Electric kart
Doctorbass
Re: Electric kart
Post by Doctorbass » Jun 19, 2017 10:06 am
Here are some description of the errors of Sevcon:
http://acgcars.us/support/SEVCON_Faults_Table.pdf
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
https://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
nuxland
Re: Electric kart
Post by nuxland » Jul 06, 2017 3:15 am
Finally solved my DSP error problem and it was a very easy fix.
Just I did not saw that before that in motor signal wire socket one of the female pins were bad.
And then male pin inside female pin was moving and there was contact and not contact depending of the movement.
But to get to the cause I resoldered just in case male part of that socket and event opened motor encoder area to see are there everything ok.
And I tested with tester wires between motor and socket and between sevcon and socket and these were good. And only then I bothered to look at the socket itself :wink:
replaced this bad pin and now everything works like new.
Here is picture of that bad pin :twisted:
Badkad
100 µW
100 µW
Re: Electric kart
Post by Badkad » Jul 10, 2017 2:13 pm
Where can I get that Z-force motor from?
nuxland
Re: Electric kart
Post by nuxland » Jul 11, 2017 9:04 am
Badkad wrote:Where can I get that Z-force motor from?
I got my motor from this thread, but that was a year ago :)
https://endless-sphere.com/forums/viewt ... 30&t=81009
nuxland
Re: Electric kart
Post by nuxland » Aug 13, 2017 7:52 am
Tested Zero air-through cooling this weekend in a race that was very acceleration and braking intensive and motor was not able to cool itself enough by pumping air through by itself.
Theoretically inner rotor should act as tesla turbine and I actually felt the air through motor very well when wheels in air and rotating in 5000rpm.
So it seems I need to install active air cooling, two powerful centrifugal vents to pump air trough at faster speed that motor itself can do :)
Video of first race when I hit the wall, because I lost rear brakes also due overheating :(
https://www.youtube.com/watch?v=uEmZBzaQNuo
nuxland
Re: Electric kart
Post by nuxland » Sep 05, 2017 2:09 pm
Installed forced air cooling to the motor and tested acceleration.
This should be not official word record with electric kart acceleration.
https://www.youtube.com/watch?v=2Xp41u1y9KI
2,640 seconds to 100km/h and 0-60mph is even faster in 2.577 seconds as 60mph=96,5km/h
This should be current official record I think to 60mph
https://www.youtube.com/watch?v=r0b6UoxqrPE
But in that track forced cooling is not enough for 10 laps. I can do sprint like 7 or 8 laps only.
amberwolf
Re: Electric kart
Post by amberwolf » Sep 05, 2017 2:28 pm
As an experiment you might try flipping the fans and expanding the duct so that they suck the air thru the motor instead of trying to force it in.
When I did computer cooling I found that worked better (less noise, which means less turbulence, less wasted power, more cooling airflow).
Or use a single larger fan shaped just like those but with it's intake the size of the outlet ring on the motor, and place it directly against that outlet ring (or spaced a short distance away with a ring between them).
Hillhater
Re: Electric kart
Post by Hillhater » Sep 05, 2017 6:37 pm
Very impressive 0-100 run.....mainly because i dont figure how you got enough grip.
Every kart i have used (regular 2t race karts) have always had more power than grip..even with good warm tyres.?
Also , depending on your definition od a "kart" , im sure you are aware of the 1.51 sec time from this...
https://youtu.be/n2XiCYA3C9s
nuxland
Re: Electric kart
Post by nuxland » Sep 06, 2017 3:38 am
amberwolf wrote:As an experiment you might try flipping the fans and expanding the duct so that they suck the air thru the motor instead of trying to force it in.
Can't do that because motor has opening around encoder in one side and opening in the edges in sprocket side. So rotor itself using tsentrifugal force will push air from encoder side to sprocket side.
And I can't install blower in sprocket side for sucking air.
I will try to install two more blowers if I have time.
But in the end it is very hard to remove 4kw to 9kw of heat so rapidly like I need in the racetrack.
If I stop then it cools very fast.
nuxland
Re: Electric kart
Post by nuxland » Sep 06, 2017 5:20 am
Hillhater wrote:Very impressive 0-100 run.....mainly because i dont figure how you got enough grip.
When I did acceleration test last year I had old hard tires and outside was 11 degrees.
This time we had soft White VEGA tires that we had run like 20 laps. So grip was very good.
We also started in the corner where there was rubber in asphalt but even then he succeeded to spin tires couple of times :)
Hillhater wrote:Also , depending on your definition od a "kart" , im sure you are aware of the 1.51 sec time from this...
Yeah, I know this, but this is 4WD and not comparable to kart. They also have suspensions and bigger tires (wider and bigger in diameter)
But how did they measured the time? Formula student actually have in competition acceleration test, but this is 0 to 75 meters test.
And I would like to officially measure my time, but I do not now what equipment I should use that will make it official?
PS! I also analyzed again and used data from cycle analyst started the clock when speed went to 1km/h.
And with that it's 2,507 to 100kmh. It took 40 meters to reach it.
https://youtu.be/eb4UeH0XcJU
craigcalfee
10 µW
10 µW
Re: Electric kart
Post by craigcalfee » Sep 06, 2017 11:20 am
Your fan size seems too small. When we bench tested that motor, a lot of air pressure is generated. That fan doesn't look like it would add much velocity to it. And the ducting is not so good for laminar flow. But good progress! Looking forward to the next improvement!
Craig Calfee
Calfee Design
Bicycles, E Bikes, E Motorcycles, Gyrocycles, Prototyping and Consulting
calfeedesign.com
Hillhater
Re: Electric kart
Post by Hillhater » Sep 06, 2017 5:55 pm
nuxland wrote:[
Yeah, I know this, but this is 4WD and not comparable to kart. ......
Thats the issue...Once you diverge from the common FIM/CIK specification a "Kart" , (motors, chassis, wheels , tyres etc) then you are in an "unregulated" area and as such there is no restrictions on what you use or what you call it.
there are karts in the USA that run 6", 8", and 10" dia x 10" wide tyres, karts with 4 wheel drive, fully enclosed bodywork, and a whole range of odball drive systems.
But i basicly agree, a "Kart" should have as a base, a solid rear drive axle, no suspension .and a ? Limit on wheel size.
nuxland
Re: Electric kart
Post by nuxland » Sep 07, 2017 3:34 am
craigcalfee wrote:Your fan size seems too small. When we bench tested that motor, a lot of air pressure is generated. That fan doesn't look like it would add much velocity to it. And the ducting is not so good for laminar flow. But good progress! Looking forward to the next improvement!
I'm using two of these fans 09533GA-12Q-AA-00 and according to specs they provide good airflow against pressure.
I'm considering to add two more or upgrade to bigger one, but I have little room there so need to think of something.
fechter
Re: Electric kart
Post by fechter » Sep 08, 2017 8:21 am
You could bump the fan voltage up to 15-16v. :wink:
It looks like the air passages through the motor are fairly small, so you need those centrifugal blowers. I can't tell from the pics what kind of cross sectional area the air passages have inside.
You could also blow air over the fins on the outside of the motor but it won't be as effective as blowing through the windings.
nuxland
Re: Electric kart
Post by nuxland » Oct 20, 2017 6:21 am
They built a brand new kart track near Tartu, Lange. It's not finished yet and will open spring 2018 but they let me try out that track.
In in the same day there were also one guy with Estonian formula student car from the year 2008. So we both tested that track.
I recorded a video also. But as this was our first run on that track we were easy and track was also moist a little bit.
https://www.youtube.com/watch?v=6R7st79kbps
I think this was my last driving this year as it's already minus degrees in night time.
I hope I can finish installing second controller + motor + battery to kart and try 1/4 mile next spring with 110kw and 210kg kart :)
SlowCo
Re: Electric kart
Post by SlowCo » Oct 20, 2017 10:36 am
Great video!
Love to see your progress on installing the second controller, motor and battery. Curious what your 1/4 mile time will be :shock:
LuigiDesign
Re: Electric kart
Post by LuigiDesign » Dec 03, 2017 5:59 pm
Hi Nuxland again! Very busy last months... :roll:
There are few things that I can comment, first one, you are getting better and better!
-When you are on field weakening state, it is caused by the motor is above max modulation, meaning, back emf is equal to max volts delivered to the motor due to higher rpms than nominal. Then, needs to compensate angle of shot with -id to still giving you torque at higher rpms, but have 2 issues, as soon you change the angle of shot you lose efficiency rapidly, you must to consider then change the final ratio to be on max torque curve. And the fatal and second one, if you abuse of this and lets the motor heat up enough, you can demagnetise permanently the magnets......
In the other hand, I suggest to check if,
-Encoder is at its best ofset.
-If field weakening gains operation is modulating properly, enough -iq amps?.
-Ls is tracking?
If you send me screenshots of dvt motor data config and logs of vehicle interface during a run I'll try to help you if you need it.
Regards!
Luigi
Quinc
Re: Electric kart
Post by Quinc » Dec 06, 2017 4:22 pm
h0tr0d
Re: Electric kart
Post by h0tr0d » Jan 06, 2018 8:41 pm
Awesome results and evolution!!!
Thank you Justin! Life is so much sweeter with this forum... ;)
macribs
1 GW
1 GW
Re: Electric kart
Post by macribs » Jan 14, 2018 4:59 pm
Yeah this have been an epic thread. Look forward to see what is possible with dual controllers.
GeriatricGeoffrey
100 µW
100 µW
Re: Electric kart
Post by GeriatricGeoffrey » Jan 17, 2018 12:10 am
looks fun. estimated cost so far?
