Hillhater said:
Does any EV have a "neutral" drive position ??
I dont know of any, and wonder what the implications of extended tow/driving of the motor.
At the least i would expect considerable drag, and probably heat generated in the windings.....but maybe worse ? :?
Maybe a simple 2wheel, braked, tow dolly would be the go ?
Many converted manual transmission cars/trucks can obviously disconnect from the motor but those are unique one-off constructions. I’ve not ruled that out yet….
But on factory EV’s I don’t have a problem with the motor and speedometer racking up towing miles. Surely the motor can handle 100k miles of rotation, powered or unpowered? Of course the towing miles on speedometer would be crazy for warranty and service. I understand why factories wouldn’t endorse flat towing.
However, I learned something about the 500E which employs technology to prevent the driver or passenger from exiting the vehicle at slow speed.
Pg 10 from this 2015 owners manual: file:///Users/AirMac/Downloads/2015-FIAT-500e-UG-3rd-TwoUpCover.pdf
Auto Park
The Auto Park feature automatically places the vehicle into PARK if there is any indication that the driver may leave the vehicle while the drive mode indicator is in the D (DRIVE), N (NEUTRAL) or R (REVERSE) modes.
Auto Park is enabled under the following conditions:
– READY mode (12 Volt ON and High Voltage ON).
– Vehicle speed is below 2 mph (3 km/h).
NOTE:
• Auto Park feature only occurs once per key cycle.
• Auto Park is disabled above 2 mph (3 km/h) and the drive mode range will be maintained.
The instrument cluster will display an Auto Shift To Park message and chime once when Auto Park action occurs.
Mode Of Operation With Key ON
Auto Park will be engaged when the drive mode is in DRIVE, NEUTRAL or REVERSE and the following conditions are detected:
• Seat Belt is unlatched
• Brake pedal is released
• Driver's door is ajar
• Vehicle speed is below 2 mph (3 km/h)
Mode Of Operation With Key OFF Auto Park will engage as you turn off the key while in gear/neutral and speed is less than 2 mph (3 km/h).
This is a major PROBLEM for towing in N since the Auto Park feature will engage below 2MPH.
Well, I guess a solution is to flat tow in D (seatbelts latched) and never Reverse? Maybe slow Reverse in D isn’t that big of deal while in D? Leave hill assist OFF…
Too bad they created “Auto Park” mode for a seemingly lame problem?
And maybe the Park actuator can be hacked?
The Park override found on pg 72 appears to reset each time the system is cycled ON.
I’m very close to buying a cheap used 500E, adapting a tow bracket and carefully test it out. Rig one of my RC video cameras and TX/RX up inside the cockpit to monitor what’s happening?
Even if I seriously screwed it up, they’re not that much money and if I could solve the challenges of flat towing it would be the nearly perfect Electric TOAD for many RV’ers.
2 wheel dollies are fine for occasionally hauling a car here/there. Trouble is where to stow it at home and parked/camping or visiting densely populated areas? My coach is already 40’ so not much room to spare in most campsites.
