SKATEBOARD video & gps 23 mph
papo2110   100 W
Re: SKATEBOARD video & gps 23 mph
Post by papo2110 » May 31 2012 12:40pm
yes and the set screws the shaft is from the car gas lifter it is 10 mm has a thread for the ball link you have to grind down
to fit the (D) cut on the gear http://www.ebay.com/itm/NEW-11-Tooth-D- ... 359e9464c3
rcelegans   10 µW
10 µW
Post by rcelegans » May 31 2012 8:51pm
Thanks for the ebay link!
I have been thinking of running a belt drive since that is what I already have on my skateboard and I assume it is more quiet. It has 44 "teeth" on the wheel side and I am thinking about using one of these gears using the Shaftloc system but not sure how many teeth I should put with the C6354-250KV outrunner motor. With the Shaftloc system I can just add the gear right on to the motor shaft (10mm):
http://www.sdp-si.com/web/email/shaftloc/index.htm
Cheers!
Exkate wheel and belt
rcelegans   10 µW
10 µW
Post by rcelegans » May 31 2012 8:57pm
btw the gear on the 400W (450W?) brushed motor has 19 teeth so I guess I should have less than this with the above brushless motor? I"m not sure how the brushed motor compares with the C6354-250 out runner?
gear on motor side
papo2110   100 W
Post by papo2110 » Jun 05 2012 7:35am
board
photo 1.JPG (141.85 KiB) Viewed 6289 times
photo 2.JPG (135.73 KiB) Viewed 6289 times
sflinux   1 µW
Post by sflinux » Jun 10 2012 8:36am
Hi,
Thanks for posting. Your board looks sick. Did you make or buy the cog for the drive wheel? If you bought it, would you please share the source?
Thanks.
Sentient AI   1 µW
Post by Sentient AI » Jun 25 2012 6:01pm
How does the motor on the back-wheel work out?
I'm not sure that a fixed 2-wheel with a single motor would make the turning lopsided in a way.
I'm visualizing the the front of the fuzion scooter, http://fuzionscooter.com/.
Just trying to figure out the different parts I would hypothetically need to make a (freewheel) kick scooter, since I'm not sure how it would work out with a fixed drive.
sk8norcal   100 MW
Post by sk8norcal » Jun 27 2012 2:13pm
the fixed drive have a drag from the cogging,
I think I would like the wheel to freewheel.
are you thinking about powering that fuzion scooter?
I have the original one,
used to be called a QuadCarver.
http://www.skatesonhaight.com/The-Quadc ... -p/qcp.htm
http://wackyboards.blogspot.com/2009/07 ... arver.html
Sentient AI   1 µW
Post by Sentient AI » Jun 27 2012 8:42pm
Yeah, I'm thinking of just sticking a relatively low-power motor (still going to figure out the amps/volts) onto one of the front wheels of a razor-esqe type build (may or may not recycle pieces), except with the whole build being more of a tricycle (Two wheels front, one larger (or smaller, not sure how it would effect it yet) wheel in the back that's on a freehinge on an axle). Just need to figure out the general pieces and their functionality before I jump into anything I can't pull off.
EDIT: Man, I'm abusing parentheses.
acevan   1 µW
Post by acevan » Sep 17 2012 9:35pm
Im attempting to do this very thing 1wd on a colt 95x mountain board, I have everything planned and the board in hand but am struggling to come up with a easy solution for mounting my motor. There are 2 threads in the rear trucks for the brake system, any ideas would be helpful, my only option of as now is n weld in a custom made motor mount plate like you did, but I am not sure how I can get this motor mount made. how can I easily and cheaply get this part manufactured? or is there a electric 15"-18" wide pre made mountain board truck?
papo2110   100 W
Post by papo2110 » Nov 12 2012 1:57pm
going faster might be 25 27 mph with new gear set up let you know on next video
http://www.youtube.com/watch?v=vnpp4tJefyI&feature=plcp
papo2110   100 W
Post by papo2110 » Nov 12 2012 2:02pm
new pic
photo 1.JPG (138.08 KiB) Viewed 5536 times
photo 2.JPG (157.51 KiB) Viewed 5536 times
papo2110   100 W
Post by papo2110 » Nov 12 2012 2:06pm
stay tune my next build crazy
sk8norcal   100 MW
Post by sk8norcal » Nov 12 2012 3:34pm
those Cindrich decks are pretty crazy looking,
but IMO, aluminum does not make good skateboard decks..
he make cnc skate trucks also...
Scruffoid   100 W
Post by Scruffoid » Nov 17 2012 2:43am
So does having a longer board stop death wobbles or something.
Always remember as a kid going down the steep hills and losing it.
Always enjoy the pics.
Wayne
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewto ... 91#p553791
sk8norcal   100 MW
Post by sk8norcal » Nov 17 2012 3:22am
yes, longer wb usually means more stablity at speed,
but that's only part of it,
notice the "longboard' trucks, they are less prone to wobbles than the traditional design trucks.
rider skills matter also.
current dh speed record is over 80+mph
realmattb   1 µW
Post by realmattb » Nov 17 2012 11:44pm
Hi guys! This is an awesome thread. It inspired me to build my own board last week. I am using the Mamba Monster ESC and a NTM 380kv 50x60mm motor rated at 90a with 5000mAh 6S lipo rated at 20C.
I am using a belt drive with timing pulleys and a simple aluminum motor mount very similar to Papa2110, but I can't weld so it is just bolted on for now. The pulley ratio is 16teeth on the motor and 50teeth on the 75mm wheel.
The thing REALLY moves and can accelerate so fast I've fallen off about 20 times. I will post some videos and pictures here shortly, I just got finished it about 24 hours ago.
Anyway, my motor stutters and is really loud when starting from a dead stop. I tried adjusting literally every option on the mamba monster with the programming software and still no luck. Would love some input from you guys so that I might make this thing work a bit better.
The only thing I can think of is that the "20C" rating of the battery won't provide enough current upon starting from a dead stop. BUT I don't have another battery to test on and would prefer not to spend the money if it isn't going to solve the problem.
Basically I just want it to be smooth so I can have my wife and friends ride it too without worrying and also as quite as possible.
Also if anyone has any suggestions please let me know, I am always looking for new ideas and builds :)
Thanks for your help. Have a great night.
papo2110   100 W
Post by papo2110 » Nov 19 2012 7:35am
We had a similar problem lower gearing 40c
Battery more power
papo2110   100 W
Post by papo2110 » Nov 19 2012 7:48am
photo 1.JPG (148.96 KiB) Viewed 5480 times
photo 2.JPG (149.05 KiB) Viewed 5480 times
papo2110   100 W
Post by papo2110 » Nov 21 2012 8:39am
IN THE WORKS
photo 1.JPG (124.07 KiB) Viewed 5461 times
photo 2.JPG (116.1 KiB) Viewed 5461 times
sk8norcal   100 MW
Post by sk8norcal » Nov 21 2012 4:15pm
nice! surf rodz indeesz trucks, right?
was think along the same line with the motor mounts clamped to the hangers with no welding...
i think that lagrange truck should have just done that, instead of that more complicated spinning axle idea...
shortcircuit911   1 kW
Post by shortcircuit911 » Nov 23 2012 3:34pm
Awesome! I'm currently building a skateboard of my own that should be done this week. I like all the machining you did on your parts. I've had to do the same with mine, but I don't have a tig welder to weld the aluminum, so I had to make a steel exoskeleton for the truck to weld the steel motor mount.
sk8norcal   100 MW
Post by sk8norcal » Nov 24 2012 1:04am
ran across this, not sure who made it...
dirkdiggler   10 kW
Post by dirkdiggler » Nov 25 2012 12:02am
How does that mount to the trucks? Can you take a pic of the mount by itself? Also, is this going to be chain driven or with a belt? I am frustrated as hell with the mt. board I built because of the chain popping. I also have a exskate that I fitted with a new brushless motor and the belt slips like crazy. I can't decide which is worse/better. I might have to try a direct drive.
Digg
Post by shortcircuit911 » Nov 25 2012 6:16pm
I don't want to hijack papo's thread, so I've started my own here: http://endless-sphere.com/forums/viewto ... 35&t=45859
It's a work in progress, so give me some time to get all the info and pics up.
Edit: mod fixed the link
