10KW ATV Build
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
AJ350925   1 µW
10KW ATV Build
Post by AJ350925 » Jun 10 2019 7:51am
I started on my first Electric ATV build this weekend, and had it driving after about 20 hours of work.
ATV: TAOTAO 125cc ATV that I found on craigslist with a blown motor
Motor: GoldenMotor 10KW 48V Air cooled BLDC motor
Controller: GoldenMotor controller for 48V BLDC motor with 500Amp Max
Battery: (2) 14S5P backs using Samsung 25R 18650 cells
I roughed everything in, tacked the motor mounts in place and connected all the electric etc. I don't have a charger, but one pack was at 58.1V and the other at 56.1V. I figured when I paralleled them for the first time the 2V difference would not create enough amp draw to give me a problem. Took the bike for a quick spin. All was great. I am going to change the gearing as the power seemed too high up top running 12Tx37T gearing with 16" diameter tires.
Having never done a build like this in any sort of way, I would love to hear what I should do to get the most fun out of this and if anyone is familiar with the Golden Motor controller and programming software.
I only have the motor mounts tacked, so this is still very much a work in progress. I just figured I would post up a few pictures of the bike now that it is a runner 20 or so hours and 2 days into the build.
I wanted to just make a shakedown run, so don't judge me based up this rats nest of wiring:
AJ350925   1 µW
Re: 10KW ATV Build
Post by AJ350925 » Jun 10 2019 9:33am
I checked battery, motor, and controller temperature by hand after a few runs. The motor and batteries were ambient but the controller felt warm to hot. What temps do these types of controllers normally see? The controller in question is a Golden Motor VEC500.
Thanks,
Andrew
flat tire   100 kW
Re: 10KW ATV Build
Post by flat tire » Jun 10 2019 2:40pm
The best controller for you is probably a ASI BAC8000.
Also if you want to ride this thing scrap the chinese atv immediately and get a legit japanese one. You will probably still need to service the suspension, linkages, bearings etc but the ride quality and overall quality will be very much higher.
GeriatricGeoffrey   10 mW
Re: 10KW ATV Build
Post by GeriatricGeoffrey » Jun 23 2019 9:12pm
looks fun. I want one!
