ATV conversion (mostly done)
romelec   10 W
Post by romelec » Jan 03 2018 11:42am
Hi,
I started to work on my ATV conversion about 4 years ago (with a lot of long pauses), finally last week I could do the first test:
The ATV is a Jianshe 250 bought about 10 years ago for 2000€
Motor: used ME1114 with regular hall sensor instead of the sin/cos, with a pulley and universal joint to the original transmission shaft
Controller: Sevcon gen 4 size 4 on ebay, with the old IXXAT interface (I don't sell it !)
Motenergy provided me a configuration file they use on a test bench, it was certainly not easy to make it working but I didn't had to modify the difficult settings such as the PI control loop parameters.
Batteries: 10Ah headway cells to form a 72V 60Ah pack
I have also 4 headway cells for the accessory battery and a 12v converter
BMS: the last model from foundingpower bought before they stopped
Throttle: I used a thumb throttle modified with 3d printed parts to use a cable so I can keep the original thumb throttle
Everything fits very very tightly:
romelec   10 W
Re: ATV conversion (mostly done)
Post by romelec » Jan 03 2018 11:48am
The things to finish are mostly around the Sevcon programming:
- figure out how to have regen on throttle release
- add a brake lever for variable regen, I will use an hydraulic one with a pressure sensor
- eventually setup the 3 different profiles with different power / regen levels
- find how to link the BMS to the Sevcon
skeetab5780   10 MW
Post by skeetab5780 » Jan 03 2018 12:38pm
Awesome build sub’d
Always wanted a two wheel drive sports quad conversion myself, all time favorite quad is 1987 trx250x
fechter   100 GW
Post by fechter » Jan 03 2018 2:27pm
Wow, looks like it runs great. Nice work.
Hillhater   100 GW
Post by Hillhater » Jan 03 2018 5:51pm
Very nice conversion.
I just hope you dont regret using those Headway cells,...they do not have the best of reputations.
jonescg   1 GW
1 GW
Post by jonescg » Jan 03 2018 11:03pm
Very tidy build!
The Headways will be fine in summer, but they will sag pretty bad in winter.
How far do you think you will get on a charge?
romelec   10 W
Post by romelec » Jan 04 2018 4:10am
Thanks !
Yes I expected that for LiFePO4, but it's fine I won't use it a lot and almost never in winter because I will also be cold !
I have no idea for the range but 50km would be nice to have, I expect it to vary a lot depending on the terrain.
amberwolf   100 GW
Post by amberwolf » Jan 05 2018 1:40am
For winter you could add battery heaters, like the ones used on car-battery lead-acid stuff for more northerly areas. Or those under-tank reptile habitat heaters, like ZooMed makes--they're thin and flat and could be installed inside the battery compartment, then their cords connected together to a single 115vac plug. Leave them plugged in when you're charging, anytime you're not riding but might need to use it, and it'll be warm and ready to go without sag during the ride.
If the battery box is insulated on the outside, it'll keep the heat in, and should last thru it's whole capacity.
E-Chopper   10 W
Post by E-Chopper » Jan 05 2018 9:00am
Great Job !!!
nice pictures !!!
Do you want to register it for street legal use or only offroad !?
Greetings from Austria to France
"Thunder is good,Thunder is impressive;
but it is Lightning that does the work !
-Mark Twain
romelec   10 W
Post by romelec » Jan 05 2018 12:42pm
I wanted to add a heater, there is some insulation in the box (4mm cork) but I have found these tapes only in USA but the shipping to Europe is pretty expensive, about $50 :?
How much power is needed ?
Unfortunately it is impossible (or very expensive) to register converted vehicles in France, so I will keep it like that.
minimum   10 W
Post by minimum » Jan 06 2018 2:14am
Look for 3D printer parts stores - some bed heaters for printers are paper thin.
12 VDC version are most common, 24VDC less common and 240VAC are rare. They come with thermistor attached and should have some kind of additional regulation or it will cook your battery.
https://www.robotdigg.com/product/877/2 ... ble-heater
GeriatricGeoffrey   1 mW
Post by GeriatricGeoffrey » Jan 10 2018 9:20pm
looks fun!
cost so far?
romelec   10 W
Post by romelec » Jun 08 2018 10:36am
Sorry for the very very late answer, it costed about 4000€
It is now almost finished, I still have to tweak the controller to have more power at startup but that's all.
Maybe create different drive profiles as I have a switch wired but is is not really necessary.
The issue I had with the regen not working was because I didn't had a FS1 switch on the throttle, when I added it worked immediately.
For the variable regen I didn't use a brake lever but reused the choke lever used with the left thumb.
I plan to make a video presenting everything but don't know when I will have the time, maybe in July.
new throttle box made with Curtis pots
variable regen lever at the bottom
Post by GeriatricGeoffrey » Aug 07 2018 11:42pm
romelec wrote:
Jun 08 2018 10:36am
I appreciate the update!
Looks great, awesome job. I want one :D :D :D
romelec   10 W
Post by romelec » Sep 17 2018 9:35am
It is not the presentation video but my first real trip with it (20km with +/- 600m in altitude), still nice I think !
Alan B   100 GW
Post by Alan B » Sep 17 2018 11:23am
Nice! Would be quiet and fun.
I have a 2wd ATV that I have thought about adding an electric "Stealth Mode" to. Keep the gas engine for range, but add a small electric system to run silent and slow for short distances. :)
fechter   100 GW
Post by fechter » Sep 17 2018 2:17pm
romelec wrote:
Sep 17 2018 9:35am
That thing is going pretty fast up the hill. Very impressive. 600m climb is good performance too.
One fun thing about electric rides is you can sneak up on wildlife. In my area there are lots of deer and coyotes. You would never see them with a gas powered ride.
Alan B   100 GW
Post by Alan B » Sep 17 2018 5:42pm
Idling along slowly with the ATV doesn't seem to bother wildlife much, usually. At least with my ATV the exhaust is quiet and in the rear. The noise comes from the low pressure tires popping little rocks or crunching leaves on the ground, but that is pretty quiet too, depending on the leaves or whatever is underfoot. Wildlife often doesn't spook until you stop, or especially if you step away from the ATV. As long as you stay on it they seem to be, for the most part, unworried. However if it was quieter it might be even better. :)
romelec   10 W
Post by romelec » Sep 25 2018 9:00am
No idea about wildlife, there isn't much around here (or I don't see them), but the MTB riders/hikers appreciate it !
The power above 10km/h is great but not under, it is difficult or even sometimes impossible to start uphill, I don't know why.
There must be some parameters to change but which ?
