Mercane MX60 rebuild
Sinhu
I like the design on the MX60, and just got one a bit run down but at a nice price.
At first sight, not bad.
After going it over the scooter had mores issues then i first i thougt, i love the battery solution but it need to be rebuild. It holds 60,4V fully charged so thsts cost.
And after couple of days i decided to do rebuild from ground and try some new electronics.
Starting the rebuild with re wire the motors, has orginal 9 pin. No speed sensor just 5 hall wires and 3 new 12awg pahse wires
Strip it down and spray paintet the worst parts
As i will use switches and light as orginal the only adition i need is eco/turbo switch7DFF65F6-8761-47DE-99A7-83658065A1C8.jpeg
Got the battery back, had to replace 8 cells
Rebuild is started
As i wait for the controller kit it’s time for rewire and new connectors, had some jwpf that works great
Installed a key switch that can be pulled out in both posisions8AFC48FF-B3B2-408D-861B-A6EFC65A8C3D.jpeg
Finaly the controller kit got delivered, not the best quality i think but have to test it8D3B69F1-F744-4A6C-A70A-E9C9136DA048.jpeg
Modify the connectors on the controller, and make a new end plate with separation.
