Industrial Motor gokart build
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
Quinc   10 W
Re: Industrial Motor gokart build
Post by Quinc » Apr 02 2018 5:06pm
Video on post #43 :bigthumb:
Not sure if I am going to be able to solder 2/4awg to my motor so researching other options like adding more 8 awg wires and I came across this calculator. I might try adding two more more 8awg wires and it will be the equivalent of running 3awg.
Putting this here so I can find it again. :idea:
https://www.wirebarn.com/Combined-Wire- ... ep_42.html
markz   100 GW
Post by markz » Apr 03 2018 2:58pm
I have used that website before myself, it sure is handy :!:
Quinc   10 W
Post by Quinc » Apr 11 2018 11:57am
Yay! Orders all shipped from HK! Also have my anderson connectors and 4ga wire ready to rock.
Picked up a charger. Should charge a little quicker then Imax b6. :lol:
EV-Peak C6 High Power LiPo/LiHV DC Battery Charger (6S/45A/1140W
some motor porn of the Leeson with her dress off.
Quinc   10 W
Post by Quinc » Apr 30 2018 11:11am
Moving at the speed of slow.. Young kids and spring time honey do's..
Quick update:
Home made crimper and 4ga wire installed on the motor: I drilled the cover and added a grommet so she is still sealed.
Quinc   10 W
Post by Quinc » May 03 2018 10:30am
garolittle   100 W
Post by garolittle » Sep 05 2018 7:57pm
Any updates? Awesome project :D
Quinc   10 W
Post by Quinc » Oct 30 2018 12:07pm
garolittle wrote:
Sep 05 2018 7:57pm
Now that Jetski season is coming to an end (https://www.youtube.com/watch?v=3o4kbAhwFwo) I am starting back up on this project. Picked up the rest of my connectors and dusted the soldering gun off.
Quinc   10 W
Post by Quinc » Nov 18 2018 10:59pm
Started on the battery wire! Using 300amp 1/0GA welding connectors. (Very much overkill, but cheaper then Anderson)
8S configuration
12S configuration
Also putting this here for later on programming the kelly. viewtopic.php?f=2&t=92899
garolittle   100 W
Post by garolittle » Nov 19 2018 5:22pm
Larger wire is always better!! :P Awesome project! Keep us posted.
Quinc   10 W
Post by Quinc » Nov 19 2018 5:24pm
First time configuring a kelly KDS48400. Any advice is most welcome!
Anyone know if the foot throttle is 0-5 or 1-4v?
CobraJet   1 W
1 W
Post by CobraJet » Nov 21 2018 5:52am
This looks like so much fun, I would love to see video of the cart in action!
nuxland   100 W
Post by nuxland » Nov 27 2018 12:08pm
do you have link for these "Using 300amp 1/0GA welding connectors"
I will build 6p usin 8awg wires, so was thinking of crimping one pack positive and another negative together.
because anderson 350 is too bulky, but this looks promising and can keep up my average 200A and peak 650A :)
Quinc   10 W
Post by Quinc » Nov 27 2018 12:50pm
nuxland wrote:
Nov 27 2018 12:08pm
https://www.ebay.com/sch/sis.html?_nkw= ... 2749.l2658
Upperfoot   100 mW
Post by Upperfoot » Nov 29 2018 4:26am
The welding connectors (DINSE) are good for the price, I use them in conjunction with the panel sockets for my positive and negative ouputs of my battery box.
https://www.ebay.co.uk/itm/Welding-Cabl ... 2821006191
Quinc   10 W
Post by Quinc » Dec 13 2018 6:06pm
Made some good progress over the last couple of nights. Finished the battery box and got everything mounted and wired up. Then I ran into the issue that I cant get the damn controller to power on.. Anyone know the secret to these things? The contactor has a +/- on it with the small wires that go to a key switch and to the controller. I assume the pwr cable goes to + and the gnd to the -? But no luck getting the green light..
Quinc   10 W
Post by Quinc » Dec 15 2018 2:30am
My dumbass had the J1 cable plugged into the J2 port.. All of the wiring was correct. Now I am balancing charging the lipos, then need to fix a cracked brake line and we are ready to rock!
Upperfoot   100 mW
Post by Upperfoot » Dec 15 2018 6:07pm
Looking good Quinc! Get a video uploaded of it spinning up!
Quinc   10 W
Post by Quinc » Dec 15 2018 7:54pm
Need to make a few tweaks here and there, tighten the chain, but other then that she is a success! Next I will take her out for a top speed run and better footage.
https://www.youtube.com/watch?v=JsHu-KVKaOY
garolittle   100 W
Post by garolittle » Dec 16 2018 3:28pm
That thing is a monster! I am jealous! What top speed to you expect? Great work.
Quinc   10 W
Post by Quinc » Dec 16 2018 4:51pm
I am restricting her to only 5100rpms right now. According to the calculator she should be able to do 26mph. But the torque to get to 26 is awesome. At full power 7500 rpms she will probably do mid 30's.
https://www.bmikarts.com/Go-Kart-Gear-R ... Calculator
garolittle   100 W
Post by garolittle » Dec 16 2018 8:09pm
Sweet!
Quinc   10 W
Post by Quinc » Dec 17 2018 12:07pm
garolittle wrote:
Dec 16 2018 8:09pm
Sweet!
Thank you!
It stopped raining today so going to tighten the chain and get the gopro out. Should hopefully have a better video up shortly.
garolittle   100 W
Post by garolittle » Dec 18 2018 9:42pm
Good deal. Looking forward to the video footage. :bolt:
Quinc   10 W
Post by Quinc » Dec 22 2018 2:08am
Trail was a lot bumpier with tree roots then I was expecting. :shock:
https://youtu.be/sDAMkK42UAI
Quinc   10 W
Post by Quinc » Dec 24 2018 12:23pm
Top speed so far is 25mph. No matter how many volts I throw at all her the motor will not spin faster then 5k rpms. Thinking the motor might have a governor.. :cry:
