Any suggestions for a nominal 16-18v lithium charger?
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
JNorth   1 mW
Post by JNorth » May 23 2019 5:31pm
I'm using 2 nissan leaf modules in a kids JD electric gator.
Replacing the 12v 12ah lead battery.
so we have a 4s2p lithium setup.
Looking for a charger now.
Any suggestions?
amberwolf   100 GW
Re: Any suggestions for a nominal 16-18v lithium charger?
Post by amberwolf » May 23 2019 6:59pm
simple and easy and relatively cheap, meanwell led psu hlg-xxxh-24a where xxx is the wattage. you probably only need the 150 series. they're adjsutable so you can adjust down to 16.4v, which is 4.1v/cell, which is where i use my eig nmc cells at for my 4s lighting packs. they're potted and sealed so you can bolt it right to the vehicle and wire it in, just put a switch between it and the battery so it doesn't drain it slwoly if you leave it sitting unused a long time.
so for you the hlg-150h-24a should work
https://www.mouser.com/ProductDetail/ME ... X34g%3D%3D
https://www.meanwell-web.com/en-gb/ac-d ... -150h--24a
JNorth   1 mW
Post by JNorth » May 24 2019 9:59pm
Interesting. Thanks.
