Finally bought one
Great looking electric car and I hope it serves you well yopappamon.
I think that these lead acid battery cars are ripe for packing with lithium, but that would not really be cost effective :cry:
Interestingly, there's a '95 plated one on eBay at the moment. At least the seller is honest with the faults it has.
Would make a great project car and probably wouldn't need too much skill to fix up like new.
1995 Geo Solectria electric conversion Metro
i bot my ZENN car about 4 months ago now. the original Valve Regulated Lead Acid pack was down to about 14 miles range. it is 100Ah rated, 72V so i took it out and exercised it several times from full full charge to total discharge and was able to push the original lead acid pack from about 40Ah where it was when i got it up to about 59Ah. that got me to 29 miles range but i did that range test at limited speeds too.
but i was reading the wikipedia article about VRLA gel packs and they mentioned a reference to some of the original literature on gel packs that showed that the cycle life was extended by stacking the electrodes like pancakes instead of vertically as they are arranged in the flooded lead acid batteries. most people still mount their SLA packs that way, with the electrodes hanging vertically like files in a filing cabinet and that is how it was set up in my ZENN car originally.
so when i put the battery back in i mounted all 6 packs ends down so the plates lay horizontal like pancakes and i expect that will help in maintaining them for another 500 cycles. then i added a hybrid 44Ah 21S lipo/87Ah 24S lifepo4 pack on top of the 6 VRLA packs in the rear battery well. so now it is real heavy in back, wheel spin on starting uphill so i added some cement blocks and jugs of water and my splitting wedges and some workout weights in the front where the old 2 VRLA had been and that got the nose down a little bit but i am now 400 lbs heavier, so up to 1700 lbs.
if you decide to go with VRLA now it would be useful to consider stacking them on end if you do that so keep that in mind when you are laying out the battery compartment. so you can buy batteries that would fit side by side stacked that way in the space you have.
i have been able to get 96 miles range in my best range test so far, all at full speed 35-36 mph. i am using about 144 Wh/mile and the battery is about 13.5kWh.
I'm hoping to revive the agm batteries it has enough to get some good AH reading to size a proper lithium pack. The current owner said the pack was working well until it was left out without heat in sub zero weather. Now he get very erratic mileage per charge, 2 miles one day 10 the next. Maybe only need to replace a cell or two if I'm lucky.
Then use the lead batteries from the car for my solar system?
I would have considered a Zenn, but my commute needs a car capable of more than 35 mph.
each battery has a specific charging point too, and then float voltage, that the manufacturer speciifies for gel and agm packs.
i can get around most places here by using 35-40mph drives, but so much of the urban area is tied together through the high speed motorways. like across the columbia river here, i have been able to get across the willamette river and the clackamas river, but i have to avoid those bridges at rush hour because there is like 2 miles of heavier traffic associated with getting to the bridge and over it before i can get back on to more restricted speed roads. but almost 35 miles from out in gresham to the river loop out by I5.
eventually we will run outa gas and they will set all the speed limits back to 35 to save gas. it would be great now if they would give bicyclists and low speed vehicles a lane on the freeway and cut the traffic speeds in urban areas so low that high speed commuting traffic would avoid driving on those sections of the freeway and go around the outside of the urban areas like they do in europe.
Had to push it on the trailer but we made it home.
Great looking car for the price.
Was just wondering, how do the brakes operate on these cars, are they still hydraulic?
mine is regen, with disc brakes at the end. i have the AC motor/curtis controller so it will regen lightly as i let up on the throttle but the controller will cut in with a strong regen when i push on the brakes. too strong almost but it will regen down a steep steep hill and push a ton of voltage back onto the battery.
The car is in beautiful condition other than one dent and oxidized paint. The interior looks new.
It has the factory Geo Metro brakes with a small vacuum pump for power assist.
The AC has an electric motor belted to the compressor.
It has regen and a switch to turn it off if you are on slippery roads. The accelerator pedal doesn't engage the motor drive until it's press down a ways and it regens when the pedal is released past that point. So it's regen when released, middle coast, down accel. The previous own said the regen is pretty aggressive.
I believe it is just manual steering. But it's a very small car, so shouldn't be an issue.
Congrats Yopappamon!
I look forward to seeing what you do with it!
-JD
Hi,
Great!
I disagree!
Nissan Leaf modules are very cost effective!
The best bang for the buck in large format lithium cells (30 Ah) are used Nissan Leaf modules (2s2p -7.2v nominal, 60 Ah) available for about $140 shipped. Check the links in my signature for more information.
MitchJi said:
I disagree!
I dont have direct experience, but I thought I read that without active cooling, the leaf cells were best at loads below 1c cont, Is that correct? If so, a 600a controller would need a 600ah pack to meet discharge requirements; 600ah would make for a nice range, but it would weigh a ton and be pretty expensive.
-JD
Looks like they're struggling to sell this one, as it got relisted at the same price as before :?
Is it really worth $4,500?
oatnet said:
MitchJi said:
I disagree!
I don't have direct experience, but I thought I read that without active cooling, the leaf cells were best at loads below 1c cont, Is that correct? If so, a 600a controller would need a 600ah pack to meet discharge requirements; 600ah would make for a nice range, but it would weigh a ton and be pretty expensive.
I think 2c is a more accurate figure, but a 600A controller :roll: :?:
156 volt nominal battery pack (from the factory thirteen 12 volt lead–acid gel cells)
22 Leaf Modules = 158.4V nominal 60AH = $2,860
44 Leaf Modules = 158.4V nominal 120AH = $5,720 (full Leaf pack is 48 modules)
So a 120AH pack is 90% of a full Leaf pack. I think the Leaf is a heavier car and it works fine. If anyone wants to build a dragster then I agree that the Leaf Modules are not a good choice.
Hi,
yopappamon said:
Going to go Lithium. Harold found this Chevy Volt pack and we are splitting it.
Sweet :mrgreen:
How much did it cost and where did Harold get it?
evalbum solectria builds said:
Batteries: 58 Calb CA100, 3.20V 100AH, Lithium Iron Phosphate
System Voltage: 185 Volts
Range: 125 city, 105 hwy
Batteries: 13 Deka Group 27 Gel, 12V, AH: 90, Lead-Acid, Gel
System Voltage: 156 Volts
Range: 35 miles on new batts
Batteries: 13 MK Battery 8G27M, 12V, AH: 88, Lead-Acid, Gel
Range: 30 Miles (48 Kilometers)
Can you keep the entire pack? It would be almost 90% of the capacity of the 185Vx100AH pack, which would give you a hwy range of over 90 miles.
yopappamon said:
Anyone know if I can use the battery management system and keep the cells in their pack groups?
AFAIK you are the first on ES to get a Volt pack, be sure and post everything you find out :D.
Hi,
Not in my opinion. $4,500 for a rust bucket?
Your right, 600a is conservative for an electric car, I did just get that 2,000a Zilla controller for my dune buggy build. However I figured going that low would be a more inline with a typical build, like one of the HPEVS AC-35/51/71 motors running the Curtis 650a controller. One of those would require a 325ah pack @2c to achieve a 650a discharge. Many people would want that big of a pack for its range, while many others would not want that mass or expense. :D
-JD
I'm not sure how he found it originally, but it ended up on ebay before we had a chance to close a deal. $1,400 plus $360 freight. Still over a grand cheaper than new lead.
He graciously has let me have the whole thing. I'm very excited to find out my car's controller which normally takes 156 volts, is capable of handling 336 volts. So I can take the 4 cell groups, parallel 2 x 2, and make a 193 volt pack. You should be correct on the range.
I'm hoping between my self (industrial controls engineer) and my brother (retired Delphi Automotive electronics engineer) we can reverse engineer the CAN interface to the battery manager.
I should go from 820 pounds of lead to 450 pounds of lithium (minus the Volt mounting assembly). I may have to add some ballast to keep the tires on the road! :mrgreen:
Hi,
Wonderful :D! That's an excellent price :mrgreen: ! About $3k less than Nissan Leaf modules (about 1/3rd the price)! Thank you! Time to google the Volt pack specs and to start looking for a used Volt pack!
I hope you start a dedicated thread on the Volt pack and convince me to change my signature!
Under $5k for a nice EV, with a range equal to or better than a $28k Nissan Leaf! Congratulations! Well done!
How many amps is the controller rated for?
The battery is on the truck. Should be here by Thursday.
I have found a guy who has already put a Volt battery in this same car. He said the weight reduction really makes the car perform. He only used 2 of the 4 modules so he has reduced the weight by over 600 lbs and gets over 50 miles range.
I could be on the road in a week or so!
Thought I had the shipping under control. Talked to the shipper, found out the hazmat category and labeled it accordingly. Declared all the relevant hazmat info. Shipper picked up the battery and now wants an MSDS on the battery or they wont deliver.
Called Chevrolet, called a dealership, called LG Chem. No luck with Chevy or the dealer. LG was helpful, refers me the person at the factory who could help. That person asked why I needed the Msds and what my relationship was to LG. I explained what I was doing. Fingers crossed I gets positive response tomorrow.
Otherwise its road trip to Minnesota!
