Cushman based build
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
burner1   10 W
Re: Cushman based build
Post by burner1 » Oct 12 2015 3:42pm
I will look for the thread when I have a chance. This entire cart was welded with a 110v MIG. Most welding issues come down to simple things. Clean metal, basic technique, good gas, good visibility. If you can't see you can't weld. Some people get corrective lenses for the welder. I am near sided so when I take off my glasses I am just right. There are times when I actually put on reading glasses.
However, there is something with 110v machines often over looked. They weld better with .023/.024 wire! In fact they penetrate better because the welder simply works better with the thinner wire. For example, here is a backhoe bucket I built using the 110v MIG and .023 wire:
wb9k   10 kW
Post by wb9k » Oct 12 2015 7:12pm
I'm using a 240V stick welder and still developing my technique. I've also got a 120V wire welder here that's on loan from my dad and that has been used on this project as well but the welding we've been doing directly to the chassis has all been with the sticks. Strong, functional welds are not too difficult with a little practice, but a pretty bead has largely eluded me. Once in a great while I'll lay something gorgeous down and wonder how I did it. Proper interfacing of the pieces being welded seems to be a major factor, maybe the missing ingredient in most of my latest ugly welds.
dh
2013 Chevy Volt
2009 Prius with Hymotion L5 PCM
2008 Prius with Hymotion L5 PCM (passed on to daughter)
2011 Rose Xing Fu 48V 500 Watt commuter scooter (now departed)
1984 Honda Interceptor 48V electric conversion motorcycle
Under construction: 2008 Miles ZX40ST truck with altered DC drivetrain
Departed: 2002 VW Jetta TDI which was run for a time partly on WVO.
Amateur radio station run entirely on solar/battery power.
"You can tell I'm a troublemaker, because I plug in my car."
burner1   10 W
Post by burner1 » Oct 14 2015 10:12am
Sorry took so long for me to respond. Lots of things going on.
Your truck project looks pretty cool. I cannot say I know a lot about stick welding. I have done a little. With what the MIG is capable of I would have a hard time spending much time with the stick. Your dad's MIG might be worth spending a little more time with.
wb9k   10 kW
Post by wb9k » Oct 15 2015 8:52am
Please, no apologies needed. Thanks for the feedback. I like the stick welder better for heavier metal because it's far easier to get good penetration with. Taking a cue from you, however, I tried some thinner sticks last night and had some pretty good results. I'll post new pics in the next few days. I'm sure the improvements are the result of multiple things--the sticks, technique/practice/experience, and better setup/prep of the pieces to be welded.
The other nice thing about the stick welder is that it also doubles as the base of a fast charger for my motorcycle!
dh
2013 Chevy Volt
burner1   10 W
Post by burner1 » Oct 15 2015 9:45pm
Learning to do new things is always the good part. Like they say the journey is the fun part. So much so the destination is often anti-climatic.
burner1   10 W
Post by burner1 » Oct 22 2015 11:19am
Finally got a bit of driving time with it. It seemed weak on take off. We used a cell phone GPS ap which showed it 25mph in low gear on flat road.
I got into the controller with USB/Serial connection and reset some parameters on the controller. Now you can feel the front end come up if you get on it very much. Power very appropriate for the unit.
Have a vibration form the misalignment adapter during deceleration. I can deal with that latter.
Diamond plate bed being cut, windshield here waiting to go in and front bumper at powder coaters.
I have a full dash but I am not putting it in yet. I am testing some things I am making right now. The 48V converter on the left is not hooked up yet but is something I will be testing. The red block is a grounding block. The next box has 4 relays in it. Two are for the lights. I set up the bright/dim function to turn off main lights and turn on led light bar.
Second relay turns on turn signal, flasher, brake light controller.
All is hooked up and working well.
4TH relay for horn but not hooked up.
burner1   10 W
Post by burner1 » Oct 23 2015 3:05pm
Vibration was simple problem. Did not mount front transmission plate because it makes it harder to get it out. I look back during start and it was moving. I welded plate in position and vibration gone!
One more thing done!
Drove around at night last night. Driving lights are really good.......Light bar.....is stadium lighting!!!
burner1   10 W
Post by burner1 » Oct 25 2015 8:54am
Windshield is in. Still waiting bumper and bed. Trees looked good for some photos:
Dog has to ride on it every time. Carpet covers right side and seat is quickly removable. What we won't do for our dogs.
SlowCo   1 MW
Post by SlowCo » Oct 25 2015 9:26am
8)
VERY nice build!
burner1   10 W
Post by burner1 » Oct 25 2015 10:12am
Thank you
wb9k   10 kW
Post by wb9k » Oct 25 2015 11:27am
Congrats, it looks great.
dh
2013 Chevy Volt
amberwolf   100 GW
Post by amberwolf » Oct 25 2015 10:16pm
Spiffy! And fuzzy. ;)
oatnet   10 MW
Post by oatnet » Nov 02 2015 4:17pm
Looking good!
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
edcastrovalley   1 kW
Post by edcastrovalley » Nov 02 2015 4:32pm
I can see people asking you "Where did you buy it"! :D
burner1   10 W
Post by burner1 » Nov 03 2015 8:47am
I have been parking on a hill at the shop. I needed to finish the parking brake. I was wondering how long before the cart rolled over the board and down the hill. I got the parking brake done last week and works great. Holds tight on steep hill with little clamping force:
Attached the trailer and hauled 5 loads of leaves to the back of the woods. I was glad it pulled the trailer as good as it did. Backing it up in the soft part to unload the leaves I had to rock it a bit to get it going but otherwise did well. Once it began to move it would fly with the trailer on back.
burner1   10 W
Post by burner1 » Nov 05 2015 9:08pm
I would not say it's done. The dash is not done as it is a platform for me to test different electronic systems. Besides some small things it is otherwise....DONE!....and I could not be happier!
Really like how the 4-link suspension provides clearance in the rear:
burner1   10 W
Post by burner1 » Nov 05 2015 9:10pm
Just thinking about how it started. We skipped the design phase and went straight to construction!:
drewjet   10 kW
Post by drewjet » Nov 06 2015 6:24am
That came out so nice! Really Awesome!
burner1   10 W
Post by burner1 » Nov 06 2015 9:13am
Thanks Drew!
SlowCo   1 MW
Post by SlowCo » Nov 06 2015 6:54pm
As I've posted earlier: This is a very nice build!
If you can, a video of you driving it would be appreciated :mrgreen:
burner1   10 W
Post by burner1 » Nov 06 2015 6:57pm
I will get a video when I can.
Gary
burner1   10 W
Post by burner1 » Nov 06 2015 9:33pm
A lot of people ask me range. What minimum voltage should I limit the batteries to? I am using these batteries:
http://www.batterystuff.com/batteries/u ... 45826.html
drewjet   10 kW
Post by drewjet » Nov 08 2015 6:59am
About 10 volts per battery in Series. Remember to charge every time you use it. Lead prefers to sit fully charged.
burner1   10 W
Post by burner1 » Nov 09 2015 4:03pm
Thanks Drew
burner1   10 W
Post by burner1 » Nov 16 2015 12:29pm
Any guess what it weighs? Hint, I have two 72v 6 battery banks. 12 batteries in total.
