arielrossolato
- Joined
- Oct 12, 2014
- Messages
- 33
Hi guys, this is my very first post, but i've been reading this forum for a while.
and i'd like to present you, guys, my project.
and please give a feedback regarding any problem i could encounter with my setup.
Me
the driver. 65 Kg 143 lb and there, where i live, it's flat as the cardiogram of my grandma
THE BOARD
the board is a cheap pintail, but i don't want to spend too much: http://www.decathlon.it/longboard-pintail-id_8229843.html
THE MOTOR
(is that enough power?) single FWD: http://www.hobbyking.com/hobbyking/store/__22036__NTM_Prop_Drive_50_60_270KV_2400W.html
i'm not so sure about that point
BATTERIES
two of these batteries: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=56839
i'll put them in a case, like the bubblegum one but thinner and "rounder" (2.5 cm thick) the esc is in another place and it will be near the rear wheels
ESC
this ESC: http://www.hobbyking.com/hobbyking/store/__10370__hobby_king_150a_high_performance_brushless_car_esc.html
i'll put it on the tail with an aereodinamic case, for cooling and cuz it's cool (mere aesthetics)
CONTROLLER
and this is the controller(reciver included) http://hobbyking.com/hobbyking/store/__31671__HobbyKing_HK_GT2B_3CH_2_4GHz_Transmitter_and_Receiver_w_Rechargable_Li_ion_Battery.html
i will open it and put the needed components inside a custom made case with my beloved 3d printer
the pulley are custom made with a 3d printer with abs.
14-35 gear ratio
i have still one big problem, the motor mount. i'd like to make it with the 3d printer.
but i'm not very good with autocad, sketch up, blender or similar and i can not find any stl file, any advice?
P.S. i come from italy (Milan) and i'm 16 years old. i'm sporty but when it comes to skateboarding i sincerly don't want to kick.
and i'll use my creationts for helping me in my daily commute (i also use public transport)
Me
THE BOARD
THE MOTOR
BATTERIES
ESC
CONTROLLER
14-35 gear ratio
