Page 9 of 9
Re: Preorder. PV NextGen FOC 130v 200/600A 25kw - $499
Posted: Apr 14 2020 10:36pm
by Powervelocity.com
Pretty sure it will work. The switching frequency can go up to 60Khz. New controllers are configured to run at 25-30kHz by default.
We shipped only to a limited number of testers so far and making changes based on the feedback. The controller design is undergoing the major overhaul at the moment, lot's of safety and reliability features are being added. The price will likely go up as the result. We hope to restart production in May.
tylerwatts wrote:
Apr 13 2020 6:10pm
Hi powervelocity.
Do you have any experience running big RC motors with your controllers? Such as Turnigy CA120 outrunner with low inductance values? What pwm frequency can/do your controllers run at?
Please share any working examples or owner threads of such combinations.
Thank you
Cheers
Tyler
Edited typo spelling autocorrect...
Posted: Apr 24 2020 12:39am
by vwgo
Hello,
I’m new to the EV movement and I’m getting my feet wet with an ekart build. Wondering if your new controller will work for my application?? I’m using a ME 1507 motor (sin/cosin) and a Curtis style throttle PB-6 3-wire. I’m building a 96v battery for it. Will your new controller run this motor and throttle??
Posted: Apr 24 2020 9:32am
by 999zip999
Battery what battery are you going to use
Posted: Apr 24 2020 11:02am
by vwgo
I’m going to make a battery using these.
Posted: Apr 24 2020 5:07pm
I haven't tested this particular motor but I see no reason why it would not work. I did test anther IPM motor and it runs fine with halls and sensorless. SIN/COS encoder is supported.
For those battery pouches, make sure you get a good fire extinguisher before you put them together and connect it to the vehicle.
Posted: Apr 24 2020 7:41pm
by vwgo
So, I want to get on the pre order list but your asking for “Product Customization”. Not sure what to ask for or if I even need any?? Being new at this I’m not up on all the lingo yet...Sorry. This controller from the specs looks pretty universal or “do-all” thus you wouldn’t need to ask for more customizing. I guess a list of customizations that I could check-off on would help then I would know what’s available or not for customizing.
Can’t wait to order one.
Posted: Apr 25 2020 7:23pm
Pre-orders are currently closed. Should re-open in a couple of weeks.
vwgo wrote:
Apr 24 2020 7:41pm
Posted: May 11 2020 4:56pm
Just a quick update that we haven't been sleeping during the pandemic but tried to use this downtime to make some serious improvements in the design. Here are some highlights.
- The controller is now three board semi-sandwiched design:
a) Al substrate power stage at the bottom interfacing directly with the heatsink
b) The mid board with DC link capacitance, drivers, and sensing circuits on top of the power stage
c) The control/brain board plugged into the DC link board
Among other added features, here are some to mention:
electronically controlled integrated contactor/disconnect with pre-charge circuit, integrated Bluetooth and WiFi for effortless over-the-air updates and possible future cloud integrations, expansion ports for optional SD card for data logging, and GPS/GSM for alarm/tracking.
These improvements will bump up the final price of the controller but pre-orders will be honored the price already paid.
Posted: May 11 2020 6:13pm
by vwgo
Cool more upgrades!! Let me know when “pre-orders” open again.
Posted: May 12 2020 12:43am
by micah78
What's the timeline of these being ready to buy and be installed on my bike?Few weeks or months?Need a new controller soon for my bike.
Posted: May 13 2020 11:22am
by HK12K
Wow you guys are really going all in. Glad to see it. Nuc aside the controller market was stagnated and it's good to see companies beginning to push the envelope and actually release controllers with a feature set past the basic stuff we've grown accustomed to seeing. I look forward to seeing user feedback once they're finally released.
Posted: May 22 2020 11:04am
by Legna199111
Just started my first eeb build and really looking forward to using one of these bad boys! Gonna go with a qs 273 this would totally be rediculous with a 30s pack :bigthumb:
Posted: May 22 2020 6:00pm
by ChuckEbikeNorris
When are these expected to ship? I'll be rebuilding my ebike this fall/winter. I've waited years for this. Thank you so much for making this! my current 10kw is starting to feel slow : (
Posted: May 23 2020 1:20pm
by cheapcookie
Interested as well
Posted: May 23 2020 1:31pm
by wojtek
Is it bulk charging or via BMS with display of all individual cells voltage (similar to adaptto?)
Posted: May 26 2020 12:58pm
by cheapcookie
Nucular controller is charged through phase wires and modulates psu charger voltage. Is this a feature of Nextgen Foc as well? Thanks!
Posted: May 26 2020 2:23pm
by 999zip999
With BT cell monitoring.
Posted: May 26 2020 2:28pm
Yes, charging via a phase is supported. It holds desired charge current and voltage. CC and CV charging modes.
cheapcookie wrote:
May 26 2020 12:58pm
Posted: May 26 2020 2:33pm
Cell level monitoring might be an option later. One way to do it can be adding protocol support for existing BMSs via BT, so no wiring or additional hardware would be needed on the controller side.
wojtek wrote:
May 23 2020 1:31pm
