SKATEBOARD video & gps 23 mph
torqueboards   100 MW
Re: SKATEBOARD video & gps 23 mph
Post by torqueboards » Aug 07 2013 4:02pm
Not sure exactly, I don't think it weighs over 15lbs though.
DIYElectricSkateboard.com Electric Skateboard Kits
Link   100 MW
Post by Link » Aug 11 2013 1:18am
Just so you know, you've been featured on hackaday.
Nice work, bruv.
http://hackaday.com/2013/08/10/diy-23mp ... ore-100894
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
papo2110   100 W
Post by papo2110 » Nov 16 2013 8:57am
My new 24" board should be interesting
papo2110   100 W
Post by papo2110 » Nov 16 2013 8:59am
The board is from a snowboard I found
And cut its very light and strong
Nikimce   10 mW
Post by Nikimce » Nov 16 2013 10:02am
Did you change the wires coming from your motor? Can you do that without damaging the motor?
torqueboards   100 MW
Post by torqueboards » Nov 16 2013 12:05pm
Nikimce wrote:Did you change the wires coming from your motor? Can you do that without damaging the motor?
Yes, you can change the connectors coming from your motor by soldering it off and soldering on different ones. I prefer using 5.5mm gold bullet connectors. If there is a 3mm or 4mm gold bullet connector, I'll cut the wire and solder on new 5.5mm gold bullet connectors.
papo2110   100 W
Post by papo2110 » Nov 22 2013 11:24am
Snowboard cut down
papo2110   100 W
Post by papo2110 » Nov 22 2013 2:49pm
Ready to ride
dirkdiggler   10 kW
Post by dirkdiggler » Nov 22 2013 8:08pm
NIce ride. Did you do the enclosure yourself? How'd you make that if you did?
papo2110   100 W
Post by papo2110 » Nov 23 2013 2:57pm
Ready for my test on the small board
papo2110   100 W
Post by papo2110 » Nov 23 2013 3:16pm
The battery box is from
papo2110   100 W
Post by papo2110 » Dec 02 2013 7:47pm
For my small board
papo2110   100 W
Post by papo2110 » Dec 07 2013 9:57pm
All our Babies Ready to ride
papo2110   100 W
Post by papo2110 » Dec 07 2013 10:04pm
Truck
stuntmanmike   100 W
Post by stuntmanmike » Dec 30 2013 8:42pm
Hey Papo do you work in a body shop? From your pictures.
papo2110   100 W
Post by papo2110 » Dec 31 2013 11:37pm
stuntmanmike wrote:Hey Papo do you work in a body shop? From your pictures.
My brother does
dansquatch   1 µW
Re: EBOARD electronics configuration
Post by dansquatch » Jan 24 2014 10:48pm
i am also building an Eboard with two motors and i was wondering what the component to the left of the battery was in your latest design. I was also wondering if you could tell me what the component is used for so i can finish my Eboard.
dansquatch   1 µW
Post by dansquatch » Jan 24 2014 11:02pm
also where did you get the gear that you put on the wheels and shaft of the motor. Did u make them or order them online?
Julius23   10 µW
10 µW
Post by Julius23 » Feb 01 2014 3:24pm
papo2110 wrote:
Silenthunter wrote:Papo,
How much range do you get with the Headway 8 cell pack that you have on your aluminium board? How long does it take to charge it?
I get around 7 to 8 miles around Central Park
There are some steep and long hills
And how many time for charge them? More batterys? More time to roll?
Julius23   10 µW
10 µW
Post by Julius23 » Feb 01 2014 3:45pm
Very well Papo, congratulation and thanks for this post, and thanks to all the aotherone here for wrote their expieriences... :)
THX a lot
papo2110   100 W
Post by papo2110 » Oct 08 2014 8:36am
working on a smaller transmitter will strip down and put in to a smaller 3D printed case
should be fun
quanum 2.4Ghz .jpg (29.96 KiB) Viewed 3473 times
papo2110   100 W
Post by papo2110 » Oct 08 2014 8:51am
CUT TRIM TO FIT REMOVE PART THAT ARE NOT USED
papo2110   100 W
Post by papo2110 » Oct 08 2014 11:25am
3D model ready for print lots of work
papo2110   100 W
Post by papo2110 » Oct 08 2014 4:28pm
3D print
photo (3).JPG (39.82 KiB) Viewed 3449 times
photo (4).JPG (49.86 KiB) Viewed 3448 times
photo (5).JPG (42.27 KiB) Viewed 3448 times
