KiwiEV VW beetle Nissan Leaf high power
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
kiwiev   10 kW
Post by kiwiev » Jul 22 2017 4:14am
Hi Gents and Ladies
We would like to prove this idea thru EVTorque our conversion company using a Nissan leaf and after market high powered AC controller. :D I think there is a good DIY market for this idea.
I have been tossing around this idea for a while, the need to make a quick, small, cheap and reliable street car / track car.
There are more and more EV used parts becoming available its time to put them to good use and re-cycle high powered style, I have to thank Luke (live for physics) and Arlin (Arlo1) with his hacked Honda CRX Nissan Leaf build.
The Smart fortwo has a few good characteristics:
-cheap AUD$3-5K for a tidy 2004-2006
-no power steering
-light weight 720Kg
-rear wheel drive
-already manufactured electric
-have recess in bottom for batteries
-design has a built in roll cage
-TOYO R888 tyres fit straight on original wheels
-small
So my thinking is this:
-Nissan leaf drive less than USD$1000
-Controller we are working with Scott drive to dyno and tune a 150KW nominal 200KW peak controller AUD $5000
-Or Rinehart controller
-Chevy Volt battery packs 14KWH AUD$5000
Let me know your thoughts and ideas
Cheers Kiwi
kiwiev   10 kW
Re: KiwiEV Smart fortwo Nissan Leaf high power
Post by kiwiev » Jul 22 2017 4:43am
so I was thinking either 2 or 3 Chevy volt packs 300 or 450 volt I guess its going to hurt either way in the pocket and the fingers.
So the Scott controller can be wound up to 750 phase amps @ 300 volt 225KW not sure if Volt pack can give that
Or @ 450 volt 337KW
I think that would be a handful :twisted:
Cheers Kiwi
Here is a ICE version racing
kiwiev   10 kW
Post by kiwiev » Jul 22 2017 5:03am
Here is a DC conversion from over at DIY electric car forum
Cheers Kiwi
EPowerRacing   10 µW
10 µW
Post by EPowerRacing » Jul 22 2017 11:09am
I like the idea! The Volt pack would easily supply enough power (see attached test report). What about just using the leaf pack? It is probably 100 kg heavier, but is 24 vs 16 kW-hr, and would make it simpler - only one donor vehicle.
batteryVolt1078.pdf
(1.37 MiB) Downloaded 50 times
Warren   100 kW
Post by Warren » Jul 22 2017 11:56am
The guy, in the video above blew up his 11" motor, and switched to a 9"...probably much better for his drivetrain life. He also switched from Headways to a Volt pack.
http://www.evalbum.com/4155
kiwiev   10 kW
Post by kiwiev » Jul 22 2017 3:25pm
EPowerRacing wrote:I like the idea! The Volt pack would easily supply enough power (see attached test report). What about just using the leaf pack? It is probably 100 kg heavier, but is 24 vs 16 kW-hr, and would make it simpler - only one donor vehicle.
Thanks love your Cobra btw so what is your battery pack and specs?
Not many donor's down here in Australia so I have to source in the states by parts.
Cheers Kiwi
kiwiev   10 kW
Post by kiwiev » Jul 22 2017 3:26pm
Warren wrote:The guy, in the video above blew up his 11" motor, and switched to a 9"...probably much better for his drivetrain life. He also switched from Headways to a Volt pack.
Yeah so looks like a volt pack fits in.
Cheers Kiwi
EPowerRacing   10 µW
10 µW
Post by EPowerRacing » Jul 22 2017 7:55pm
Our pack is from a Kia Soul EV. 27 kW-hr and only 400 pounds. We also figured out how to use the OEM BMS and charger, so could help if required. The only problem is availability.
kiwiev   10 kW
Post by kiwiev » Jul 22 2017 10:06pm
EPowerRacing wrote:Our pack is from a Kia Soul EV. 27 kW-hr and only 400 pounds. We also figured out how to use the OEM BMS and charger, so could help if required. The only problem is availability.
I can wait do have dimensions?
Price?
Thanks in advance Kiwi
liveforphysics   100 GW
Post by liveforphysics » Jul 22 2017 10:14pm
Should be a ripper, but personally having used a few RMS controllers I would go for Arlins DIY controller. It might cost the same or more than RMS, but the power is huge.
kiwiev   10 kW
Post by kiwiev » Jul 22 2017 11:08pm
liveforphysics wrote:Should be a ripper, but personally having used a few RMS controllers I would go for Arlins DIY controller. It might cost the same or more than RMS, but the power is huge.
Thanks Luke
I would like Arlin DIY controller but I am now a dealer for Scott Drive and can get them cheap they can also do angle phased and few other things.
And being a New Zealander thought I would give a New Zealand company a go.
Cheers Kiwi
Post by liveforphysics » Jul 23 2017 1:48am
Thanks Luke
Cheers Kiwi
Sweet! Maybe having local support they can parallel 2 controllers to the same motor? Excited to see more EV controller companies, I hope they thrive and do well.
Arlo1   100 GW
Post by Arlo1 » Jul 23 2017 10:00am
I always wondered how those Scott drive controllers would work out. I watched a couple dead end threads on DIY electric car about them but never saw anyone actually using one yet.
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
EPowerRacing   10 µW
10 µW
Post by EPowerRacing » Jul 23 2017 2:15pm
We took the stock pack and reconfigured it by flipping the two halves and placing them back to back. We found this to be a more convenient form factor. It allowed us to re-use all the BMS wiring without making any changes. We built a new cradle made out of steel tube, then covered it with stainless steel for protection. The dimensions of our stainless box are 16Wx18.5" highx54" long. (which makes the stock pack ~ 37" w x 8" hx54" long.
kiwiev   10 kW
Post by kiwiev » Jul 24 2017 3:43am
So the director of finance AKA my beautiful wife and put the foot down on any more cars and use what I have.
So here is what I have. :lol:
What do you think??
It ticks some of the boxes
Cheers Kiwi
kiwiev   10 kW
Post by kiwiev » Jul 24 2017 3:44am
EPowerRacing wrote:We took the stock pack and reconfigured it by flipping the two halves and placing them back to back. We found this to be a more convenient form factor. It allowed us to re-use all the BMS wiring without making any changes. We built a new cradle made out of steel tube, then covered it with stainless steel for protection. The dimensions of our stainless box are 16Wx18.5" highx54" long. (which makes the stock pack ~ 37" w x 8" hx54" long.
Thanks mate
I pulled the trigger on 2 Chevy Volt packs to day just cant argue with the specs and I can add a few more modules for above 400 volts and a bit more capacity.
Cheers Kiwi
kiwiev   10 kW
Re: KiwiEV VW beetle Nissan Leaf high power
Post by kiwiev » Jul 26 2017 6:11am
Chevy volt packs on the way do you think I should parallel them up for 36kwh at 360 volts or at say 8kwh to one pack and get to the high 400 volts at 26 kwh.
This would be lighter and provide some serious power into the Leaf motor like Arlin1 is doing.
Cheers Kiwi
