Hello, everyone, sorry if this isn't the correct place on the forum to ask, but i would like to know if someone here knows the british ebay store "SecondLife EV Batteries", i saw an ad about a 60kW motor for cheap, but i don't know if they are trustful or not since the motor is advertised as cheap.
Here is the link for their ebay listings:
https://www.ebay.com/usr/secondlife-evbatteries-com
SecondLife EV Batteries: Trustful?
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Re: SecondLife EV Batteries: Trustful?
Not sure if the site(s) referenced in posts in this list
search.php?keywords=*SecondLife*&terms= ... mit=Search
are the same, but if they are then they may have info you can use.
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
Unfortunately they don't check with the same company, but thanks for answering anywayamberwolf wrote: ↑Mar 25 2021 7:14pmNot sure if the site(s) referenced in posts in this list
Hello, yes they are legit, I had them on the phone the other day, they are having a guy reverse engineer the meiden motors from the Mitsu outlander for integration. They have a sweet assortment of packs and motor kits. They seem to be fully registered in the UK, let us know how it goes! What controller are you planning to use?
