John Deere E-Gator rebuild(Picturestory)
E-Chopper   10 W
Post by E-Chopper » Nov 21 2017 12:38pm
Hello to all !
This year i had the option to buy a cheap but rosty E-Gator for a few bugs .
It was lot of hard Work !
So i made lot of Photos from the rebuild . so lets start the Picture-Story .
inside the E-gator
the motor
the dead Battery
"Thunder is good,Thunder is impressive;
but it is Lightning that does the work !
-Mark Twain
E-Chopper   10 W
Re: John Deere E-Gator rebuild
Post by E-Chopper » Nov 21 2017 12:49pm
so i start work
so much dam rost everywhere !
paintwork
special paint for more grip
-Mark Twain
E-Chopper   10 W
Re: John Deere E-Gator rebuild(Picturestory)
Post by E-Chopper » Nov 21 2017 1:10pm
for the next step i demount the DC-Brushmotor
i also demount the axel
the rame is a real lightweight and easy to lift
and again rost everywhere
after paintjob
so on the backside and batteryspace all rost is terminated
next step the front
again lot to paint......
................more paint
-Mark Twain
E-Chopper   10 W
Post by E-Chopper » Nov 23 2017 10:17am
Hello again some new Photos
here is a lost picture ...work on the axel
now its getting interesting ...............
the controller -gasket was broken i made a new seal (luck there was only a little oxidized inside )
inside the controller
so next work clean the DC- motor and repair the dead TachoPOL-Wheel
much dirt inside
the old TachoPOL was broken so every broken Magnet build two new poles (North andSouth)
Thats the reasen why the motor turn to slow !
i build a new tachoPOl with little neodymmagnet N-S-N-S-N-S
after clean the motor i chek the Brushes they look really good so i dont change them !
-Mark Twain
E-Chopper   10 W
Post by E-Chopper » Nov 23 2017 10:25am
So next step was build a new Battery i am not really a fan of acid Battery so i build a new liion Battery .
Old Battery more then 200KG the new one under 30kg :-)
I buy cells and solder it !
close to fin
so i want that the Battery look like a original battery from a shop .i think it will look like a profesional Battery
i also mount a 200AMP fuse and a main switch !
-Mark Twain
litespeed   100 kW
Post by litespeed » Nov 23 2017 12:41pm
Great job and well documented.
Super cool.
Tom
E-Chopper   10 W
Post by E-Chopper » Nov 25 2017 10:47am
thank you !
so now i show some pictures of modified the Seat-holder and i mount seat belts for safty !
-Mark Twain
E-Chopper   10 W
Post by E-Chopper » Nov 25 2017 10:59am
work start on driver cabin so can drive it all weather .
now i mount the glas
after paintjob its look much better
-Mark Twain
E-Chopper   10 W
Post by E-Chopper » Nov 25 2017 11:11am
so all work is done !
so sticker are also very important feature
picture from side
frontside
backside the ATV the 10km-plate is old meantime i had a street license and it drive faster
i mount 2 lights on roof
i change the halogen against led with less Watt but more light
So thats the end of the story i am really happy with it and my little son love the E-GATOR( john green deere)
meantime also my wife love to drive it :mrgreen:
-Mark Twain
litespeed   100 kW
Post by litespeed » Nov 25 2017 1:51pm
What an excellent build!
Great job.
Tom
markz   100 GW
Post by markz » Nov 26 2017 11:00pm
Looking sweeeeeet!
Whats the Ah and voltage of your new battery?
New cells or used?
Brand name of cells?
Whats your range calculations?
I dig the build!
E-Chopper   10 W
Post by E-Chopper » Nov 27 2017 6:25am
Oh yes sorry i forget the data :
the cells are old 2014-2015 but not used = (0.0 Cycle )
i buy it for around 2,50 euro- pice (260 pices)
Cell data =Panasonic NCR18650PF 3.6 V 2900 mAh (10Amp max )
i solder 13s *20 Cells so i got 46,8 Volt nominal and 58 Ah
i know that 58ah is not much but i calculate this Vehicle for a max range that i need is 10-12 km so it is fine .
the Controller does made 400A max for short time but continous it is between 100-130 Ampere .
First test drive i controll the heat of cell´s but the never get real hot ..so this DIY accu is fit perfectly .
And the fuse is a 200amp fuse so there is no Danger to the Cells .
So i made some calculatoins and the range with this accu should be around 15km .
The maximum range i drive is now is 12 kilometer and the Accudisplay is not in the red range. I can not really tell you the real range its difficult to tell .
Maybe next time i made a video> offroad it is a really pure fun you can even drift the turn of the road .
Greetings Martin
-Mark Twain
whereswally606   100 kW
Post by whereswally606 » Nov 27 2017 11:48am
I had never see one of these before and then yesterday my wife dragged me out to greenacres petting zoo in Wales for my 1 year olds amusement. Was a horrid day for weather. Animals were good but it was a bit run down as a place (its unfortunately a little oversold on their website). Anyway I saw an e-gator in the flesh and ironically a real gator/croc in the reptile house. Thanks for sharing I enjoyed the pictures.
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
fechter   100 GW
Post by fechter » Nov 27 2017 2:34pm
Great job. How many Ahr were the original lead-acid batteries? Lithium batteries don't suffer so much from Peukert effect, so even if the lithium pack is less Ahr, it might perform better.
E-Chopper   10 W
Post by E-Chopper » Nov 28 2017 2:59pm
first ! Hello again thanks for your post´s and interest in my Project.
Originally there was 8 pice acid Battery inside one had...... 6Volt -225 Ah (Trojan T-105 ) a cell had 28 Kilo so 224 Kilo .
But this Battery was all dead ! i took them to Recycling !
I know that 225 Ah acid Battery would perform longer ...but on other side they much heavier and the point of matter> the price of 8 new T-105 Battery was 1496 euro (one 187euro) the Liion Battery coast was around 700 Bugs .
Liquid Acid Battery you always must watch them fill Water in it .....
Liion you only have to watch to stay over 2,8 volt per cell :D
grettings
martin
-Mark Twain
armandd   10 W
Post by armandd » Mar 18 2018 12:06pm
Nice project! I wish I had one golf cart like this to modify.
