretty universal or “do-all” thus you wouldn’t need to ask for more customizing. I guess a list of customizations that I could check-off on would help then I would know what’s available or not for customizing.
Can’t wait to order one.
Thanks
Post by Powervelocity.com » Apr 25 2020 7:23pm
Pre-orders are currently closed. Should re-open in a couple of weeks.
vwgo wrote:
Apr 24 2020 7:41pm
Thanks
Post by Powervelocity.com » May 11 2020 4:56pm
Just a quick update that we haven't been sleeping during the pandemic but tried to use this downtime to make some serious improvements in the design. Here are some highlights.
- The controller is now three board semi-sandwiched design:
a) Al substrate power stage at the bottom interfacing directly with the heatsink
b) The mid board with DC link capacitance, drivers, and sensing circuits on top of the power stage
c) The control/brain board plugged into the DC link board
Among other added features, here are some to mention:
electronically controlled integrated contactor/disconnect with pre-charge circuit, integrated Bluetooth and WiFi for effortless over-the-air updates and possible future cloud integrations, expansion ports for optional SD card for data logging, and GPS/GSM for alarm/tracking.
These improvements will bump up the final price of the controller but pre-orders will be honored the price already paid.
vwgo   100 µW
100 µW
Post by vwgo » May 11 2020 6:13pm
Cool more upgrades!! Let me know when “pre-orders” open again.
micah78   10 mW
Post by micah78 » May 12 2020 12:43am
What's the timeline of these being ready to buy and be installed on my bike?Few weeks or months?Need a new controller soon for my bike.
HK12K   10 kW
Post by HK12K » May 13 2020 11:22am
Wow you guys are really going all in. Glad to see it. Nuc aside the controller market was stagnated and it's good to see companies beginning to push the envelope and actually release controllers with a feature set past the basic stuff we've grown accustomed to seeing. I look forward to seeing user feedback once they're finally released.
Legna199111   10 mW
Post by Legna199111 » May 22 2020 11:04am
Just started my first eeb build and really looking forward to using one of these bad boys! Gonna go with a qs 273 this would totally be rediculous with a 30s pack :bigthumb:
ChuckEbikeNorris   1 µW
Post by ChuckEbikeNorris » May 22 2020 6:00pm
When are these expected to ship? I'll be rebuilding my ebike this fall/winter. I've waited years for this. Thank you so much for making this! my current 10kw is starting to feel slow : (
cheapcookie   100 W
Post by cheapcookie » May 23 2020 1:20pm
Interested as well
wojtek   100 kW
Post by wojtek » May 23 2020 1:31pm
Is it bulk charging or via BMS with display of all individual cells voltage (similar to adaptto?)
Velokraft Batmobile
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - in progress
Giant CRS Alliance - SOLD
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02
Velokraft e-VK3
Velokraft Vk2
Steintrike Mungo Sport HS3540
Scorpion FS HS3540
Kona Dawg BMC v2
cheapcookie   100 W
Post by cheapcookie » May 26 2020 12:58pm
Nucular controller is charged through phase wires and modulates psu charger voltage. Is this a feature of Nextgen Foc as well? Thanks!
999zip999   100 GW
Post by 999zip999 » May 26 2020 2:23pm
With BT cell monitoring.
Post by Powervelocity.com » May 26 2020 2:28pm
Yes, charging via a phase is supported. It holds desired charge current and voltage. CC and CV charging modes.
cheapcookie wrote:
May 26 2020 12:58pm
Post by Powervelocity.com » May 26 2020 2:33pm
Cell level monitoring might be an option later. One way to do it can be adding protocol support for existing BMSs via BT, so no wiring or additional hardware would be needed on the controller side.
wojtek wrote:
May 23 2020 1:31pm
john61ct   100 GW
Re: PV NextGen FOC 130v 200/600A 25kw - $599, Watch Display
Post by john61ct » Jun 16 2020 9:30am
strapped to my body? yuck!
But OK, long as the handlebar mount is secure, big numbers simple display for old eyes slow brain
Post by Powervelocity.com » Jun 17 2020 12:32pm
You don't have to. There is a handlebar mountable bike version.
The wearable watch version is for those applications where you actually want it to be strapped to. Think of efoils/surfboards, e-skateboards, etc.
john61ct wrote:
Jun 16 2020 9:30am
micah78   10 mW
Post by micah78 » Jun 18 2020 3:19am
Any news of when I can order a controller?What might be the time frame of this being ready?
Post by Powervelocity.com » Jun 18 2020 12:13pm
I am thinking we should have production running in July and will start accumulating the stock.
In the meanwhile, I've run acceleration and variable regen braking tests on the latest version of the controller yesterday, and it's running solid on my bike. Pulls strong, very little heat on the case even though I intentionally dropped the controller into the enclosed frame to restrict the airflow. Installed outside, it would be doing even better, likely staying at ambient temperature most of the time. The metal core power stage does its job well.
I am also seeing a good efficiency bump in comparison with single shunt controllers which would be expected from three phase in line sensing. The torque feels natural, smooth and precise.
I might need a couple more testers to have a better sample of different motors and setups. If you have a good testing rig and have experience/knowledge working on electric vehicles, please PM. I can offer a discount in exchange for proper testing but you have to be set up for that.
micah78 wrote:
Jun 18 2020 3:19am
micah78   10 mW
Post by micah78 » Jun 20 2020 1:41pm
Alright July sounds great!!I look forward to the upgrade from the controller I have now.
