Electric kart
- Doctorbass 100 GW
- Contact:
Re: Electric kart
Here are some description of the errors of Sevcon:
http://acgcars.us/support/SEVCON_Faults_Table.pdf
Doc
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Re: Electric kart
Finally solved my DSP error problem and it was a very easy fix.
Just I did not saw that before that in motor signal wire socket one of the female pins were bad.
And then male pin inside female pin was moving and there was contact and not contact depending of the movement.
But to get to the cause I resoldered just in case male part of that socket and event opened motor encoder area to see are there everything ok.
And I tested with tester wires between motor and socket and between sevcon and socket and these were good. And only then I bothered to look at the socket itself
replaced this bad pin and now everything works like new.
Here is picture of that bad pin
Electric kart 60kw: viewtopic.php?f=34&t=68543
100v 35Ah LiPo battery: viewtopic.php?f=14&t=97763
100v 25Ah LiFePo4 battery: viewtopic.php?f=14&t=85912
Scooter battery: viewtopic.php?f=14&t=108227#p1582703
Re: Electric kart
Where can I get that Z-force motor from?
Re: Electric kart
I got my motor from this thread, but that was a year agoBadkad wrote:Where can I get that Z-force motor from?
https://endless-sphere.com/forums/viewt ... 30&t=81009
Re: Electric kart
Tested Zero air-through cooling this weekend in a race that was very acceleration and braking intensive and motor was not able to cool itself enough by pumping air through by itself.
Theoretically inner rotor should act as tesla turbine and I actually felt the air through motor very well when wheels in air and rotating in 5000rpm.
So it seems I need to install active air cooling, two powerful centrifugal vents to pump air trough at faster speed that motor itself can do
Video of first race when I hit the wall, because I lost rear brakes also due overheating
https://www.youtube.com/watch?v=uEmZBzaQNuo
Re: Electric kart
Installed forced air cooling to the motor and tested acceleration.
This should be not official word record with electric kart acceleration.
https://www.youtube.com/watch?v=2Xp41u1y9KI
2,640 seconds to 100km/h and 0-60mph is even faster in 2.577 seconds as 60mph=96,5km/h
This should be current official record I think to 60mph
https://www.youtube.com/watch?v=r0b6UoxqrPE
But in that track forced cooling is not enough for 10 laps. I can do sprint like 7 or 8 laps only.
- Attachments
- Cooling1.jpg (109.05 KiB) Viewed 5401 times
- Cooling2.jpg (139.58 KiB) Viewed 5401 times
- Cooling3.jpg (116.17 KiB) Viewed 5401 times
- Cooling4.jpg (119.17 KiB) Viewed 5401 times
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Re: Electric kart
As an experiment you might try flipping the fans and expanding the duct so that they suck the air thru the motor instead of trying to force it in.
When I did computer cooling I found that worked better (less noise, which means less turbulence, less wasted power, more cooling airflow).
Or use a single larger fan shaped just like those but with it's intake the size of the outlet ring on the motor, and place it directly against that outlet ring (or spaced a short distance away with a ring between them).
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
- Location: Sydney ..(Hilly part !) .. Australia/ Down under !
Re: Electric kart
Very impressive 0-100 run.....mainly because i dont figure how you got enough grip.
Every kart i have used (regular 2t race karts) have always had more power than grip..even with good warm tyres.?
Also , depending on your definition od a "kart" , im sure you are aware of the 1.51 sec time from this...
https://youtu.be/n2XiCYA3C9s
Re: Electric kart
Can't do that because motor has opening around encoder in one side and opening in the edges in sprocket side. So rotor itself using tsentrifugal force will push air from encoder side to sprocket side.amberwolf wrote:As an experiment you might try flipping the fans and expanding the duct so that they suck the air thru the motor instead of trying to force it in.
And I can't install blower in sprocket side for sucking air.
I will try to install two more blowers if I have time.
But in the end it is very hard to remove 4kw to 9kw of heat so rapidly like I need in the racetrack.
If I stop then it cools very fast.
Re: Electric kart
When I did acceleration test last year I had old hard tires and outside was 11 degrees.Hillhater wrote:Very impressive 0-100 run.....mainly because i dont figure how you got enough grip.
This time we had soft White VEGA tires that we had run like 20 laps. So grip was very good.
We also started in the corner where there was rubber in asphalt but even then he succeeded to spin tires couple of times
Yeah, I know this, but this is 4WD and not comparable to kart. They also have suspensions and bigger tires (wider and bigger in diameter)Hillhater wrote:Also , depending on your definition od a "kart" , im sure you are aware of the 1.51 sec time from this...
But how did they measured the time? Formula student actually have in competition acceleration test, but this is 0 to 75 meters test.
And I would like to officially measure my time, but I do not now what equipment I should use that will make it official?
PS! I also analyzed again and used data from cycle analyst started the clock when speed went to 1km/h.
And with that it's 2,507 to 100kmh. It took 40 meters to reach it.
https://youtu.be/eb4UeH0XcJU
- craigcalfee 1 mW
- Contact:
Re: Electric kart
Your fan size seems too small. When we bench tested that motor, a lot of air pressure is generated. That fan doesn't look like it would add much velocity to it. And the ducting is not so good for laminar flow. But good progress! Looking forward to the next improvement!
Craig Calfee
Calfee Design
Bicycles, E Bikes, NuVinci N171 hubs and parts, E Motorcycles, Prototyping and Consulting
calfeedesign.com
Calfee Design
calfeedesign.com
Re: Electric kart
Thats the issue...Once you diverge from the common FIM/CIK specification a "Kart" , (motors, chassis, wheels , tyres etc) then you are in an "unregulated" area and as such there is no restrictions on what you use or what you call it.nuxland wrote:[Yeah, I know this, but this is 4WD and not comparable to kart. ......Hillhater wrote:Also , depending on your definition od a "kart" , im sure you are aware of the 1.51 sec time from this...
there are karts in the USA that run 6", 8", and 10" dia x 10" wide tyres, karts with 4 wheel drive, fully enclosed bodywork, and a whole range of odball drive systems.
But i basicly agree, a "Kart" should have as a base, a solid rear drive axle, no suspension .and a ? Limit on wheel size.
Re: Electric kart
I'm using two of these fans 09533GA-12Q-AA-00 and according to specs they provide good airflow against pressure.craigcalfee wrote:Your fan size seems too small. When we bench tested that motor, a lot of air pressure is generated. That fan doesn't look like it would add much velocity to it. And the ducting is not so good for laminar flow. But good progress! Looking forward to the next improvement!
I'm considering to add two more or upgrade to bigger one, but I have little room there so need to think of something.
- Attachments
- Blower.png (158.1 KiB) Viewed 5332 times
Re: Electric kart
You could bump the fan voltage up to 15-16v.
It looks like the air passages through the motor are fairly small, so you need those centrifugal blowers. I can't tell from the pics what kind of cross sectional area the air passages have inside.
You could also blow air over the fins on the outside of the motor but it won't be as effective as blowing through the windings.
Re: Electric kart
They built a brand new kart track near Tartu, Lange. It's not finished yet and will open spring 2018 but they let me try out that track.
In in the same day there were also one guy with Estonian formula student car from the year 2008. So we both tested that track.
I recorded a video also. But as this was our first run on that track we were easy and track was also moist a little bit.
https://www.youtube.com/watch?v=6R7st79kbps
I think this was my last driving this year as it's already minus degrees in night time.
I hope I can finish installing second controller + motor + battery to kart and try 1/4 mile next spring with 110kw and 210kg kart
Re: Electric kart
Great video!
Love to see your progress on installing the second controller, motor and battery. Curious what your 1/4 mile time will be
Re: Electric kart
Hi Nuxland again! Very busy last months...
There are few things that I can comment, first one, you are getting better and better!
-When you are on field weakening state, it is caused by the motor is above max modulation, meaning, back emf is equal to max volts delivered to the motor due to higher rpms than nominal. Then, needs to compensate angle of shot with -id to still giving you torque at higher rpms, but have 2 issues, as soon you change the angle of shot you lose efficiency rapidly, you must to consider then change the final ratio to be on max torque curve. And the fatal and second one, if you abuse of this and lets the motor heat up enough, you can demagnetise permanently the magnets......
In the other hand, I suggest to check if,
-Encoder is at its best ofset.
-If field weakening gains operation is modulating properly, enough -iq amps?.
-Ls is tracking?
If you send me screenshots of dvt motor data config and logs of vehicle interface during a run I'll try to help you if you need it.
Regards!
Luigi
-Ls is tracking?
Regards!
Luigi
Re: Electric kart
Awesome results and evolution!!!
Thank you Justin! Life is so much sweeter with this forum...
Re: Electric kart
Yeah this have been an epic thread. Look forward to see what is possible with dual controllers.
Re: Electric kart
looks fun. estimated cost so far?
Re: Electric kart
Was having I little setback with battery. Forgot motor cooling fan dc/dc connected to battery for 2 months. And battery was only 10Ah from 40Ah. Result was devastating 0V the whole battery. From 68 cells or 34 cellpairs 11 pairs or 22 cells broke (did not hold voltage anymore).
This was the first image I made when using laboratory power supply to get inital voltage back to the battery. Here I have charged cells and disconnected problematic pairs and concluded the pairs I have to replace. Then I charged them to full and it seems 3 more pairs are not completly ok and their voltage dropped event other did not. So I'm now in the middle of replacing these cells also. And it had taken me more than two months, so my plan to install two controllers has now postponed until I get this battery working again.
Usually I checked my battery once or twice a month, but this time forgot. Never again will this happen again
Re: Electric kart
Got the battery back together today to test it with bigger current. So installed it on kart and simulated load with brake (you can do it only like 5s and then you have to cool brakedisk back down
. But I'm impressed with these cells. They were at 0V for some time and can still give out 350A and drop only to 2,9V
Have to wait until snow is gone, to test with more current (it can be done only outside)
But sad part is that 24 cells from total of 68 got hurt with it and had to be replaced. Some of them can hold some charge and I think there is at least 4 that can hold 3.2v. So I can make 12V battery with these to my honda GX200 with turbo and fuel injection if I will ever finish it
Re: Electric kart
Hey - found your thread!
That weight is quite good. My 80cc shifter with me and fuel is about 208 Kg. Of course it doesn't help much that I'm about 95 Kg's of that weight. I'd really like to pursue a setup like this instead of upgrading to a 125 KTM setup with the Mechatron paddle shifter.
EKartGo - Building a kart for 100cc TAG competition
YouTube Channel: https://www.youtube.com/channel/UC6RfJ2 ... vHEzLcqKUg
ES thread https://endless-sphere.com/forums/viewt ... 4&t=107963
KartPulse thread https://forums.kartpulse.com/t/ekartgo-project/5857/1
Bryan
Bryan
Re: Electric kart
Got myself a iCharger 4010Duo to balance my repaired pack (even made two sets of charge and balance wires with crocodile endings).
(RTFM is a must next time) So connected both sideof the charger to same pack and caboom one side (right one) of charger was dead. Anyhow I then balanced the pack with one side. And a good thing is that iCharger also calculated IR-s.
PS! repaired also the charger afterwards, only 4x 15A fuses and one diod where burned away
And as always did not read the manual at first
