Help me decide: Motor/Charge Controller for 55-MPH Go Kart (PICS)
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
garolittle   1 kW
Post by garolittle » Aug 10 2018 9:29pm
All,
I have been lurking and learning for the past several months and I need your help on a major purchasing decision. I am considering purchasing the following motor and charge controller for my electric go kart project.
Motor: 72V Motenergy Brushless Motor (ME0201014201).
https://www.amazon.com/Motenergy-ME-020 ... dpSrc=srch
Charge Controller: Sabvoton (svmc72150)
https://www.amazon.com/QSMOTOR-SVMC7215 ... +svmc72150
Would this motor/charge controller set up allow me to reach my goals of quick acceleration with a max speed on level ground of 55 mph (88 kph)?
Here is the background information:
In the coming weeks, I will be building/testing the following lithium ion battery pack to power the go kart:
Using Brand new Samsung INR18650-25R cells (20Amps maximum continuous discharge), I will have two separate 20S10P packs connected in parallel to obtain 72 volts. Wiring to/from the battery pack, controller and moter will be 4 AWG copper wire.
Even more information.....
Rider weight: 150 pounds (68 Kilograms)
Kart Weight: 100 pounds (45 Kilograms)
Motor/Charge controller Weight: 30 pounds (13 Kilograms)
Battery pack weight: 40 pounds (18 Kilograms)
Chain: #35
Sproket Size: To be determined
Brake type: Disc
Desired max range: 25-30 minutes at average of 30 mph (48 kph)
Terrain: mostly flat, some short hills under 5% grade
See the following pictures of the frame showing placement of each 20S10P 18650 battery pack as well as the tires I plan to use. Thanks for any advice/suggestions/criticism you can offer:
garolittle   1 kW
Re: Help me decide: Motor/Charge Controller for 55-MPH Go Kart (PICS)
Post by garolittle » Aug 12 2018 8:03am
Here are a few more photos of the frame I purchased for my project. This is a pre-owned "Razor" chassis was previously used for gas powered racing. The prio owner claimed to have reached speeds in excess of 70 mph (112 kph) so it should be sturdy enough for my goal of 55 mph (88 kph).
Any feedback on my plans for a Motenergy motor and Sabvoton controller is welcome. I have also considered purchasing an Alltrax controller within the same price range of the Sabvoton.
garolittle   1 kW
Post by garolittle » Aug 16 2018 6:00pm
Ok I will offer a free ride in my super cool go kart to anyone with advice. :lol:
999zip999   100 GW
Post by 999zip999 » Aug 18 2018 2:09pm
Looks Qsmotor or Vito they have a lot of high power stuff. He has a thread in the for sale new section. I do believe they have good support . It should fly. In a cart you can use leaf style battery modules
garolittle   1 kW
Post by garolittle » Aug 18 2018 9:40pm
999zip999 wrote:
Aug 18 2018 2:09pm
Thanks. I checked out the websites and they have some cool stuff. Have you heard of Electromotorsport? They have some motor kits that look interesting....
https://www.electricmotorsport.com/ev-p ... drive-kits
999zip999   100 GW
Post by 999zip999 » Aug 19 2018 1:08pm
That's some serious stuff I'm scared.
garolittle   1 kW
Post by garolittle » Aug 19 2018 10:19pm
I am starting to think that a 48v motor/charge controller with 150 continuous amps (300 max amps) would suffice.
A 14S 10P pack (on each side of the kart connected in Parallel) would give me 52V (nominal) and 58V (max). Such an arrangement would easily fit within the spaces below ....
It would also be much cheaper since I would need fewer 18650 cells. :D
garolittle   1 kW
Post by garolittle » Aug 26 2018 11:04pm
I appreciate all the advice from this post and from private messages. I am now leaning heavily toward this motor/charge controller/wiring package from "Electric Motorsports" in CA.
https://www.electricmotorsport.com/ev-p ... k-928.html
The relative safety of 48V over 72V has been a big factor for me. If anyone has any final suggestions for before I pull out my worn-out check book :D , feel free to reply or send a PM. Thanks again for everyone's help. Long live ES!
Gary
Upperfoot   100 W
Post by Upperfoot » Aug 27 2018 5:08am
I would recommend higher voltages because its easier to get more volts into a system than more amps (weight and heat constraints). The performance is normally greater, and you dont have to go as heavy duty with the wiring.
72v x 300A = 48v x 450A = 21600w
Here is a bit of discussion over it and safety of voltages viewtopic.php?t=75636
garolittle   1 kW
Post by garolittle » Aug 27 2018 7:44am
Upperfoot wrote:
Aug 27 2018 5:08am
Great article. Thanks for sharing that. This is been a difficult decision for me. I cannot tell you the number of times I have been on a website like electricmotorsports.com and toggled between the 48 V and 72v motenergy Motor/Charge Controllers.
nieles   10 kW
Post by nieles » Aug 27 2018 8:41am
get the zero motor drivetrain!!! :mrgreen: :mrgreen: :mrgreen:
garolittle   1 kW
Post by garolittle » Aug 29 2018 8:41pm
Ok. I think I will go with this set up.
https://www.electricmotorsport.com/ev-p ... k-929.html
48v motor/charge controller with 150 amps continuous (300 amps max). Time to start buying stuff. Really appreciate all the great advice from everyone.
ElectricTraveler   1 µW
Post by ElectricTraveler » Aug 31 2018 4:01pm
My son and I went with this package. http://www.evdrives.com/product_p/ck-0708.htm
We used a 14S Nissan Leaf pack (7 modules in series) with no BMS. With my son's weight and the proper sprocket selection you can hit 55mph easily. Since we are not running a BMS we are instead monitoring the battery voltages to ensure balance, and we do not run the voltage too low.
Still working out the bugs, but it is a blast!
garolittle   1 kW
Post by garolittle » Aug 31 2018 8:25pm
ElectricTraveler wrote:
Aug 31 2018 4:01pm
Nice! Can you share some pictures? What size wheels and sprockets do you have. Any additional information is much appreciated.
garolittle   1 kW
Post by garolittle » Aug 31 2018 8:27pm
Also, what is your continuous and max amps? What size wiring are you using?
garolittle   1 kW
Post by garolittle » Feb 01 2019 10:35am
Slight change of plans. For safety reasons, we are going with 48 volts and Nissan Leaf batteries instead of the “Tesla-style” 18650 batteries.
https://www.facebook.com/247184812650883...857410878/
Here are the specs. Go kart to be finished by March 31, 2019.
BATTERIES: 7 Nissan Leaf battery modules (7.8V each) connected in series for 54V nominal (approximately 58 amp hours). The picture of the go kart frame shows the proposed placement of the battery modules (4 on one side and 3 on the other side).
BATTERY MANAGEMENT SYSTEM (BMS): Orion Jr. BMS with pre-wired CANBUS harness, voltage tap harness, shunt resistor (500A) and basic analog display
MOTOR: Motenergy ME0708 Permanent Magnet Direct Current (DC) Motor, 48V, 8 hp cont, 15 hp pk (300 amps max/150 amps continuous)
CONTROLLER: Alltrax SR-48300 48V/300A. The charge controller would go in front of the driver (under the steering wheel).
WIRING: 4 AWG gauge wire to/from charge controller, motor, and battery pack
THROTTLE: EZ-GO Pot Box
CONTACTOR:
Gigavac GV200QA-1 48V 500 Amp
Stay tuned for more updates.
The VenomKarts Team
VenomKarts, LLC
garolittle   1 kW
Post by garolittle » Feb 03 2019 9:47am
Sorry about the broken link above. Here is the link....
https://www.facebook.com/24718481265088 ... 857410878/
SlowCo   100 kW
Post by SlowCo » Feb 03 2019 12:33pm
Not looked up the continuous/max amps of the (early/58Ah?) Nissan Leaf cells but that seems a small pack you're planning for that much motor/amp draw?
garolittle   1 kW
Post by garolittle » Feb 03 2019 7:59pm
SlowCo wrote:
Feb 03 2019 12:33pm
Fair point. Continuous amps would only be about 150 amps with short bursts of 300 amps. Here is more data on the Leaf Modules....
https://evbatterycenter.com/HAC4/index. ... Itemid=605
Quinc   100 W
Post by Quinc » Feb 03 2019 11:46pm
What are you going to use for a charger?
garolittle   1 kW
Post by garolittle » Feb 04 2019 10:32am
Quinc wrote:
Feb 03 2019 11:46pm
I Purchased this charger from EVbatterycenter.com. 18A of charging specifically designed for a 54V (nominal) pack such as mine. I highly recommend this vendor. Great customer service.
mcflystg   1 µW
Post by mcflystg » Aug 31 2019 11:34am
Wow this is an older topic. I actually did something very similar with a manco go kart.
I went with a Motenergy ME1004 Motor, paired with an Alltrax SR48400 controller with Chevy Volt battery modules. I was able to find a high output balancing bms from AliExpress.
I was able to purchase most of the supplies from evdrives.
This thing has tons of power and acceleration.
If interested, I have build and drive videos with more details on my YouTube channel.
https://www.youtube.com/user/gcerkez
garolittle   1 kW
Post by garolittle » Sep 13 2019 1:36pm
mcflystg wrote:
Aug 31 2019 11:34am
Thanks. I will check it out. Do you use a chain tensioner by chance? Gary
