Test The Brake Lever Switch help
TommyCat   1 kW
Re: Test The Brake Lever Switch help
Post by TommyCat » Jul 24 2019 10:42am
omadawn wrote:
Jul 24 2019 8:49am
Yes it is, only 2, why do you say it's a good thing?
When you get your new charger that operates properly you can easily reuse your old charger's wiring and connector.
See my completed Magic Pie V5 rear hub E-Bike build Here!
omadawn   10 W
Post by omadawn » Jul 24 2019 12:04pm
Interesting. Using your charger as a power source and shutting off at your determined set-point. Would not be my choice.(I don't think it allows cc/cv) But if your determined to charge below 29.4 (or have too), perhaps. Beats diodes...
As a newbie feel more confortable in a cheaper solution, to learn, and at the same time if something goes wrong, have the conscience clear that I won´t loose much. My future intentions are to update (overvoltage perhaps...) anyway....for now, lets go for this:
https://www.ebay.com/itm/DC-DC-Boost-Bu ... 508941658
It says it allows cc/cv, now witch one it´s the most appropriate?
TommyCat   1 kW
Post by TommyCat » Jul 24 2019 12:49pm
Sorry, I have no experience with that type of control. :(
Please use the utmost caution when charging with it :!: Best of luck!
Last chance... :wink:
https://electricbike.com/forum/forum/kn ... d-advanced
Dui, ni shuo de dui   1 kW
Post by Dui, ni shuo de dui » Jul 26 2019 2:54am
I'm not sure to understand what's going on in this thread. Why is it that you don't just go the easy/obvious way and purchase a new charger just like this one:
https://www.amazon.com/29-4V2A-lithium- ... way&sr=8-5
Since apparently the issue is that your previous charger was going up to 29.7V, and provided you actually did the test I mentionned before which was to charge at 29.4V and check if everything works, I guess this sounds to me like being the smartest choice.
Unless maybe I missed something?
:bolt: :bolt: My electric Ninja 250 clone: 16 000W 72V40Ah A123 cells : :bolt: :bolt:
https://endless-sphere.com/forums/viewt ... 12&t=90032
:bolt: :bolt: My electric Scooter: 11 000W 72V 50Ah LiFePO4 cells: :bolt: :bolt:
https://endless-sphere.com/forums/viewt ... 12&t=75912
omadawn   10 W
Post by omadawn » Jul 26 2019 4:07am
I think you did. Found out that The motor runs only at 29.2 V. So the best solution from what I have seen so far is pending between the 2 options that I mentioned before (investment on a good & costumised charger, or, the small & cheap charging circuit).
This one, seems quite reliable, almost 3000 units sold, and more than 150 positive feedbacks:
https://www.ebay.com/itm/DC-DC-Convert ... 1052037491
omadawn   10 W
Post by omadawn » Sep 09 2019 1:57pm
Hollydays ended, now problem solved, with the charger connected to the small circuit I mentioned in previous posts, works fine.
If u guys would be so kind, I would need some help now here: viewtopic.php?f=35&t=101415
thanks
Voltron   10 MW
Post by Voltron » Sep 10 2019 12:01pm
CC/CV (constant current/constant voltage) is what you want for lithium batteries.
