Destroyer 12s Urban Racer Build
beto_pty   1 kW
Re: Destroyer 12s Urban Racer Build
Post by beto_pty » Dec 18 2014 12:28pm
LOL...
yup that is next on my list...roadrash where the sun don't shine LOL.. :shock:
awesome graph...
OKP YUP that is the tradeoff... faster maximum speeds on flats at the cost of hill climbing ability... probably the sucks for Alps and our mountain friends.. but for me... living in a big tropical pancake... the tradeoff is painless.
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
thepronghorn   100 W
Post by thepronghorn » May 11 2015 1:38pm
How did you get your airplane esc to play nice with your car transmitter? I can't get my CC HV80 esc to arm using my quanum transmitter since it's expecting full throttle, but I'm trying to only give it half (center on the pistol transmitter).
beto_pty   1 kW
Post by beto_pty » May 12 2015 7:11am
Hi..
Dont think you can just go halfway for the setup sequency.... you need the full travel...
Try reversing your throttle direction...(little button just above where the trigger would be) as some remote controls are inverted amd maybe your esc is looking for this..
If you are looking to diminish your top speed try gearing down instead of the midway throttle alternative...
Also chech that your esc is not opto..as yiunwill need a secondary power source for your receiver as your esc might not be power ing it...
thepronghorn   100 W
Post by thepronghorn » May 12 2015 1:31pm
made_in_the_alps_legacy wrote:Have you tried the "throttle range adjustment" procedure ?
Yeah I tried that, I don't think the esc is going to accept a 1.5ms signal as zero throttle because it's looking for something a lot closer to 1ms.
beto_pty wrote:Hi..
My esc is optocoupled, but I am powering it with a separate battery pack. The setup works, just not that way I want it to. The problem with needing full travel means that zero throttle is not at the neutral position of the throttle stick - it's at the end of the stick's travel. This means that the stick has to be actively held at zero throttle which is unsafe and has already resulted in one crash. I think I will have to pass the receiver signal through an arduino in order to make the esc happy.
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » May 12 2015 6:08pm
Just disassemble your transmitter and modify it so the trigger snaps all the way forward when released. It is really easy on most transmitters.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
beto_pty   1 kW
Post by beto_pty » May 12 2015 6:36pm
weird esc.. in my (brief and crappy) experience with boat esc this was not an issue... I have used the cheap little bird airplane esc (which I burned but thet is another story) the original bulletproof hv airplane esc and the 2nd version and they have all loved the quanum... an airplane joystick controller i think resets to center so there should be no difference in logic there..
However to prevent your untimely death
we will design a normally closed, resistive tecnolgy, state of the art diy wireless weird-ESC handheld controller.
For this proyect you will need..
parts
ScreenHunter_259 May. 12 18.32.jpg (29.05 KiB) Viewed 1182 times
Carefully assemble as follows, if necesary get a professional, or a licenced diy-er
done part
ScreenHunter_260 May. 12 18.32.jpg (30.25 KiB) Viewed 1182 times
Played around with it for quite a while and the rubberband did not show signs of wear...
Might still want to use a hlemet though
good luck
Edit..recompence didnt read your post.. yeah that would be the profesional, scientific and permanent way to do this..how embarassing :oops:
made_in_the_alps_legacy   10 kW
Post by made_in_the_alps_legacy » May 13 2015 2:10am
beto_pty wrote:weird esc.. in my (brief and crappy) experience with boat esc this was not an issue... I have used the cheap little bird airplane esc (which I burned but thet is another story) the original bulletproof hv airplane esc and the 2nd version and they have all loved the quanum... an airplane joystick controller i think resets to center so there should be no difference in logic there..
+1, I use 12s OPTO HV plane ESC without that issue either. I guess you played with the "thr. trim knob" too...
anyway, there is no point to have a transmitter trigger going in both direction since this esc won't allow braking :
both option from beto_pty and recumpence should help...
sl33py   10 kW
Post by sl33py » May 13 2015 10:54am
Seriously awesome thread beto! Great builds, info, and especially loved the play-by-play descriptions. Nice writing and extremely fun to read. Thanks for sharing with us!!
bandaro   10 kW
Post by bandaro » Jun 02 2015 11:46pm
Was this you by any chance? making potholes tweet to politicians every time they were run over? Apparently the potholes in Panama are sick of getting run over all the time and took an angry stance...
http://www.fastcodesign.com/3046904/pot ... e=facebook
beto_pty   1 kW
Post by beto_pty » Jun 04 2015 6:57pm
awesome..lol
had no idea...
thanks for the info..
