Electric Miata/MX5.
Electric Miata/MX5.
Hi guys,
A lot of you wanted to see the car we put together last year - so here you go! I've been putting off taking pictures till the car was more "finished" - but as it's my daily testbed that day is likely a long way off! So - please excuse all the wires and sensors strapped here and there.
THere is actually surprisingly little to see - I'd have to dissasemble it to get clear pics of much of the work.
So - here is the tatty old MX5 used for the conversion. Here is the drive system (11" 250v Kostov motor and Soliton1 350v 1000A controller from EVnetics)
THis has been coupled to the gearbox and securely mounted to the chassis (without clutch - just as well - you don't need gears with this much power!). There are 4 battery boxes, 1 large one under the parcel shelf in the space originally occupied by the petrol tank, and 3 smaller ones mounted under the bonnet ("hood" for all you yanks). All are built into 3mm alluminium boxes and sealed.
Here's the petrol tank box (holding some 10KW/H) during assembly. And here it is with half of the bussbars connected up (already looking a bit neater!) ..
- Attachments
- Lewes-20110918-00045.jpg (208.56 KiB) Viewed 1806 times
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h pack
Dual Agni Ducati.
Countless ebikes and trikes..
http://www.Jozztek.com
Dual Agni Ducati.
Re: Electric Miata/MX5.
You are a brave man with all that Lipo
http://www.custom-ebikes.com is my new Ebike company serving the Uk and Europe
Free Uk shipping over £49.99
The parcel shelf box has been closed off with an MDF shelf and covered with the original carpet - one of these days I'll take the roof off so I can get pics of it finished up to add here..
The 3 boxes under the "hood" can be seen here firmly mounted around the motor and controller. The untidy balance leads are currently connected to a Methods V4 digital BMS system that is in testing - housed in the small slim ally box. The charge controller can also be seen (white plastic lid and 4 terminals).
Inside the car, I run a Cycle Analyst for day to day data needs, and also have an Arduino logging motor temp, motorside current and a few other things. The controller also puts out some excellent data - but unfortionatly on an ethernet port (which is pretty hard to log unless you fit a PC in the car - not the best choice there!).
So - there you go. A few forum members have been by this way and gotten a scary ride - I'll leave it to them to descibe the performance (most of them look a bit green around the gills when they get out - but that may be my driving:D).
Jozz
Jozz
Dual Agni Ducati.
Dual Agni Ducati.
- liveforphysics 100 GW
Woot!!! You are the man Jozzer! My hat's off to you sir!
Not that much - I've made/used/raced over a dozen vehicles with Lipo packs bigger than 10KW/h, and not had any problems yet. The main thing is to CHECK ALL PACKS VERY CAREFULLY. I don't mean just give them a discharge and charge - that's not enough. Our testing process is to cycle the packs twice looking for any anomolies (high IR cells or low capacity - 3-5% of packs will show faults here), then put them on the shelf for 6 weeks minimum and repeat (often a cell will have a higher self discharge rate than it's buddies and needs to be weeded out so it can't weaken your whole pack - another 2-3% of packs will be found faulty here).Spacey wrote:You are a brave man with all that Lipo
The bigger the pack, the more careful you must be to have all good cells. So far, not a single pack that has passed this testing process has failed in use (out of perhaps a couple of thousand).
Course, that said, a 300KW vehicle is bound to be a bit dangerous..
Dual Agni Ducati.
Dual Agni Ducati.
Thanks Luke - but all very easy - and I knew exactly how it was all going to work out. One of the most boring builds I've done in some ways:D All been done before too (except fot the big Turnigy pack - those DIYelectriccar guys are scared of them still;))liveforphysics wrote:Woot!!! You are the man Jozzer! My hat's off to you sir!
Dual Agni Ducati.
Dual Agni Ducati.
Regarding power consumption, I'm getting about 230wh/m absolute best (and god it's hard to stay off the throttle to do that!) and 600+wh/m worst (that's a lot easier to do!). Average after a couple of thousand miles overall average is 400wh/m, though on a smooth journey it's fairly easy to stay below 300wh/m (giving me about 65 miles useable range).
Currently there are 3 seperate chargers, if I plug them all in to seperate sockets I can charge from flat in around 4 hours.
For heating there a couple of 1.5kw ceramic heating elements (taken from $15 AC fan heaters) that replace the original heating matrix. Methods has kindly built me a programmable controller for these - when I finally get around to fitting it I should be able to just set a cab temp and have it automatically PWM byt he required amount. (Thanks also to Luke for helping out with the IGBT's needed for this).
How does it go? Well - lets just say I need fatter wheels and tyres
The car rarely comes out of 4th gear - it will wheelspin up to 60mph in 4th. 3rd gear is for making smoke, 5th gear is for driving over 80mph (110mph top speed with current gearing and rev limiter).
Jozz
Jozz
Dual Agni Ducati.
Dual Agni Ducati.
WOW. Just WOW. Niiiice. I'm guessing a little over $5.5K for batteries, and no worries about fires.
Thanks to Justin, the forum is open source and NON-commercialized.
you should try to get onto Top Gear UK with that one and do a drag race
Lol, Jeremy Clakson doesn't deserve the pleasure tbh
He'd pretend the battery went flat after the first lap and have someone pretend to push it back to the garage..
Dual Agni Ducati.
Dual Agni Ducati.
Yeah but he'd be blown away by the ~500 hpJozzer wrote:Lol, Jeremy Clakson doesn't deserve the pleasure tbhHe'd pretend the battery went flat after the first lap and have someone pretend to push it back to the garage..
If it would be a drag race against a stock MX-5, the 100m rolling burnout will look very nice on TV
Lol, yeah, a stock car wouldn't have much chance. I took a guy for a ride a few weeks back who had crammed a 4.5l V8 into a Miata - he had spent more money on his and said if he had known what it would be like he would have gone electric instead.
I can get close to 1000A battery side with pack sagging to about 280v on a warm day, so "only" 280KW in. Probably peaking at 300hp to the tyres at best.
EVnetics now make a 1.2MW version of this controller (Called "Shiva, The Destroyer!"). Unfortionatly it won't fit on such a small car - it's a masssive beast! http://www.evnetics.com/products.php?prod=shiva
Jozz
Jozz
Dual Agni Ducati.
Dual Agni Ducati.
- Location: Sydney ..(Hilly part !) .. Australia/ Down under !
Jozz,
how have you built your buss bars ? are you using all bullit connectors soldered onto a bar, or some other "cunning" system ?
I assume you have seen "Rons" packs in the Bat' Tec' forum ?
Awesome work Steve!! I remember seeing the car last time we came down all empty and waiting for the good stuff!! looking forward to having a go in it! ha ha
will have to come down and see you soon, perhaps another spring/summer EV meet? that is if we can get to the petrol pumps
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
That's a lot of Lipo. I'd be scared of that too. You can have a lot of fun with that car.
hmm Richard for Steve that isnt a lot of lipo trust mefechter wrote:That's a lot of Lipo. I'd be scared of that too. You can have a lot of fun with that car.
Yup, Busbars are gold bullets carefully soldered in place.
Paul, come down anytime! Fortionatly I don't need the petrol station to have fun. You can gas up the bike for a ride down south in the sunshine surely? Get Deecanio out for a day too - poor guys, up to yer necks in babies!
Jozz
Jozz
Dual Agni Ducati.
Dual Agni Ducati.
Great job.
1200amp blasts must be something.
Do you have a final total weight/corner weights?
I have dreamed of Miata conversion for some time.
I had a 1993 L.E. limited slip, lowered w/bilstiens all around, 5spd & so light.
I beat that car hard for two years even in the snow(up to 4",before it got hung up)
It is my benchmark car still.
That Colin Chapman fella was really on to something with the lightweight stuff.
With a small'ish Lipo pack I bet you can improve the weight & balance of the car.
Make a great autocross car.
Enjoy
Enjoy
Will do Steve! the missus will always give me time out and the bike does need the run!! its sat idle all winter, Ill check with Deec see how he is fixed, be great to see some video of the car in actionJozzer wrote:Yup, Busbars are gold bullets carefully soldered in place.
Jozz
We can always take the roof off Paul, so it feels more like a bike;)
I'm getting a lot of requests for visit/testdrives - just to say, if anyone wants to come check it out it's always here juiced up and ready to rip - just give me some notice before showing up.
Cheers,
Steve
Cheers,
Steve
Dual Agni Ducati.
Dual Agni Ducati.
Holy hell fire! That thing is amazing!
If Im ever down south I may have to call in. Many thanks for posting the pics Jozzer
The White Warrior - http://endless-sphere.com/forums/viewto ... =6&t=33918
Homebuilt 40mph+ tadpole!
I can testify to the beastly, stomach re-locating power, that is the Jozztek MX5!
My casual drive is a pedestrian Nissan, so stepping in this car really blew my breath away. Having just come from a track day in an Audi R8 and a caterham 7 they both pale into comparison. Electric FTMFW.
On a wet day the only limitations were tyres and a road length! (and balls on the throttle....haha)
When are you getting it on the track??
Wheelspin to 60mph..... Videos or it didn't happen!
Norco Shore2
Was Cellman MAC rear oil cooled then 8x8 9C vented and temp probed now 9x7 9C vented and temp probed!
12 FET controller
62V 18650 home made battery pack
50 km/h
http://endless-sphere.com/forums/viewto ... =6&t=32769
MAC Repair thread http://endless-sphere.com/forums/viewto ... =2&t=34806
Oil cooling the MAC hubbie http://endless-sphere.com/forums/viewto ... =2&t=37972
12 FET controller
50 km/h
Hi Steve...yes will give you plenty of warning that I am coming down and I reckon we can get a bit of video of the wheel spin if i can hold on the camera as well as the seatbelt!! ha haJozzer wrote:We can always take the roof off Paul, so it feels more like a bike;)
Cheers,
Steve
Sweeeeeet!
Norco Shore2
12 FET controller
50 km/h
12 FET controller
50 km/h
