3D printed parts Depository
Vanarian   10 kW
Re: 3D printed parts Depository
Post by Vanarian » Apr 24 2015 1:15pm
Haha true you're totally right :P
I think I'll buy a big plexiglas box to put around the printer, not as practical but should protect it from wind.
-+AT-One project : electric inline skates - no remote, hub motors, one frame for various wheel sizes & quasi-universal boot mount
Rollo Ergo Sum!
torqueboards   100 MW
Post by torqueboards » Apr 24 2015 1:30pm
Vanarian wrote:Haha true you're totally right :P
That works..
DIYElectricSkateboard.com Electric Skateboard Kits
torqueboards   100 MW
Post by torqueboards » Apr 29 2015 11:39am
Here's another cool printer - http://www.makergeeks.com/dui3de3dprfr.html - $425.95. Putting a plexiglass enclosure around it would be nice with a door to open would be even better.
lowrizzle   100 mW
Post by lowrizzle » May 10 2015 4:51pm
Looongtime lurker almost-never poster adding a couple of things I just uploaded:
42 Tooth Onda HDT 5m pulley:
http://www.thingiverse.com/thing:820097
18650 4x1 cell carrier:
http://www.thingiverse.com/thing:820139
The neat thing about the 42t pulley is that you can really easily tap the stock holes for 5mm screws. I've got a couple longboard projects I'm working on. I've lurked here for a real long time without posting because this place just has that much info to take in without having to ask to be spoonfed, hopefully I can start contributing back ;)
Oh, and here's a nice 3d printer fail, skip to about a minute in. I was printing Sune's faraday motion sprocket when one of the setscrews for the balljoints gave out.
Vanarian   10 kW
Post by Vanarian » May 11 2015 5:09am
lowrizzle wrote:Looongtime lurker almost-never poster adding a couple of things I just uploaded:
First, welcome :D
I feel you there but if you're able to bring this kind of things don't be afraid to post.
Second : thank you! The 18650 cell carrier here looks like a good form factor, are the cells able to expand a bit when they heat? Allow me to post this to Freshair topic!
Rollo Ergo Sum!
Vanarian   10 kW
Post by Vanarian » May 15 2015 9:13am
After further research I've cancelled my order on the Genesis 3D because lack of CE certification so I would have never been shipped in France unless they solved this certification problem.
Instead I went for a TeeBot! Delivery expected in August :)
Rollo Ergo Sum!
buzztiaan   1 W
1 W
Post by buzztiaan » May 17 2015 5:07pm
Just published some models you guys might like ;)
http://www.thingiverse.com/thing:833057 (wheel pulleys, both 44 and 48 teeth versions)
http://www.thingiverse.com/thing:833053 (motor pulley, 16 teeth version)
http://www.thingiverse.com/thing:804463 (updated motor mount for Randal RII trucks)
Images here ; http://imgur.com/95k7sJg,88jZi9W,kS1TcIr#2
I'll let you know later how long this print survives (it's just 8mm thick, printed at 100% fill out of PLA)
HK150 - 5055 SK3 280kv - 6S 5000mAh - 90mm bigfoots
https://nurdspace.nl/RobertLongboard
RideTheIon   10 mW
Post by RideTheIon » May 24 2015 7:19am
This is the wheel sprocket adapter for my build.
http://endless-sphere.com/forums/viewto ... 35&t=69243
The adapter fits an ElectricScooterParts's 54 Tooth Rear Wheel Sprocket for #25 Chain (holes enlarged to 6 mm)
http://www.electricscooterparts.com/SPR-2554.htm
Couples to a MBS TriSpoke Hub
http://shop.mbs.com/accessories-366/mou ... black.html
The adapter is based on MrRocketman's Wheel_Insert_Inside.stp
http://www.thingiverse.com/thing:236811/#files
I selected a larger wheel sprocket for my build with a larger bolt pattern. I put in a few night trying to learn Freecad and then sent the job to a freelancer.
Here is the original versus modified
Original on the right, Modified on the left
Endless-sphere didn't let me upload the STL mesh file, STEP model or Solidworks model, so I'll send them to MrRocketman's and he will hopefully add them to his Thingiverse page.
My own quote
Luckily tweaking a 3D model is a lot easier than tweaking a physical object.
The hell it is. If I could have used a dremel on the STP-file, this mod would have been done in 30 min :lol:
buzztiaan   1 W
1 W
Post by buzztiaan » May 29 2015 3:13pm
buzztiaan wrote:I'll let you know later how long this print survives (it's just 8mm thick, printed at 100% fill out of PLA)
The 'tube' part that grabs the irregularities on the hanger has seperated from the main body of the mount. I have glued it with 2 component acrylic paint about 20km ago.. Total is now about 35km.
bandaro   10 kW
Post by bandaro » Jun 01 2015 5:46am
83 and 90mm abec flywheel clones, very high accuracy. https://grabcad.com/library/flywheel-sk ... l-clones-1
torqueboards   100 MW
Post by torqueboards » Jun 01 2015 11:12am
Sweet deal! Nice -- Did you make it?
Ptown_Cruiser   1 mW
Post by Ptown_Cruiser » Jun 01 2015 8:00pm
@Beto_py or anyone else do you have/know where I can get a model for a 36t 15mm pulley that fits the 83 clones? Beto I know you said you use a 15mm setup unlike most of the people who are using 9mm setups. I am going to investment cast it for a class project (class credit for making my e-board that much more awesome?!?! yes please.) Thanks!
Hummina Shadeeba   10 MW
Post by Hummina Shadeeba » Jun 01 2015 10:50pm
investment cast! cool. always wanted to but never did.
are you going to do a lost pla cast? I heard there's a new wax filament that you could melt out and burn out cleaner than the pla.
you going to do it in aluminum? might as well do something longer lasting and nicer looking like aluminum bronze if you can get that bit hotter.
Ptown_Cruiser   1 mW
Post by Ptown_Cruiser » Jun 01 2015 10:57pm
Yeah i am pretty excited about it, we will have to see how it turns out. yeah I will be doing it with PLA. The wax filament sounds cool, but I know they don't have it for the printer I have access to at school, and there is no way I could get it in time. I have heard that the PLA works pretty darn well though. I am going to do it in aluminum, at least at first (they have tons of casting aluminum for free right now), and if it works well I may well do something a bit better, but I imagine that the aluminum will hold up pretty well.
Vanarian   10 kW
Post by Vanarian » Jun 12 2015 11:15am
TeeBot successfully funded 400%! :D
Will be able to join your fray by August haha
There really is more and more materials to print with nowadays, promises beautiful designs for e-boards.
Rollo Ergo Sum!
beto_pty   1 kW
Post by beto_pty » Jun 12 2015 6:21pm
Ptown_Cruiser wrote:@Beto_py or anyone else do you have/know where I can get a model for a 36t 15mm pulley that fits the 83 clones? Beto I know you said you use a 15mm setup unlike most of the people who are using 9mm setups. I am going to investment cast it for a class project (class credit for making my e-board that much more awesome?!?! yes please.) Thanks!
Let me see.. i think i had on in solidworks..cant remember if it was36 or 38..
Need it as an stl ?
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
bandaro   10 kW
Post by bandaro » Jun 14 2015 5:52am
Speaking to okp regarding the controller housing I have done and while he isn't keen on it, a friend of his is enjoying it. I am also finding no problems in my testing, so uploading the files for all.
Basically, this is a new controller housing for the internals of a GT2E controller from hobbyking. Doesn't use any extra parts and easy to convert. Uses a thumb throttle control, keeps the control panel board unchanged, and is much smaller than stock. Still a little large and heavy due to the 4 AA batteries, so if anyone wants to buy me a GT2B for a similar conversion then that could be cool..
https://grabcad.com/library/gt2e-contro ... ateboard-1
Partially assembled controller
2015-04-23 16.19.39.jpg (220.69 KiB) Viewed 1269 times
mccloed   100 W
Post by mccloed » Jun 16 2015 4:32pm
Finally have something to contribute here. I modified Voodoojar's 50mm motor mount for 63mm motors. The sizing fits Torqueboards weld on motor mounts pretty well. Heres the file on Thingiverse if anyone is interested:
http://www.thingiverse.com/thing:884314
I also made a version for those of us who still use the 20 tooth motor pulley and 40 tooth wheel pulley w/ 9mm belt:
http://www.thingiverse.com/thing:884310
killisch   100 mW
Post by killisch » Aug 13 2015 9:58pm
http://www.thingiverse.com/thing:965514
Made a 40 tooth htd5 kegel pulley for 15mm belts.
Cheers voodoojar for the inspiration.
okp   100 kW
Post by okp » Aug 14 2015 12:18am
could you make a 32T?
killisch   100 mW
Post by killisch » Aug 14 2015 1:59am
Yeah no worries mate.
I'll knock one up tonight after work.
okp   100 kW
Post by okp » Aug 14 2015 4:14am
thanks !
killisch   100 mW
Post by killisch » Aug 14 2015 7:23am
Here ya go okp.
any changes preferred let me know and I'll change it as best i can.
http://www.thingiverse.com/thing:968312
okp   100 kW
Post by okp » Aug 14 2015 7:30am
great, is it the same than this one ?
in this one, it seems that there's something that fits on the other side of the wheel
akiraEC   100 W
Post by akiraEC » Aug 14 2015 7:33am
I dont think so.
There is not part on this outter side and the pully side which is close to the wheel is flat (whereas this other one is curved to match the wheel shape).
It is probably another design.
