DIY Battery Upgrades for Goped ESRs
sk8norcal   100 MW
Re: DIY Battery Upgrades for Goped ESRs
Post by sk8norcal » Jul 08 2011 1:37am
ran across this,
video showing the factory setup
http://www.goped.com/FAQ.asp#
Wattever   10 mW
Post by Wattever » Jul 19 2011 7:30am
I expected better from goped!
1. I think its very very dangerous to have exposed (male) connectors on the battery side, its really basic.
2. Another problem I can see with this setup is not having LVC per cell.
3. The use of DB8 is not the best choice here - once the cells voltage diff (I think it start at 5 or 10 mV) the DB8 will try to balance the cells. 38120S LifePo4 cells have a very flat discharge curve, however, think what will happen if one cell's nominal voltage is 20 mv lower than all other... this happens, and it meens the DB8 will empty the pack when standing and unbalance the whole pack. the DB8 should be active only when charging!
I own and love a hoverboard, but this solution looks like something a kid hacked at home (except for the plastics - I like the black spacer).
walls99   100 W
Post by walls99 » Jul 27 2011 6:25am
Here is my Goped battery upgrade with DIY 16Ah pack using A123 cells and DIY BMS
the build thread with more details and schematics can be found here:
http://www.gopednation.com/forum/showth ... p?t=302422
sk8norcal   100 MW
Post by sk8norcal » Oct 03 2011 3:25am
ping battery
silviasol   10 kW
Post by silviasol » Oct 19 2016 10:30am
sk8norcal wrote:ping battery
Where did you get that deck and seat? I like that version seat way better then goped's.
Current project: 10s 20ah sensored goped hoverboard
http://endless-sphere.com/forums/viewto ... 35&t=62155
Silenthunter   100 W
Post by Silenthunter » Oct 20 2016 6:42pm
https://www.youtube.com/watch?v=TblO4muWAao
Check this video on how i upgraded the goped esr 1000 to a 34 amps li-ion 18650 GA cells.
BlitzKrieg   10 mW
Post by BlitzKrieg » Aug 01 2018 5:24am
Hi guys. Do you know what is the highest voltage that controller allows to use?
And why dont you use 40152 cell. I assume that it will fit in deck spacer.
