buddy electric car
matsh   100 mW
buddy electric car
Post by matsh » Nov 05 2018 11:29am
Hi guys,
im buying an older buddy electric car, its prodused for the norwegian market https://no.wikipedia.org/wiki/Buddy_(elbil)
the stock brushed motor is toasted, same with battery. original is 72V SepEx 13kW motor and lead accid batteries. going to use e-up or golf battery cells and a kelly controller keb12401. first time electric car build / hotrodding. built several high powered bikes and stand up scooters.
but i dont know where to buy motor for this project ? maybe some that can fit in the stock location ? and must be bldc motor, because of the controller i have.
matsh   100 mW
Re: buddy electric car
Post by matsh » Nov 05 2018 1:53pm
i found that old used motor from salvaged citroen c-zero is relative cheap and easy to get here in norway. Y4f1 motor same as used in couple different electric cars. if i go for this motor then i cant use my kelly keb controller right ? what controller can i match into a motor like this ? if this is easier and cheaper than a new bldc motor that will work with my keb controller ?
x.l.r.8   100 W
Post by x.l.r.8 » Nov 12 2018 10:23am
Maybe you can look on the diyekectricar wedsite, they have a comprehensive classifieds abd there are a lot of used motors there.
Intelligence is distributed nearly evenly, with only the occasional concentration in one person. The total quantity of Intelligence is a constant: as more people come into being, fewer and fewer get a sufficient amount for themselves.
Some say this has already reached homeopathic levels.
