MTD Novotrac conversion
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
agniusm   10 MW
Post by agniusm » Jun 14 2019 7:19am
Bought this for conversion working and after 1.5 years engine gave up. Looking for some info. What would be RPM at the OEM engine shaft generally? I need to pick the system Voltage to make it close to stock. The stock engine is briggs and stratton 259707-0146-01 but i cant find manual or specs cause its prob too old
agniusm   10 MW
Re: MTD Novotrac conversion
Post by agniusm » Jun 14 2019 9:45am
Its difficult. So blade tip speed should be 210-230mph. Blade is 66cm or 26".As much as i could dig up blade pulley is 7" or 178mm
and motor pulley is 100mm OD., thats 1:1.78 reduction.
Need to calculate motor rpm from this :cry:
evblazer   1 kW
Post by evblazer » Jun 22 2019 12:55pm
When etek was being used as a drop in replacement for mower motors it was ~3500 at 48v and fit in fine. I don’t know if specific mowers may have been different but that worked great on my craftsman
24v Challenge Hurricane Recumbent Cute85 powering Tandem crank.
agniusm   10 MW
Post by agniusm » Sep 11 2019 12:58am
Made motor mounting plate:
...and mounted the motor:
Controller also mounted:
Fitted coulomb gauge, 220V charging port, printed waterproof cap:
Most components fitted. Battery, behind 30A charger, Eaton PSU:
Video:
robby p   10 mW
Post by robby p » Oct 13 2019 7:11am
I like it!
