Make Own Custom Pouch 12v 100 Ah battery (need help)
juzamthai   10 µW
10 µW
Post by juzamthai » Aug 18 2016 5:02am
Hi
I have a project to design (for my own usage) 12v 100 Ah battery.
I choose LiFePO4 or prismatic Pouch cells (Flat ones)
The target is 100 Ah : So I will use 4 x (20 Ah cells) to make (12v 20 Ah cells).
Then I need 5 of these pack, to make a (12v 100 Ah Battery).
I will need 5 x 12v 4s BMS
And 1 x 12v BMS (that can handle from 5 minumum to 10 x 12v cells.
Also, If I need bigger plant, like 500 Ah
I will have to get another BMS to balance all 5 x (12v 100 Ah) batterie.
Can someone point me to a good BMS supplier, where I can find all these ?
Is my knowledge about all this correct ?
How will I be able to check single cells, see if it working properly ?
Hope you can help me.
All this is very interesting.
Also what do you know about aluminium Battery cells ?
Should last longer on Paper, but anyone has return about it ?
Thank you.
marcexec   1 kW
Re: Make Own Custom Pouch 12v 100 Ah battery (need help)
Post by marcexec » Aug 29 2016 3:43am
Welcome to the forum!
You don't have to build 5 times a 4 series(s) pack.
You can parallel(p) 5 cells to have the equivalent of one 100Ah cell. Test the cells individually and balance charge them before you do this!
Then you can use 4 of these to get to 4s5p, an only need a 4s LiFePo4 BMS.
I have used 4s LiFePo4 as a motorcycle battery without a BMS see https://endless-sphere.com/forums/viewt ... 14&t=25846, but wouldn't recomment this for the investment you have planned here.
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
