Bucefalo [Project]
arielrossolato   10 mW
Bucefalo [Project]
Post by arielrossolato » Oct 17 2014 4:17pm
Hi guys, this is my very first post, but i've been reading this forum for a while.
and i'd like to present you, guys, my project.
and please give a feedback regarding any problem i could encounter with my setup.
Me
the driver. 65 Kg 143 lb and there, where i live, it's flat as the cardiogram of my grandma
THE BOARD
the board is a cheap pintail, but i don't want to spend too much: http://www.decathlon.it/longboard-pinta ... 29843.html
THE MOTOR
(is that enough power?) single FWD: http://www.hobbyking.com/hobbyking/stor ... 2400W.html
i'm not so sure about that point
BATTERIES
two of these batteries: http://www.hobbyking.com/hobbyking/stor ... duct=56839
i'll put them in a case, like the bubblegum one but thinner and "rounder" (2.5 cm thick) the esc is in another place and it will be near the rear wheels
ESC
this ESC: http://www.hobbyking.com/hobbyking/stor ... r_esc.html
i'll put it on the tail with an aereodinamic case, for cooling and cuz it's cool (mere aesthetics)
CONTROLLER
and this is the controller(reciver included) http://hobbyking.com/hobbyking/store/__ ... ttery.html
i will open it and put the needed components inside a custom made case with my beloved 3d printer
the pulley are custom made with a 3d printer with abs.
14-35 gear ratio
i have still one big problem, the motor mount. i'd like to make it with the 3d printer.
but i'm not very good with autocad, sketch up, blender or similar and i can not find any stl file, any advice?
P.S. i come from italy (Milan) and i'm 16 years old. i'm sporty but when it comes to skateboarding i sincerly don't want to kick.
and i'll use my creationts for helping me in my daily commute (i also use public transport)
PracticalProjects   10 W
Re: Bucefalo [Project]
Post by PracticalProjects » Oct 17 2014 5:05pm
Parts look good, just be aware that these 3D printed mounts are not guaranteed to last a long time. I would be constantly worried about it breaking. If you are not good with CAD the best way is probably just to draw it, make a cardboard model to see how it will look and then make it out of aluminium by hand. Good luck!
beto_pty   1 kW
Post by beto_pty » Oct 17 2014 5:17pm
Excelent name...perhaps it will only let you ride him?
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
Post by arielrossolato » Oct 17 2014 7:28pm
beto_pty wrote:Excelent name...perhaps it will only let you ride him?
Of course, i will put a finger print scanner...
J.K. but i relly like alexander and so...
And regarding the 3d printed parts it's not a big problem, i'm a combo between a reckless dude and stoner, so i relly dont' care about dying due a pulley failure :D
And i will make it in alu, cuz it's easier
adriftatsea   100 W
Post by adriftatsea » Oct 17 2014 8:41pm
arielrossolato wrote: And i will make it in alu, cuz it's easier
It's also better for heat transfer, as the controller puts off lots of heat.
There are plenty of areas where 3dprinted parts are great. I'm using the following printed with ABS: controller mount, phone/diy ca mount, throttle lever and mount, mount for 100A breaker and fuse, and a rather complicated battery box.
Lastly, awesome project name.
[Santa Cruz Heckler] - Tangent 80:1 RC mid-drive, 12s 16ah, 44t, clutched derailleur, Fox 40/dhx5, Hope mono6ti. Pic: http://imgur.com/XAt85di
[e-kart/buggy thing] - ME1003, Alltrax 7245, 400a, 20s60ah (leaf modules), CA3. Pic: http://imgur.com/ZOpCJ6I
[Bad Boy Buggy XT] - Dual DC motors, Curtis 1268 @ 400A/ea, 14s120ah leaf modules, CA3
torqueboards   100 MW
Post by torqueboards » Oct 17 2014 9:03pm
You got it right. All the parts are common parts for what we try and build.
The pulleys I would suggest using real pulleys as well as real motor mounts. It's much safer and you can count on it not falling apart on you going 20mph.
Nobody has STL files on it just yet. I'll be working on a few designs and will release it on thingiverse that way people can use it for free. I'll release belt covers + enclosures if they wanted them.
These boards are great for commuting. I use it everyday and it never gets boring.
Good luck. Post some pictures :)
DIYElectricSkateboard.com Electric Skateboard Kits
bandaro   10 kW
Post by bandaro » Oct 18 2014 1:46am
Sweet, sounds like a nice project.
I could model a motor mount into a printable file faster than it could be uploaded, but while 3D printing is awesome, it's not the technology you want. If you don't want to cut some 6-8mm aluminium for the mount, make one out of cardboard and then use illustrator to draw it up. Draw it exactly as you want it, then you can send the .ai file to any laser cutting place and they will be able to cut it out for you. Laser/CNC is the technology for flat plate materials that you want, not 3d printing.
As for the pulleys, nylon may be strong enough for the driven, if you found a model that had a beefed up wall thickness, but it won't be good enough for the drive pulley, it will pull apart and shred if you start putting any real power into it. Pulleys are cheap, just get some when you get the belts, you will already be getting shipping/going to the store. That being said, a good SLS printed drive pulley *might* be strong enough if printed solid, but probably not cheaper...
Looking forward to seeing how it goes!
Edit: Didn't check the batts, but yeah, as below said, go a higher c rating. It makes the work on the batteries so much less. I run a total of 10,000mah at 20c (2 zippy 5000mah 20c batts).
razad7@gmail.com   1 W
1 W
Post by razad7@gmail.com » Oct 18 2014 11:46am
I would recommend different batteries because those are rated to 10C constant and 20 peak. go with at least 20C const. in my opinion.
beto_pty   1 kW
Post by beto_pty » Oct 18 2014 7:19pm
you need the esc programer card.
the settings on the hobbyking suck... you have to change them to get the uncogging to stop, by setting the timing on high, otherwise it will throw you off, also the start is better at mid and the breaking at 60% rocks
Post by arielrossolato » Oct 19 2014 5:01am
beto_pty wrote:you need the esc programer card.
Alredy listed
Post by arielrossolato » Oct 19 2014 5:02am
razad7@gmail.com wrote:I would recommend different batteries because those are rated to 10C constant and 20 peak. go with at least 20C const. in my opinion.
Thanks, i'll search for a thin 20c battery :-)
Post by arielrossolato » Dec 25 2014 7:28am
UPDATE
i bought all the mecanichs parts, sadly from enertion shop...
(not enough time and money for building them by my own).
-Project Still Alive-
mccloed   100 W
Post by mccloed » Dec 25 2014 12:07pm
Parts look good. I have a board with the same parts list and 20/40 gears on 80mm wheels. I can go 25mph(40kph).
Post by arielrossolato » Dec 25 2014 12:34pm
Ah, i forgot to say that i moved to switzerland, in the Alps...
so the roads are no longer flat, and therefore i changed my gear ratio.
(and that's why i had that huge delay on the schedule)
Updates to come...
made_in_the_alps_legacy   10 kW
Post by made_in_the_alps_legacy » Dec 28 2014 3:33am
arielrossolato wrote:Ah, i forgot to say that i moved to switzerland, in the Alps...
Really? where did u move? Ticino?
Post by arielrossolato » Jan 04 2015 12:35am
No, i live in Chur (Coira).
But my father lives in Mesocco...
Post by made_in_the_alps_legacy » Jan 06 2015 8:22am
I see, I think I went once in Chur when I was living in Argovia, now I am in Wallis...
Anyway, how is your built going ?
Post by arielrossolato » Oct 26 2015 3:40pm
Project still alive, now i have all the parts.
except for the controller and the reciver.
This is not the final version
Pictures
https://app.box.com/s/zwpiouwsxccqyfdmwscbiupzb07cu7vm
https://app.box.com/s/nv6tdyq2ppq9x92teib1h3p2l26njh0r
Post by arielrossolato » Nov 13 2015 12:41pm
At the moment i have two 7000mha 6s lipo 25c and a 130kv 63mm rated for max 10s from alien power system.
I'm planning to buy a Vesc, maybe in one month.
Having the possibility to get new batteries should i buy a 10s setup or a 12s.
What should i upgrade, what should i change for having the most out of my money? :?
