1600w, 60v, custom scooter
Blacksite   1 mW
Post by Blacksite » Jun 25 2019 12:00am
Hello
This is my new project. For now i have ordered one set hub motor, controller, brakes yesterday.
If one motor would not be enough, will order second set :) (sorry for my english :pancake: )
https://www.aliexpress.com/item/3297404 ... 4c4dsQ9gAN
https://www.aliexpress.com/item/3301045 ... 4c4dsQ9gAN
https://www.aliexpress.com/item/3302145 ... 4c4dsQ9gAN
https://www.aliexpress.com/item/3302324 ... 1d6fMZm6oq
Battery will be 16s12p this type ( 192 pcs ) 38,4ah
https://eu.nkon.nl/lg-inr18650mh1-3200m ... ttery.html
For now this prototype :)
Blacksite   1 mW
Re: 1WD/2WD 1600w 60v Dualtron copy
Post by Blacksite » Jun 27 2019 3:22am
Blacksite wrote:
Jun 25 2019 12:00am
Hello
Still thinking about 2WD bud rear motor 1600w and front 1000w same voltage. Weak motor just for cruising and holding speed, stronger for hill climbing and offroad. Is that posibble?
Blacksite   1 mW
Post by Blacksite » Sep 18 2019 2:23am
So, frame partially welded, waiting for PU rod for rear suspension to test.
Bez názvu.jpg (293.81 KiB) Viewed 2589 times
Ianhill   10 MW
Post by Ianhill » Sep 19 2019 10:31pm
That's a real nice frame looks top work, I got myself one these hubs for a light weight stunt looking scooter I've spun it up at 12s on a vesc and its ideal for what i need but see they run at 16s in pairs.
On its own it will have a bit less torque so reaching such a high rpm will take a lot of effort out of it so running it at 16s on it own is the upper limit before heat problems and it's close then on big hills if your heavy but it your light and the scooter is not to heavy and plan in using 2 hubs you could push it to 20s 84v in the future, I've seen a claimed 120kph/75mph on this setup, alot faster than I'm aiming for but still looks impressive a humming human bullet :)
Silenthunter   100 W
Post by Silenthunter » Nov 17 2019 1:28am
cool frame. Would you sell one?
marejan   1 µW
Post by marejan » Jan 06 2020 7:05am
I want to buy one frame too.. please pm
Blacksite   1 mW
Post by Blacksite » Jan 14 2020 3:26am
Sorry, not for sale :) but can send model of frame
Lazzaroinferno   10 µW
10 µW
Post by Lazzaroinferno » Jan 22 2020 5:37am
Blacksite wrote:
Sep 18 2019 2:23am
it looks a bit like the little brother of this. Good job!
:arrow: Solar and e-mobility seller in Spain >> www.tutiendaenergetica.es
:lowbatt: :bolt: Solar and e-mobility seller in Europe >> www.solaremobility.com
:es: B2B e-mobility distributor worldwide>> www.fotonamobility.com
Blacksite   1 mW
Re: 1600w, 60v, custom scooter
Post by Blacksite » Feb 04 2020 3:23am
Redesigning tail light, two strips just turn on, when scooter is powered on, round one is brake light with flashing module.
Whole project is delayed because total lack of time. My first scooter was 2x350w and 18ah , power was enough, so i decided to use just one hub motor 1600w, so battery will be only 16s8p. 3250mah/per cell.
Round COB led
https://www.aliexpress.com/item/4000328 ... r5Lpo&mp=1
COB strip led
https://www.aliexpress.com/item/3290171 ... r5Lpo&mp=1
Led flasher
https://www.aliexpress.com/item/3302329 ... 4c4dQYgK7m
Bez názvu.jpg (134.41 KiB) Viewed 1095 times
Blacksite   1 mW
Post by Blacksite » Feb 12 2020 7:09am
Vertical light like DRL with flash funkcnion and 2 lights on each side for night rides. Front wheel arrived today :bigthumb:
Ianhill   10 MW
Post by Ianhill » Feb 12 2020 11:07am
What's going on with the suspension is it polyurethane bushes to absorb the harshness ?
I like that idea not to much travel but keeps the shock from traveling up the handle bars and through to the fingers.
I would ride my old scooter off-road zero suspension and cold weather after 15 mins or so id be locked to the handlebars cant feel a thing.
Gonna be a nice ride this one.
Blacksite   1 mW
Post by Blacksite » Feb 13 2020 5:05am
Yes, exactly. 4 PU rods. just took dualtron idea for suspension and tried to make it with available stuff i have around. :wink:
Ianhill   10 MW
Post by Ianhill » Feb 13 2020 9:22am
U wanna watch it's such a nice clean design people might get the wrong idea with that rear light lmao and you Willy need to keep a chappy chopper close to hand to free your ride.
The fenders are bang on specially the rear that is art fp.
