What is the Difference Between Electronic and Electric?
Things related to the E-S Wiki
LockH   100 GW
Post by LockH » Oct 11 2015 10:48am
Seen here, for example:
http://www.wisegeek.org/what-is-the-dif ... ectric.htm
there is a subtle difference between the correct usage of each word.
and "Electric has to do with the general concept of electricity."
and "... electronic is a term that is descriptive of devices that are powered by electricity."
Anyway... after using electricity all my life this question occurred to me in reading this instructables "12V-180kV: A Battery Powered Marx Generator (and introduction to electronics)"
... and until now zero mention of the "Marx Generator" on ES either, that I could find.
Tks :)
L
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
spinningmagnets   100 GW
Re: What is the Difference Between Electronic and Electric?
Post by spinningmagnets » Oct 11 2015 11:31am
I don't know the proper differences between electronic and electric, but as an outside observer, I would say that the common brushless ebike controller is stuffed full of electronic components, but a simple brushed controller could (in my mind) be comfortably called an electrical device. Perhaps it has to do with the processing of inputs and outputs using low voltage in a programmable chip?
LockH   100 GW
Post by LockH » Oct 11 2015 11:49am
Hehe... Ya. We tap about "electric bikes" when it seems we're more about "electronic bikes". Amusing.
Post by spinningmagnets » Oct 12 2015 6:50am
This may be splitting hairs, but by my definition, the brushless ebike hub-motor is "electric", but the hall sensors are "electronic", and...the controllers are electronic devices, whether sensored or sensorless...
The battery is electric, but the BMS is electronic?...
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Oct 12 2015 6:34pm
To me, if there are logic devices within the electrical, then it is electronic.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
pgpete   100 µW
100 µW
Post by pgpete » Aug 03 2016 9:13am
Electrical systems are about electric energy systems used to produce and distribute power output
Electronic systems are about electronics designed used to produce, process and distribute information.
Electrical systems use electronics . ( and vice versa. )
Stealth Franken-Fighter
RLT   10 kW
Post by RLT » Aug 03 2016 5:06pm
cal3thousand wrote:To me, if there are logic devices within the electrical, then it is electronic.
Yep. That is pretty much the way I always thought about it. If it uses old school vacuum tubes or semiconductors it is electronic.
If it is only wires, and/or any combination of mechanical switches , resistors capacitors and inductors, it is just electric..
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Jan 31 2020 5:17pm
the real actual Electronics is called Chemistry full stop
smoko   1 µW
Post by smoko » Mar 05 2020 9:29pm
An electrician minimises resistances to gain the most efficient transmission.
An electronics technician plays with resistances to achieve the desired circuit.
alan   100 W
Post by alan » Mar 06 2020 10:53am
Toorbough ULL-Zeveigh wrote:
Jan 31 2020 5:17pm
The real actual chemistry is called physics.
The virtual physics is called philosophy.
The real virtual is called math.
Post by spinningmagnets » Mar 06 2020 12:47pm
I remember that the higher the voltage, the farther a spark can jump through the air. So...in order to pack a LOT of copper traces on an electronics circuit board or a programmable chip, it is very common to use 5V or 3.3V. I am no electronics guru, so maybe one of the other members can chime in.
Of course with "electrical" systems, we can see very high volts and amps, and significant power performing work. I view a hubmotor as an electrical device, except for the Hall sensors and temp sensor, which I view as electronic (they work with 5V)
flat tire   1 MW
Post by flat tire » Mar 06 2020 6:15pm
Electric is anything to do with electricity.
Electronics USE electricity.
DogDipstick   10 kW
Post by DogDipstick » Mar 08 2020 7:47am
flat tire wrote:
Mar 06 2020 6:15pm
Such perception. Such knowledge. Such helpful. What skill.
83.1v of Ironhorse XC.. :) :bolt: by Chevy :bolt: :D Broke 10 horsies :twisted: (..about 80% healed..).. :? Anybody.. what equals √3 times the line to neutral voltage? Asking for a friend.. :| (gottenymoem4115thangs?Yall?) :confused: Fabricator @ BSECo. Inc.
markz   100 GW
Post by markz » Mar 09 2020 4:53pm
spinningmagnets wrote:
Oct 12 2015 6:50am
What about SENSORLESS controllers
no Hall Sensors
Post by spinningmagnets » Mar 09 2020 5:52pm
I am fond of sensorless controllers, especially as a troubleshooting device. Meaning...if your stock controller suddenly does not work, but a sensorless back-up controller does work, then the motor phases are fine (not shorted due to heat damaging the coil-wire insulating varnish). In that case, the throttle and motor are working fine, but either the controller or the Hall sensors are not working properly.
A sensorless controller is an electronic device, although there is an argument as to whether the MOSFETs are an electrical device, since they work at high volts and high amps.
There have been suggestions to develop an open-source controller that separates the brain-stage and the power-stage, since the brain section would then not suffer from the high heat of the power stage...
amberwolf   100 GW
Post by amberwolf » Mar 13 2020 4:00am
Mar 09 2020 5:52pm
. There have been suggestions to develop an open-source controller that separates the brain-stage and the power-stage, since the brain section does not suffer from high heat.
like lebowski + (insert powerstage here)? ;)
Post by spinningmagnets » Mar 13 2020 7:30am
Yes, Lebowski! I also think any inductance from large power pulses can be isolated to the robust power stage, leaving the separate brain-box as cool as possible and inductance-free...
Although, I freely confess I am a noob when it comes to electronix...
fourbanger   100 W
Post by fourbanger » Mar 29 2020 4:56am
