Wireless Wii Nunchuck *TESTERS WANTED
Svenska   100 mW
Re: Wireless Wii Nunchuck *TESTERS WANTED
Post by Svenska » Mar 15 2015 2:30am
I need a "naked" pic of it. I stacked it and the board hit a curb on an very awkward angle, the WIIciever got mangled up. I need to see what parts are in a few particular locations...
austindavid   100 W
Post by austindavid » Mar 17 2015 11:45pm
sorry, all mine are already disassembled. torqueboards, do you have a Kama you can get a picture of the guts?
torqueboards   100 MW
Post by torqueboards » Mar 18 2015 12:23am
I'll see if I can find a photo.
DIYElectricSkateboard.com Electric Skateboard Kits
craft211   1 mW
Post by craft211 » Mar 18 2015 3:08am
Svenska wrote:I need a "naked" pic of it. I stacked it and the board hit a curb on an very awkward angle, the WIIciever got mangled up. I need to see what parts are in a few particular locations...
Will these photos suffice?
[EDIT] Sorry. messed up the url for the photos. hope that helps!
Svenska   100 mW
Post by Svenska » Mar 18 2015 8:09am
I don't seem to be able to see any pictures there?
sami   1 W
Post by sami » Mar 19 2015 11:52pm
ordered and receieved mine thanks Torqueboards. (ordered the extra controller for when i inevitably stack it and break one :D)
will build my board this weekend.
Svenska   100 mW
Post by Svenska » Mar 20 2015 9:05am
@ craft211 Thank you, that helps a bunch!
beto_pty   1 kW
Post by beto_pty » Apr 05 2015 9:54pm
There is always a new post regarding a new open sourced controller.. or a new gadget controller.. or the desire for a new controller design...
So I`m baffled why im so in love with my wiiceiver...
So I have acording to map my ride almost 1500 kms with the wiiciever on the velociraptor... and I love this thing.. The original velociraptor board (a set of wheels, 2 ntms, and 1 hw150 and an hk150 ago) started with a boxy remote the GT2 from hobbyking...no not the lighter GT2B you are currently thinking of with the lipo battery.. the original one with like 8 D batteries LOL.. it seemed that way... it was heavy and clumsy. Moved to the quanum as soon as it came out and marveled at the weight and balance.. Got stopped every block by some cop trying to confiscate my tazer or gun, but other than that it worked well. Well it also went through 4 AAAs in about 2 hours which was a little over the top...
At some point I tried a flex sensor connected to my glove, and all the electronics i think it was from the gb2's trigger setup, hiding in my wrist.. and it is very complex trying to control a board without "something" in your hand.... You forget and lower it, or brace yourself for a fall and accelerate instead of stop... or wave at someone and die (never actually did that but still think about how it could have happened :shock: )
Then I was fortunate enough to back austin's initial wiimote run and got number 4 or 3.. I seem to remember... worked OK but the software left some to be desired. However the wiimotes Nyko Kama form factor was awesome.. it fits perfectly in your hand, it weighs close to nothing and after a couple of hours the thumb throttle feels totally natural. The only big glitch was the signal problem.. I lost signal every couple of minutes.. so that was a little anoying.. and would sometimes be unable to get it back for a while... which was much more anoying, as a pushed the whole way back stranded by the danged remote.
However the updates kept coming and the wiimote kept getting better. I Also I realized that the nykos receiver was disconecting from the wiimotes "usb sort of hub" due to vibration and consecuently loosing connection or power... I taped the nyko'sreceiver to the wiimote firmly so that it could not disengage in mid run and that inmediately solved 100% of my connectivity issues. I have not lost signal in literally over 1000 kms...
Then the final (or at least current) update added a very comfortable acceleration, a much easier to use cruise control.. and I am fully hooked. I really like this thing. If we go the trigger gun way (which rocks by the way) we loose the cruise control alternative wich is cool, and handy... and the size difference is almost negligible...
There is also the production and design parameters, that go with purchasing something of wich there have been literally hundreds of thousands made, as opposed to (and no disrespect to those that do) something welded up in a garage by someone like me. :shock:
So keep on developing ideas and pushing the tecnology further... but I believe there is currently a superb alterntive for the eboard crowd.. I actually also belive it is open sourced.
There, end of rant... just the views of someone who is fortunate enough to be able to ride more than the average eboard user... and who has already tried some of the alternatives...
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
mogenheid   1 µW
Post by mogenheid » Apr 27 2015 5:44pm
hey, if anyone is still reading this forum, is there anything stopping me from not removing the atmega 328 from the uno and just leaving it on the board and using the board to run the software and esc? i bought the wi chuck breakout and i have the ardunio uno. Just wondering if i can skip the shrinking of the hardware and leave the bulky uno to do the work?
austindavid   100 W
Post by austindavid » Apr 27 2015 6:13pm
You can use the Uno as-is. Check the wiiceiver pinouts.h to find pin locations, but I think it will "just work" with a break out on the a2-5 pins and the esc signal on 9 or 10. Triple-check power and ground to your chuck, and figure a way to get power onto your Uno.
But it does work. Torqueboards used an Uno + shield for a while during development.
kwoolf1   100 mW
Post by kwoolf1 » Apr 27 2015 7:24pm
Hello guys,
I need to extend the wiring on my Nyko Kama but I don't know which wires are which (data, clock, power, ground, etc.). Plus I'm colorblind which makes things even worse. My daughter had to tell me which colors these were but I think she's right and not messing with me. So there's black, blue, white, red, and green. See my pic below. Any help assigning these wires for their functions is much appreciated! thanks.
wii reciever1.jpg (49.48 KiB) Viewed 2485 times
EDIT: after looking at pictures and the layouts on nunchucky and sparkfun adapter it looks like:
1. Black = Ground
2. Blue = Data
3. White = ?? not used? hmmm...
4. Red = VCC (+)
5. Green = Clock
Still searching for Animal Chin
Easy-pd   10 W
Post by Easy-pd » Jun 15 2015 5:19pm
I would love this for my build, but all websites say that they will not ship overseas (i am uk), so i thought id try the code. i have got an arduino, a 'Wiichuck' and some patience. I have tried the code supplied, but cannot figure out how to get it running. I get the following error and an orange box saying:
redefinition of 'void setup()'
I have spent ages and am pulling out my hair. Is there an 'idiots guide' to setting this up on an arduino?
Any help would be amazing...
Code: Select all
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
In file included from sketch_jun15a.ino:2:0:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h: In member function 'void Chuck::readEEPROM()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h:186:15: error: 'EEPROM' was not declared in this scope
     storedY = EEPROM.read(EEPROM_Y_ADDY);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h:186:27: error: 'EEPROM_Y_ADDY' was not declared in this scope
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h: In member function 'void Chuck::writeEEPROM()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h:208:5: error: 'EEPROM' was not declared in this scope
     EEPROM.write(EEPROM_Y_ADDY, Y0);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h:208:18: error: 'EEPROM_Y_ADDY' was not declared in this scope
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h: In member function 'void Chuck::setup()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h:231:5: error: 'Wire' was not declared in this scope
     Wire.begin();
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h: In member function 'void Chuck::update()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Chuck.h:266:5: error: 'Wire' was not declared in this scope
     Wire.requestFrom (0x52, 6); // request data from nunchuck
In file included from sketch_jun15a.ino:3:0:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h: At global scope:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h:43:3: error: 'Servo' does not name a type
   Servo _esc1, _esc2;
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h: In member function 'void ElectronicSpeedController::init(int, int)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h:59:3: error: '_esc1' was not declared in this scope
   _esc1.attach(pin1, 1000, 2000);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h:62:5: error: '_esc2' was not declared in this scope
     _esc2.attach(pin2, 1000, 2000);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h: In member function 'void ElectronicSpeedController::setLevel(float)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h:120:5: error: '_esc1' was not declared in this scope
     _esc1.write(angle);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/ElectronicSpeedController.h:122:7: error: '_esc2' was not declared in this scope
       _esc2.write(angle);
In file included from sketch_jun15a.ino:5:0:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Smoother.h: In member function 'float Smoother::compute(float, float)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Smoother.h:58:23: error: 'SMOOTHER_MIN_STEP' was not declared in this scope
       if (abs(step) < SMOOTHER_MIN_STEP) {
In file included from sketch_jun15a.ino:6:0:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h: In member function 'void Throttle::readAutoCruise()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:50:26: error: 'EEPROM' was not declared in this scope
       byte storedValue = EEPROM.read(EEPROM_AUTOCRUISE_ADDY);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:50:38: error: 'EEPROM_AUTOCRUISE_ADDY' was not declared in this scope
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h: In member function 'void Throttle::writeAutoCruise()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:70:7: error: 'EEPROM' was not declared in this scope
       EEPROM.write(EEPROM_AUTOCRUISE_ADDY, storedValue);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:70:20: error: 'EEPROM_AUTOCRUISE_ADDY' was not declared in this scope
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h: In member function 'float Throttle::checkCruiseReturn(Chuck)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:151:31: error: 'THROTTLE_CRUISE_RETURN_MS' was not declared in this scope
           (previousCruiseMS + THROTTLE_CRUISE_RETURN_MS < millis())) {
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:177:26: error: 'THROTTLE_MIN' was not declared in this scope
       if (abs(chuck.X) > THROTTLE_MIN ||
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:188:60: error: 'SMOOTHER_CRUISE_RESUME_PROGRAM' was not declared in this scope
         newThrottle = smoother.smooth(previousCruiseLevel, SMOOTHER_CRUISE_RESUME_PROGRAM);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h: In member function 'float Throttle::cruiseControl(Chuck)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:214:31: error: 'THROTTLE_CC_BUMP' was not declared in this scope
         throttle += chuck.Y * THROTTLE_CC_BUMP;
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:217:31: error: 'THROTTLE_CC_BUMP' was not declared in this scope
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:220:25: error: 'THROTTLE_CC_BUMP' was not declared in this scope
         throttle += 4 * THROTTLE_CC_BUMP;
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h: In constructor 'Throttle::Throttle()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:232:20: error: 'THROTTLE_MIN_CC' was not declared in this scope
       autoCruise = THROTTLE_MIN_CC;
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h: In member function 'float Throttle::update(Chuck)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:281:35: error: 'SMOOTHER_THROTTLE_PROGRAM' was not declared in this scope
         smoother.smooth(throttle, SMOOTHER_THROTTLE_PROGRAM);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:282:29: error: 'THROTTLE_MIN' was not declared in this scope
       } else if (chuck.Y < -THROTTLE_MIN) {
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:284:45: error: 'SMOOTHER_BRAKES_PROGRAM' was not declared in this scope
         throttle = smoother.smooth(chuck.Y, SMOOTHER_BRAKES_PROGRAM);
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:286:56: error: 'SMOOTHER_THROTTLE_Z_PROGRAM' was not declared in this scope
         throttle = smoother.smooth(chuck.Y, (chuck.Z ? SMOOTHER_THROTTLE_Z_PROGRAM : SMOOTHER_THROTTLE_PROGRAM));
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/Throttle.h:286:86: error: 'SMOOTHER_THROTTLE_PROGRAM' was not declared in this scope
In file included from Wiiceiver.ino:77:0:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h: At global scope:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h:65:5: error: redefinition of 'int CSEL'
 int CSEL = -1;
In file included from sketch_jun15a.ino:4:0:
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h:65:5: error: 'int CSEL' previously defined here
 int CSEL = -1;
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h: In function 'void chipSelect()':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h:66:6: error: redefinition of 'void chipSelect()'
 void chipSelect (void) {
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h:66:6: error: 'void chipSelect()' previously defined here
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h: In function 'int pinLocation(int)':
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h:94:5: error: redefinition of 'int pinLocation(int)'
 int pinLocation(int pinID) {
C:\Users\jamie_000\Documents\Arduino\libraries\libraries/pinouts.h:94:5: error: 'int pinLocation(int)' previously defined here
Wiiceiver.ino: In function 'void setup()':
Wiiceiver:372: error: redefinition of 'void setup()'
sketch_jun15a:8: error: 'void setup()' previously defined here
Wiiceiver.ino: In function 'void loop()':
Wiiceiver:421: error: redefinition of 'void loop()'
sketch_jun15a:13: error: 'void loop()' previously defined here
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
phomann   10 W
Post by phomann » Jun 15 2015 5:28pm
Easy-pd wrote:I would love this for my build, but all websites say that they will not ship overseas (i am uk)
Hi,
I have no issue shipping overseas if you are after a ready made board.
http://www.homanndesigns.com/store/inde ... cts_id=278
Cheers,
Peter
MiniWiiceiver- http://www.homanndesigns.com/store/inde ... cts_id=277
Longboard build: http://endless-sphere.com/forums/viewto ... 35&t=60280
Homann Designs - http://www.homanndesigns.com/store/
austindavid   100 W
Post by austindavid » Jun 15 2015 10:04pm
Easy-pd wrote:I would love this for my build, but all websites say that they will not ship overseas (i am uk), so i thought id try the code. i have got an arduino, a 'Wiichuck' and some patience. I have tried the code supplied, but cannot figure out how to get it running. I get the following error and an orange box saying:
How did you import this sketch? The errors say you're missing system libraries for EEPROM, Wire, and Servo, and show some other import errors. If you're not using Arduino for anything else I'd suggest you uninstall and try again with a fresh installation. Install the Arduino environment, download the Wiiceiver sketch, and just double-click Wiiceiver.ino and see if it opens and builds correctly.
I've done that on a clean install before just to confirm that it works.
The other difference I have not tested is with Arduino 1.6.x; I'm using 1.0.6. I expect the newer version to work, but it's not something I've attempted.
Easy-pd   10 W
Post by Easy-pd » Jun 16 2015 1:05am
Hi,
Cheers,
Peter
I am trying to self build and learn as I go
Maybe because I played with the arduino to get an idea how it works and there's stuff on there already? How do I uninstall to do a fresh installation?
jacobbloy   100 W
Post by jacobbloy » Jun 24 2015 6:56pm
Ok so I've resigned vedders nunchuck PCB to help him out with all the pressure he is under. Iv made it to be the exact same size as an original wii nunchuck PCB, I will be taking preorders for this PCB and I will be posted on git hub very soon!
I taking numbers for the first beta of this boards. They will come fully assembled! In a wii nunchuck case.
The good thing About these is you can install a 10k pot and trigger instead or you can install a slider bar!
And then we can get a library of 3d printing files! iv attached a photo of an original nunchuck PCB.
Iv only posted it here because I think that if we can add this with the wiireciver then you will get a really great nunchuck going that doesn't have to be used with the VESC!
finocks   1 µW
Post by finocks » Jul 13 2015 9:00pm
My wiiceiver seems to be functioning as in the leds respond to the nunchuck but the there seems to be no signal coming out as the esc is not recognizing it as there, works fine with my 2.4 remote. not sure what to check or replace. any help appreciated.
austindavid   100 W
Post by austindavid » Jul 13 2015 9:59pm
finocks wrote:My wiiceiver seems to be functioning as in the leds respond to the nunchuck but the there seems to be no signal coming out as the esc is not recognizing it as there, works fine with my 2.4 remote. not sure what to check or replace. any help appreciated.
Which wiiceiver do you have? If it's a dual-port version you can truy the other port, just to be sure there's not an issue with one solder. Also be sure the ESC plug is oriented correctly -- black / ground goes toward the center of the PCB.
finocks   1 µW
Post by finocks » Jul 13 2015 11:32pm
Picture attached V1 14/06/02, it has the latest firmware and it was working!! but it stopped and has not worked since, i have some more 328's on the way asuming i spiked it and i have ordered a new wiiceiver from DIY as well.
austindavid   100 W
Post by austindavid » Jul 14 2015 7:14am
Ah, of it was working then stopped, sounds like the ATMega got cooked. If you're feeling frisky you can try cutting the bottom left of the atmega right beside jp1 and connecting the next leg over, currently unconnected. The newer software release enable both pins for dual ESC, you may have just fried one of them.
The board itself is likely fine, replacing the ATMega should help. I can send you one programmed if you want to give it a try.
finocks   1 µW
Post by finocks » Jul 14 2015 7:29pm
Thanks Frisky worked a treat, back up and running again, i have 5 ATmega's on the way as spares. So does that mean the new one i have ordered will be a dual?
finocks   1 µW
Post by finocks » Jul 15 2015 2:37am
have to play with placement a bit more as still getting signal dropouts. I have another numchuck to try as there may be slight differences between them but it is frustrating. I hope the jacobbloy upgrade sorts it out once and for all!!
emepror   10 mW
Post by emepror » Sep 08 2015 8:59pm
Been awhile since anyone posted in this thread but this is worth mentioning:
I have a wiiciever setup that has been working flawlessly for as long as I've had my board setup, until tonight. Seems there might be something wrong with the cruise control setup as I lost control of my board after attempting to use the cruise control. Board would not respond to input from the nunchuck, but was still connected and I couldn't throttle down, it just stayed at the ~10mph I was traveling at when I lost control. Unfortunately ended up using a building's wall to stop (im fine). I'll see about providing more information based off any questions anyone has.
austindavid   100 W
Post by austindavid » Sep 08 2015 9:15pm
emepror: when you powered it back up (after the event), was it working normally? Have you successfully used cruise control in the past? What ESC are you using? What nunchuck?
It could be that your wiiceiver "crashed". There is watchdog code that should basically reboot it if the hardware gets wedged, usually caused by interference. That code should kick in after about 1/4 second and start from scratch. It shouldn't happen much, but it's there just in case.
I have tested that code on a few different ESCs, but not all of them. After that code fires the wiiceiver goes back to neutral and starts over cold. There is a sequence on startup to re-center the joystick, but if that happened while in normal cruise (with C + stick at neutral) it would just recenter the stick to neutral.
It's also possible that the nunchuck stopped working correctly. I've had a few that started getting weird over time, like the throttle would stop working correctly at 100% (basically show neutral, or something like 60%), but fine at other ranges. So as I'd press "up" the ESC would accelerate, and keep accelerating, until I hit the stop on the chuck -- then it would back off again to whatever speed. Pretty tough to diagnose while I'm standing on the board!
Since it sounds like your ESC just kept going at the same throttle, I gotta believe that the wiiceiver either stopped responding (a crash without the watchdog reset), or the ESC stopped responding. If the chuck cut out entirely wiiceiver would have gone to neutral after 2s... but that didn't happen either?
Last fall when I was testing a few ESCs I was able to get the Flier to stop working, semi-reliably. I was able to confirm that the controls were correct, wiiceiver doing the right thing, etc. I've also seen similar problems with Fliers using off-the-shelf RC controllers + receivers.
Let me know what all you observed at the time, what worked / didn't, etc, and we'll see what might have happened.
emepror   10 mW
Post by emepror » Sep 08 2015 9:39pm
Talk about quick response!
i have a nyko kama nunchuck, Turnigy Trackstar 150A GenII ESC
I've never really used cruise control, and I don't want to completely blame it (correlation not causation kinda thing). But the run up to the event was i tried cruise control and it worked for about a minute, went off cruise control and started braking for a tight turn, about a minute after the tight turn i noticed i lost control. After that was an exercise in "crap crap find some grass to ditch it, crap passed all of it, hey look that wall looks soft"
Afterwards it started up just fine, rode the thing home even. I've had it cut off on me before (properly, went to neutral etc) which is why I'm confused on what happened. It sounds like the ESC stopped responding though, im going to triple check the wiring tomorrow.
Lemme know if I missed any of your questions and thanks for the response!
