Anti spark XT90 connectors
benj   100 W
Post by benj » Sep 11 2014 3:17am
I hadn't seen these before, but they look great for a budget setup and if space is at a premium. They fit a standard XT90 but handle all the anti-spark stuff for you, so just solder them in and happy days. Cheap too!
https://www.hobbyking.com/hobbyking/sto ... _bag_.html
SunCoaster   100 W
HobbyKing Anti-Spark Connector - XT90-S
Post by SunCoaster » Sep 11 2014 4:42pm
itchynackers   100 kW
Re: Anti spark XT90 connectors
Post by itchynackers » Sep 11 2014 5:15pm
It doesn't really give any information on what wattage/resistance these are. I currently have a 1000ohm 10 watt resistor for my 100V setup. Not sure if this would work or not.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
teslanv   100 MW
Post by teslanv » Sep 11 2014 11:05pm
So if I understand correctly, these connectors have "pre-charge" resistors built into the housings?
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
Drevious   100 mW
Post by Drevious » Sep 14 2014 3:42am
whereswally606   100 kW
Post by whereswally606 » Sep 23 2014 4:31pm
Just received my connectors today. Installed 3 minutes ago and I can confirm no spark with a 54.6v pack, a very happy uk customer.
Bought a load and will have them on all my ebikes now. I've been a convert to xt60's for a while but these xt90s seem like a no brainer.
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
itchynackers   100 kW
Post by itchynackers » Sep 23 2014 8:16pm
Thanks for the update. I have mine on order. I have a 25s lipo pack to try. Hopefully no spark, but I doubt it.
Silenthunter   1 kW
Post by Silenthunter » Sep 23 2014 8:48pm
What is the amps rating for this connectors?
amberwolf   100 GW
Post by amberwolf » Sep 25 2014 7:00pm
I'd guess it's 90A, minimum, possibly a bit more?
Silenthunter   1 kW
Post by Silenthunter » Sep 25 2014 10:13pm
I would like to buy some for my mountain board with 8S 33.6V pack....I pull average 40 amps and max about 120-150 amps. I guess it should do it...
Russell   10 MW
Post by Russell » Sep 25 2014 11:42pm
itchynackers wrote:It doesn't really give any information on what wattage/resistance these are. I currently have a 1000ohm 10 watt resistor for my 100V setup. Not sure if this would work or not.
Why so big?
-R
Jeep Comanche Trekking Bike w/YOUE geared motor, 42 lbs + 15 lb rear trunk bag w/12S 16Ah LiPo battery, tools, etc., 21A controller, 700 x 40C tires. 27 MPH.
My other E-Bikes: Nashbar Steel Flatbar
itchynackers   100 kW
Post by itchynackers » Sep 26 2014 6:04am
Because it doesn't spark. What would you suggest?
Russell   10 MW
Post by Russell » Sep 26 2014 9:42am
Of course it depends on the size caps in your controller but 100 ohms would be fine for 100V. I'm using 50 ohm for a 12S pack w/main caps of 470-1000uF. Peak current of 1A for a tiny fraction of a second.
-R
itchynackers   100 kW
Post by itchynackers » Sep 26 2014 4:25pm
Just got my xt90's in the mail. Looks like there is a very small "5.6ohm" printed on the connector. With that, what maximum voltage should these be good for?
teslanv   100 MW
Post by teslanv » Sep 26 2014 4:29pm
I thought the point of a "pre-charge" was to slow the current flow during the initial connection. If the 5.6ohm resistor is in the primary (And ONLY) path of the current flow, won't it inhibit the flow of current and heat up when discharging the battery at high amps? And wouldn't you need a clear path with minimal resistance from the battery to the controller/motor?
Bellevue, WA
USA
itchynackers   100 kW
Post by itchynackers » Sep 26 2014 4:35pm
I'm fairly sure the pre-charge only "charges" when you begin to make the connection. As you slide the connector on all the way, the pre-charge disengages, while the main connects completely.
jackjetful   100 W
Post by jackjetful » May 18 2015 2:20am
Also bought this connectors for my current build; have a 20S Battery ant Kelly Controller.
the required precharge resistor is 1K!
I opened up the XT90 and here is what it looks inside:
jackjetful   100 W
Post by jackjetful » May 18 2015 2:25am
5.6OHM seemed to be to less to charge the capacitors of the Kelly.
I think they would charge up to fast; this could damage them.
I also don't know how many watts the 5.6OHM Resistor has.
nutnspecial   1.21 GW
1.21 GW
Post by nutnspecial » May 18 2015 3:50am
Hey brother! My 2cents= I think I heard the resistor is just really to protect the connectors, and caps are not damaged by 'surge' that don't exceed rated capacity.
Also, from what my infineon does without any anti-draindown mods, you have to leave the battery disconnected for days to fully drain down the 18fet 4110, and even then it's no real big deal to reconnect the 82v, but it does SNAP a little lol. I leave it connected except when charging anyway.
Ps, I didn't know you were doing 20s!!!!! I wish we were able to get together and ride!
Nobuo   10 kW
Post by Nobuo » May 18 2015 5:59am
jackjetful wrote:5.6OHM seemed to be to less to charge the capacitors of the Kelly.
Do you think is as small that is useless?
i found them at a good price.
http://www.aliexpress.com/store/product ... 93215.html
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
riba2233   1 MW
Post by riba2233 » May 18 2015 7:01am
You didn't have to bother, 5.6 ohm would work fine. With 1k you need to hold the connector partially plugged for few seconds, which might be easy to forget every time. And with 5.6 ohm you don't have to think about it, just plug it in, it precharges pretty fast.
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
KalSteve   1 W
1 W
Post by KalSteve » May 18 2015 9:34am
I've got them, use them on 48v and 72v setups. Work great, no fuss no spark. Easiest precharge resistor setup I have seen.
Hummina Shadeeba   100 MW
Location: sausalito cali..up the hill in front of the cruising club.
Post by Hummina Shadeeba » May 18 2015 10:41am
These say 150
I have too many if ur interested. Nice because they allow you to separate the wires.
http://rcsearch.info/hobbyking/i42825/
Vanarian   10 kW
Post by Vanarian » May 18 2015 11:42am
Hummina Shadeeba wrote:These say 150
How many do you have? I'm interested ;)
-+AT-One project : electric inline skates - no remote, hub motors, one frame for various wheel sizes & quasi-universal boot mount
Rollo Ergo Sum!
Post by Hummina Shadeeba » May 18 2015 1:09pm
I went crazy buying plugs of different types. these I have at least 6 extra. you need two. connect the black then the red.
write me pm and we can figure out what you can send me in exchange. Maybe you can let me live on your nice outdoor patio I saw in your video.
