Alien Drive Systems- Stunt scooter from scratch
beetbocks   10 kW
Re: Alien Drive Systems- Stunt scooter from scratch
Post by beetbocks » Aug 22 2016 2:59am
New Med scoot has come together nicely- i'm particularly proud of the one piece hand control..super neat -
I've had a short test ride and on 8S 5065 motor- its fast (25mph)but usable..:)
Nice acceleration and an overall weight or 7.kg..
Next job is to strip it for Paint- and LED fittings.
beetbocks   10 kW
Post by beetbocks » Aug 24 2016 5:53am
New panel printed for my mates big scoot and a combined charging plug designed and printed..
" piece split cover .. saves all the tedious balance wire soldering..
Just uses standard balance lead up to 8S and a deans plug..:)
beetbocks   10 kW
Post by beetbocks » Sep 01 2016 3:04am
The rebuild has begun..:)
after a nice paint job and some custom parts printed the new Med scoot is coming together..
New features include-
New APS 5070 motor
New gear ratio and drive chain
LED lighting
Cree LED fron head lamp
stripped ready for paint
Cree LED and remote
refit begun
rear LED pods
New APS 5070 motor
stealth71   10 W
Post by stealth71 » Sep 19 2016 11:28am
I still want to buy one of these from you. Any plans on production?
beetbocks   10 kW
Post by beetbocks » Sep 21 2016 3:33am
well..in order to get them at a reasonable cost..i need to buy 10 chassis min... so i need a group buy really ..otherwise i'm maybe stuck with them..
would you consider a pre-order with a deposit? to try to get the ball rolling?
stealth71   10 W
Post by stealth71 » Sep 22 2016 11:25am
beetbocks wrote:well..in order to get them at a reasonable cost..i need to buy 10 chassis min... so i need a group buy really ..otherwise i'm maybe stuck with them..
Yes. Should start a list and see how many people are interested.
Badkad   100 µW
100 µW
Post by Badkad » Sep 22 2016 2:04pm
I've expressed interest in the past and I would still buy a chassis
from you.
beetbocks   10 kW
Post by beetbocks » Sep 23 2016 6:12am
ok- to actually build that exact same scoot- (white one)..would cost around £1100 (this includes my time to build)....
The chassis only would be around £250... (would need wheels/bars/clamp/forks-adding)
which way do people want to go?
stealth71   10 W
Post by stealth71 » Sep 23 2016 11:23am
beetbocks wrote:ok- to actually build that exact same scoot- (white one)..would cost around £1100 (this includes my time to build)....
Would be nice to include any custom parts needed. Sprockets, wheel adapter and such. So maybe a base package for people to source the rest of the off the shelf parts and an option to buy those other parts wheels, clamp, fork ect. if you are interested in stocking them. Otherwise just point us in the right direction.
Badkad   100 µW
100 µW
Post by Badkad » Sep 27 2016 11:52am
Hit the nail on the head, chassis and accessories, if not just a list of what you used to complete the scoot would be fine.
beetbocks   10 kW
Post by beetbocks » Sep 29 2016 4:32am
Im looking into bulk purchase of scoot bodies -
I'm the mean time -I've uploaded several STL for 3d printing that may be of use to the building community both scoot and e-skates..
http://www.thingiverse.com/beetbocks75/designs
Ianhill   10 MW
Post by Ianhill » Sep 29 2016 10:14am
Yeah done really well by there looking at the video it seems fast enough and it looks very lite thats always my main task light enough to lift in through house, keep carpet clean or I get hammered.
Ianhill   10 MW
Post by Ianhill » Jan 18 2017 11:38am
Im very tempted to use your build design, ill reuse the front forks from my razor with a disc brake front and rear wheel and build it to acomadate 20s or so with hyrdraulic brakes all round, I like the 4inch tyres myself as they have plenty of suspension built in on the side wall and take up very little room, my aim will be just over 4kw with a boma style motor.
xadmx   1 kW
Post by xadmx » Jan 18 2017 12:15pm
i used your gtb2 housing on my daughters scooter. it did have a 63mm motor until it broke so now has a 50mm until i get the 63mm one fixed.
ElectricGod   1 GW
1 GW
Post by ElectricGod » Jan 18 2017 9:59pm
I love your scooters! I would be building my own from scratch if I had a TIG welder. I'm going to have to make it a goal to get one this year. I'm definitely envious of your builds.
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
beetbocks   10 kW
Post by beetbocks » Jan 19 2017 4:27am
cheers- well thats my problem at the moment- i gave to have the parts fabricated by a company at a cost ...so im limited really..and hence why they are not that cheap to make- (and sell on)
xadmx-That housing is nice- whats the scooter you based it on?
xadmx   1 kW
Post by xadmx » Jan 19 2017 7:58am
beetbocks wrote:cheers- well thats my problem at the moment- i gave to have the parts fabricated by a company at a cost ...so im limited really..and hence why they are not that cheap to make- (and sell on)
i made it myself. it did have a balanceboard wheel on the back, but it was only mounted to the one side as the balanceboard wheel has one shaft.
but i cut it all off and welded some more bits on the back to take the shaft. its made from 20x30mm box section and 1.5mm tub on the bottom that the batteries sit in and razor e100 front wheels.
its not light but it shifts with my daughter on it. the only thing i have found the sound resonates into the hollow frame making it loud so i might drill some holes and fill it with silicon :).
Rikobonito   100 W
Re: Alien Drive Systems - AT scooter
Post by Rikobonito » Jan 29 2017 7:57am
Hi Beetbocks !
Here we go, I find a really good deal for a dirt scooter like I want :twisted: (oxelo model to start a 1th proto less than 50€)
Now was thinking about how do it well (like you :P or Keith_hill but can't make a frame like both of you ... I have absolutely no knowledge in welding nor even the material :| )
that is the boy. Image
If you or someone else had a link on the anatomy / composition of a scooter (I found only very basic images with handlebar, wheel, ...)
I try to understand how this link with the handlebars works, to increase and reinforce its hold and its height (I measure 1m95).
When I see your piece ! wow look so strong and tall Unlike that mounted on mine ... :shock: (red pieces)
And your deck (carbon layer) is exaclty what I would like too "protect" the mounted motor on the top of the deck. It is a custom manufactured ?
I see you sell, full frame, but do you steal sell parts :D ?!
Many thanks for your inspiration and your help, I will start a topic !
Best electric regards :wink:
my little blog with e-sk8, e-Cruiser, e-pintail, e-MTBoard, e-Dirt Scooter and others builds
... I wish also an e-MTBike soon !! :v: Thanks DIY Power community :wink:
tomjasz   10 GW
10 GW
Post by tomjasz » Jan 31 2017 3:37pm
Stunning work sub d
beetbocks   10 kW
Post by beetbocks » Feb 01 2017 4:54am
Rikobonito wrote:Hi Beetbocks !
The red clamp is just a standard 4 bolt stunt scooter clamp and wide bars
Rikobonito   100 W
Post by Rikobonito » Feb 02 2017 12:59pm
Yes, thanks beetbocks :wink:
At first I was a little lost, but now that I disassembled it, I searched for what handlebar fastening system I had (simple compression system screwed) and I watched quite a few videos :mrgreen:
Got many parts who will comes + your Motormount ! Its gonna be AWESOME !!
Many thanks once again and good ride.
