Hi Guys,
Just wanted to share some build pictures and a video of my 1972 2 wheel tractor conversion.
The motor is a Heinzman PMS-126 that I bought here a couple years ago.
Sevcon Gen4 size 6 drive is overkill but this is what I had on hand.
I use my bike battery that is 24S11P li-ion of LG HG2
Cleaning my driveway require between 300wh and 1300wh depending on snow conditions
Most of the time it's around 500wh
I am not finished because I dont know how much power/current I actually use.
I programmed the drive to ouput 32Nm up to 3000 rpm and 180A phase current.
Limited the batt current to 130A input.
Here is the link to a not good video but at least you can see the operation of it.
https://www.youtube.com/watch?v=EE1ARneaODs&t=1s
Electric Snow Blower (Gravely)
Michel Cote
Norco Tactik Rc twin drive
2 VESC on 12S
60km/h top speed
2 x 2 kW max input power
2 VESC on 12S
60km/h top speed
- skeetab5780 10 MW
- Contact:
Re: Electric Snow Blower (Gravely)
Awesome!
Youtube channel http://www.youtube.com/skeetab5780
Kuberg Freerider Project https://endless-sphere.com/forums/viewt ... 28&t=90187
Direct Drive Genesis viewtopic.php?f=28&t=59122
Vector Light Commuter https://endless-sphere.com/forums/viewt ... =6&t=91406
Voloci Pagehttps://endless-sphere.com/forums/viewt ... 4#p1372424
Thanks for sharing; that thing is a beast! I'd love to have an electric snowblower someday that can handle what my 10HP 30 inch ICE blower does.
Current Build:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
em3ev 14S5P 30Q + 14S6P 25R pack
Build Thread: https://endless-sphere.com/forums/viewt ... =6&t=98286
Old Build:
GIANT ATX 980 w/ Cycle Analyst v2.25
Golden Motor Magic Pie (internal controller) X2
14S3P 15aH: 6X 6S 5000mAh + 3X 2S 5000mAh LiPo pack
Old Build:
Joe,
I like the idea of a battery-powered snow thrower, but the extreme environment that snow throwers must endure seems like a real challenge to the batteries. The battery prices may be somewhat daunting, as well. I guess it would be okay if you have enough batteries lying around.
FWIW, I have an electric snow thrower, too. It cuts an 18" swath, and if I don't watch it, that unit will take snow from my place and put it across the street on my neighbor's driveway. It's a Toro PowerCurve; it's light, it's not expensive, and it runs on 60 cycle AC. Once you pile the electric cord where it feeds itself out constantly as you throw snow, electric power is fine. I use three prong power cords, of course. The motor inside is smaller than my fist, but it sings.
Gotta say, your conversion is a brilliant idea. It's downright inspirational. I have a big two-stage snow thrower also, and if that ancient dinosaur engine ever quits, I will be looking for an equivalent 60 cycle AC motor for the rig. My Toro runs on a toothed flat drive belt, so I know it will be easy to get the drive reduction needed, with the right belt pulleys. Drive belts are also a safety factor; if anything jams the snow thrower, only the drive belt will fail, where a gear drive would probably destroy either the jamming material, or the machine transmission, or both. D.A.M.H.I.K.
Cheers,
X2flier
X2flier
Thanks for kind comments
Michel Cote
2 VESC on 12S
60km/h top speed
2 VESC on 12S
60km/h top speed
That's a beast..love it!
What is the kw rating of the motor and how large of a swath does it clear and how deep have you cleared, if I may ask?
Im working on a custom r/c vehicle for snow throwing, mowing, and just for fun and am in the concept/research phase of the power system that will be required for a 42"-50" mow/snow clearing (6 acres and about 100yd rural driveway)
Thread so far is here:
https://endless-sphere.com/forums/viewt ... 34&t=97513
Awesome build!
Awesome build!
Funny and very similar to my homemade battery powered snow blower:
https://endless-sphere.com/forums/viewt ... =7&t=98592
I also have a Toro Powercurve, and I agree it's great - within certain limits. It doesn't handle wet, heavy snow well, or more than 18" of powder. The effort of pushing it makes for a great workout, but I don't always want or need an extreme workout! For years, I've been thinking about a dual power electric snowblower with a battery pack AND an AC cord connector, to save the battery while near the house. It seems that Snow Joe makes one now, but it's a bit too small, and not, IIRC, self-propelled. I definitely need self-propulsion.
BTW, as of about two years ago, there are no more American-made snowblowers, and virtually all of the engines are made in China - even Briggs & Stratton...
