Compression Molded Carbon Fiber Deck
tung256
Re: Compression Molded Carbon Fiber Deck
Post by tung256 » Nov 13, 2014 6:30 am
Looks ridiculously good! Looks like we have a real marble challenger hehe
JJ2525
Post by JJ2525 » Nov 13, 2014 9:39 am
This looks spectacular. I'm also eager to hear what kind of a performance you're getting. Very impressive.
okp
Post by okp » Nov 13, 2014 2:53 pm
masterpiece.
CFRP
Post by CFRP » Nov 13, 2014 9:12 pm
Thanks everyone for the encouraging comments.
This is a foam cored compression molded deck. This revision is setup to hold twenty, 26650 cells. So I am not sure off the top of my head how many 18650 cells would fit in it....probably around 30. The motor mount is press fit and bolted to the hanger so it is plenty strong.
At this point have the following specs:
2200 watt 320KV motor
3:1 pulley ratio
85mm wheels
10 cell 2.5Ah Lifepo4 battery pack
5mile range
26mph top speed
I plan to double the capacity of the battery pack and reduce the top speed a little so it will get 10 miles of range. I am working to keep the board under 10lbs. That will be challenging with 85mm wheels but they sure ride nicely.
tung256
Post by tung256 » Nov 14, 2014 7:25 am
ok seriously, are you planning to sell it to the public? and what's the price range?
i highly recommend making at least 3 versions from low to high end.
UrNzWy
100 µW
100 µW
Post by UrNzWy » Nov 14, 2014 10:50 am
Looks awesome! That range though... That's the big complaint with the boosted boards. Weight isn't a huge concern to some people. Now don't get me wrong, but I would take an extra 5 pounds to double or triple the range. It would be nice to have a base model with an extended battery compartment, thus able to add capacity. Assuming your ESC can take the amps.
CFRP
Post by CFRP » Nov 14, 2014 6:55 pm
I will be selling this to the public. The price range will depend on the final specifications. I would like to keep the price close to $1000 or below.
UrNzWy,
Thank you for your comment on range. What range would you like to see?
The obvious answer is, the more range is better. But..this naturally adds to weight, deck size, and cost.
JJ2525
Post by JJ2525 » Nov 14, 2014 7:13 pm
As someone who's vacillating between an Evolve Carbon and Marbel, this looks like a very interesting option. I'll be eagerly following your progress.
I echo the sentiments someone else wrote...I'd be fine with a bit more weight if it meant more range.
Do you have a tentative ETA on when you want to bring this to market?
When you do bring it to market, please tell me the remote won't be the big controller used in the video?
UrNzWy
100 µW
100 µW
Post by UrNzWy » Nov 14, 2014 7:38 pm
CFRP wrote:I will be selling this to the public. The price range will depend on the final specifications. I would like to keep the price close to $1000 or below.
UrNzWy,
I do have to say i have a Evolve Carbon AT with the Street wheels as well. While not crazy heavy, the range is massive. Especially with the street setup. However, it would not be convenient to carry around and as kinda a pain when going into a restaurant to set down. But I don't use it to commute here in Phoenix. Occasionally to go pickup food around my neighborhood.
I also have a Yuneec, which is fun to cruze on but a bummer it is limited at 13mph. That said, the range is pretty big as well. It just about kept up with my Carbon AT through a full battery.
For a later thought, if you decided to make a All Terrain setup.. Since you will have the extra clearance, possibly making another deeper mold of the battery compartment to allow additional storage and an awesome compact AT board. Which I would LOVE to see.
Have you looked into a custom battery pack? It seems you have a decent amount of space in your current design and could benefit from a custom pack for a bit more in price and a decent amount in additional range.
tung256
Post by tung256 » Nov 14, 2014 8:52 pm
im hoping you will have at least 13km for range. 5km forward, and 5km to go back home, with the 3km for buffer. i dont mind charging the batteries every night.
if a commute is longer than 5km, i would rather take the bus.
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Nov 14, 2014 8:57 pm
I highly doubt you could offer a carbon fiber deck 2 motor for less than $1,000. Unless, you wanted to assemble electric skateboards for free. :mrgreen: If you can.. more power to you :D
DIYElectricSkateboard.com Electric Skateboard Kits
flathill
Post by flathill » Nov 15, 2014 3:18 am
You are True craftsmen
How are the batteries gonna handle board flex? I would use some panasonic/samsung/lg/sony 18650s and make it thinner
10 miles on flat land is not enough. Figure 15 on flat means 8 in a hilly city
Forget phosphate
svt/r&d
Post by svt/r&d » Nov 15, 2014 3:18 pm
Range could be added with a back pack or hip pack and a plug in port. :idea:
CFRP
Post by CFRP » Nov 23, 2014 5:02 pm
Putting together a very simple and cost effective kit for driving the Seismic Skate Speed Vent wheels.
This is a 1 piece injection molded part that drops right into the wheel. Designed for a 15mm wide belt. Works with 5mm PowerGrip GT or HTD belts.
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Nov 23, 2014 8:00 pm
Nice looks good. How much is it?
CFRP
Post by CFRP » Nov 26, 2014 6:12 pm
I could probably sell a kit for about $25 if there is enough interest.
psychotiller
Post by psychotiller » Nov 26, 2014 7:56 pm
CFRP wrote:I could probably sell a kit for about $25 if there is enough interest.
I'll buy 2 right now.
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttps://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through https://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Nov 26, 2014 8:00 pm
I'll help. 2 here too.
psychotiller
Post by psychotiller » Nov 26, 2014 8:02 pm
I'll see Torque's 2 and raise him 1. 8)
builds:
phomann
Post by phomann » Nov 26, 2014 8:17 pm
I'll take a pair as well.
Cheers,
Peter
MiniWiiceiver- http://www.homanndesigns.com/store/inde ... cts_id=277
Longboard build: https://endless-sphere.com/forums/viewto ... 35&t=60280
Homann Designs - http://www.homanndesigns.com/store/
torqueboards
1.21 GW
1.21 GW
Post by torqueboards » Nov 26, 2014 9:20 pm
psychotiller wrote:I'll see Torque's 2 and raise him 1. 8)
:mrgreen: I thought you only ride Pneumatics! lol You don't need these...
psychotiller
Post by psychotiller » Nov 27, 2014 1:01 am
Whaaaaat? I still rock urethane.
builds:
CFRP
Post by CFRP » Nov 27, 2014 1:26 pm
Thanks for the interest. I plan to have these available late December.
This illustrates how the parts are installed on a wheel.
Over-all deminsions
If anyone else is interested just let me know so I can make sure I order enough parts.
JJ2525
Post by JJ2525 » Nov 27, 2014 1:41 pm
Are you still planning on selling the entire complete boards as well?
psychotiller
Post by psychotiller » Nov 27, 2014 2:10 pm
If there's any chance you're thinking about doing a 32 tooth pulley I'll buy a couple of those too.
builds:
